#include #include #include #define uchar unsigned char #define uint unsigned int #define Delay4us() {_nop_();_nop_(); _nop_();_nop_();} ***it SCL =P3^2; ***it SDA =P3^3; //上次按键和当前按键序号,该矩阵中序号范围0-15,16表示无按键 uchar Pre_KeyNo = 16,KeyNo = 16; uchar code title_Test[] ="Your Password..."; //标题字符串 uchar DSY_BUFFER[10] =""; //显示缓冲 uchar UserPassword[10] =""; //用户输入的密码 void LCD_Init(); //液晶初始化 void Display_String(uchar *str,uchar LineNo); //液晶指定行显示字符串 void IIC_24C04_Init(); //IIC初始化 void Beep(); //蜂鸣器
uchar RecString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N); //从IIC读取数据 uchar SendString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N); //向IIC写入数据 uchar Keys_Scan(); //键盘扫描,返回键盘号0-15 ***it LED_OPEN =P2^7; //开锁亮灯 ***it BEEP=P3^7; ***it LCD_RS= P2^0; ***it LCD_RW= P2^1; ***it LCD_EN= P2^2; //起始位// void Start() { SDA = 1; SCL = 1; Delay4us(); SDA = 0; Delay4us(); SCL = 0; } //停止位// void Stop() { SDA = 0; SCL = 1; Delay4us(); SDA = 1; Delay4us(); SCL = 0; } //IIC总线初始化// void IIC_24C04_Init() { SCL = 0; Stop(); } //发送应答信号// void ACK() { SDA = 0; SCL = 1; Delay4us(); SCL = 0; SDA = 1; } //发送非应答信号// void NO_ACK() { SDA = 1; SCL = 1; Delay4us(); SCL = 0; SDA = 0; } //从芯片读取1字节// uchar RecByte() { uchar i,rd; rd = 0x00; SDA = 1; for(i = 0; i<8; i++) { SCL = 1; rd <<=1; rd|= SDA; Delay4us(); SCL = 0; Delay4us(); } SCL = 0; Delay4us(); return rd; } //向芯片发送1字节// uchar SendByte(uchar wd) { uchar i; bit ack0; for(i = 0; i<8; i++) { SDA = (bit)(wd & 0x80 ); _nop_(); _nop_(); SCL = 1; Delay4us(); SCL = 1; wd <<= 1; } Delay4us(); SDA = 1; SCL = 1; Delay4us(); ack0 = !SDA; SCL = 0; Delay4us(); return ack0; } //发送多字节数据函数// uchar SendString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N) { uchar i; Start(); if(!SendByte(Slave)) return 0; if(!SendByte(Subaddr)) return 0; for(i = 0; i if (!SendByte(Buffer)) return 0; } Stop(); return 1; } //接收多字节数据函数// uchar RecString(uchar Slave,uchar Subaddr,uchar *Buffer,uchar N) { uchar i; Start(); if(!SendByte(Slave)) return 0; if(!SendByte(Subaddr)) return 0; Start(); if(!SendByte(Slave + 1)) return 0; for(i = 0; i Buffer = RecByte(); ACK(); } Buffer[N-1] = RecByte(); NO_ACK(); Stop(); return 1; } void DelayMS(uint x); uchar Keys_Scan() { uchar Tmp,KeyNo = 0; P1 = 0x0F; DelayMS(1); Tmp = P1^ 0x0F; switch(Tmp) { case 1: KeyNo = 0;break; case 2: KeyNo = 1;break; case 4: KeyNo = 2;break; case 8: KeyNo = 3;break; default: KeyNo = 16; } P1 = 0xF0; DelayMS(1); Tmp = P1 >> 4^ 0x0F; switch(Tmp) { case 1: KeyNo += 0;break; case 2: KeyNo += 4;break; case 4: KeyNo += 8;break; case 8: KeyNo += 12; } return KeyNo; } //延时// void DelayMS(uint x) { uchar i; while (x--) for (i=0;i<120;i++); } //蜂鸣器子程序// void Beep() { uchar i; for(i = 0;i<100;i++) { DelayMS(1); BEEP= ~BEEP; } BEEP =0; } //清除密码// void Clear_Password() { UserPassword[0]=' |
