IT66021资料
General Description The IT66021FN is a single-port HDMI receiver, it is fully compatible with HDMI 1.4b, HDMI 1.4b 3D and HDCP 1.4 and also backward compatible to DVI 1.0 specifications. The IT66021FN with its Deep Color capability (up to 36-bit) ensures robust reception of high-quality uncompressed video content. The IT66021FN also supports all the primary 3D formats which are compliant with the HDMI 1.4b 3D specification.Aside from the various video output formats supported, the IT66021FN also receives and provides up to 4 channels of I2S digital audio outputs, with sampling rate up to 192kHz and sample size up to 24 bits, facilitating direct connection to industry-standard low-cost audio DACs. Also, an S/PDIF output is provided to support up to compressed audio of 192kHz frame rate. Each IT66021FN comes preprogrammed with an unique HDCP key, in compliance with the HDCP 1.4standard so as to provide secure transmission of high-definition content. Users of the IT66021FNneed not purchase any HDCP keys or ROMs. Features Single-port HDMI 1.4b receiver. Compliant with HDMI 1.4b, HDMI 1.4b 3D, HDCP 1.4 and DVI 1.0 specifications Supporting link speeds of up to 3.0Gbps (link clock rate of 300MHz) for 4K2K or 1080p@120hz solution. Supporting all the primary 3D formats which are compliant with the HDMI 1.4b 3D specification. Supporting 3D video up to 1080P@50/59.95/60/120Hz, 1080P@23.98/24/29.97/30Hz, 1080i@50/59.94/60/Hz, 720P@23.98/24/29.97/30Hz, 720P@50/59.94/60Hz Supporting formats: Framing Packing, Side-by-Side (half), Top-and-Bottom. Video output interface supporting digital video standards such as: 24-bit RGB/YCbCr 4:4:4 16-bit YCbCr 4:2:2 8-bit YCbCr 4:2:2 (ITU BT-656) 24-bit double data rate interface (full bus width, pixel clock rate halved, clocked with both rising and falling edges) Input channel swap MSB/LSB swap (Only for deep color 12bpp mode) Bi-direction Color Space Conversion (CSC) between RGB and YCbCr color spaces with programmable coefficients.IT66021FN www.ite.com.tw T8720F V0.7.1 Jun-2014 Rev0.91 3/44 Up/down sampling between YCbCr 4:4:4 and YCbCr 4:2:2 Dithering for conversion from 12-bit component to 8-bit Digital audio output interface supporting up to two I2S interface supporting 4-channel audio, with sample rates of 32~192 kHz and sample sizes of 16~24 bits S/PDIF interface supporting PCM, Dolby Digital, DTS digital audio at up to 192kHz frame rate automatic audio error detection for programmable soft mute, preventing annoying harsh output sound due to audio error or hot-unplug Auto-calibrated input termination impedance provides process-, voltage- and temperature-invariant matching to the input transmission lines. Integrated pre-programmed HDCP keys Integrated programmable EDID RAM Intelligent, programmable power management 76-pin QFN (9mm x 9mm) package RoHS Compliant ( 100% Green available ) |
哇撒,已经大批量生产了!杠杠的。
谢谢楼主 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1495 浏览 0 评论
2510 浏览 1 评论
1256 浏览 0 评论
1717 浏览 0 评论
3528 浏览 3 评论
GMT+8, 2025-12-10 01:46 , Processed in 0.567028 second(s), Total 48, Slave 38 queries .
