发 帖
原厂入驻New
IT66021资料,HDMI转RGB,HDMI转BT656,HDMI1.4 Receiver,HDMI转BT1120
2020-9-24 19:08:49  85 IT66021资料 HDMI Receiver HDMI转BT656 HDMI转BT1120 HDMI转RGB
分享
IT66021资料
General Description
The IT66021FN is a single-port HDMI receiver, it is fully compatible with HDMI 1.4b, HDMI 1.4b 3D and HDCP 1.4 and also backward compatible to DVI 1.0 specifications. The IT66021FN with its Deep Color capability (up to 36-bit) ensures robust reception of high-quality uncompressed video content.
The IT66021FN also supports all the primary 3D formats which are compliant with the HDMI 1.4b 3D specification.Aside from the various video output formats supported, the IT66021FN also receives and provides up to 4 channels of I2S digital audio outputs, with sampling rate up to 192kHz and sample size up to 24
bits, facilitating direct connection to industry-standard low-cost audio DACs. Also, an S/PDIF output is provided to support up to compressed audio of 192kHz frame rate.
Each IT66021FN comes preprogrammed with an unique HDCP key, in compliance with the HDCP 1.4standard so as to provide secure transmission of high-definition content. Users of the IT66021FNneed not purchase any HDCP keys or ROMs.
Features
 Single-port HDMI 1.4b receiver.
 Compliant with HDMI 1.4b, HDMI 1.4b 3D, HDCP 1.4 and DVI 1.0 specifications
 Supporting link speeds of up to 3.0Gbps (link clock rate of 300MHz) for 4K2K or 1080p@120hz
solution.
 Supporting all the primary 3D formats which are compliant with the HDMI 1.4b 3D specification.
 Supporting 3D video up to 1080P@50/59.95/60/120Hz, 1080P@23.98/24/29.97/30Hz,
1080i@50/59.94/60/Hz, 720P@23.98/24/29.97/30Hz, 720P@50/59.94/60Hz
 Supporting formats: Framing Packing, Side-by-Side (half), Top-and-Bottom.
 Video output inteRFace supporting digital video standards such as:
 24-bit RGB/YCbCr 4:4:4
 16-bit YCbCr 4:2:2
 8-bit YCbCr 4:2:2 (ITU BT-656)
 24-bit double data rate interface (full bus width, pixel clock rate halved, clocked with both rising
and falling edges)
 Input channel swap
 MSB/LSB swap (Only for deep color 12bpp mode)
 Bi-direction Color Space Conversion (CSC) between RGB and YCbCr color spaces with
programmable coefficients.IT66021FN
www.ite.com.tw T8720F V0.7.1 Jun-2014 Rev0.91 3/44
 Up/down sampling between YCbCr 4:4:4 and YCbCr 4:2:2
 Dithering for conversion from 12-bit component to 8-bit
 Digital audio output interface supporting
 up to two I2S interface supporting 4-channel audio, with sample rates of 32~192 kHz and sample sizes of 16~24 bits
 S/PDIF interface supporting PCM, Dolby Digital, DTS digital audio at up to 192kHz frame rate
 automatic audio error detection for programmable soft mute, preventing annoying harsh output
sound due to audio error or hot-unplug
 Auto-calibrated input termination impedance provides process-, voltage- and temperature-invariant
matching to the input transmission lines.
 Integrated pre-programmed HDCP keys
 Integrated programmable EDID RAM
 Intelligent, programmable power management
 76-pin QFN (9mm x 9mm) package
 RoHS Compliant ( 100% Green available )
3
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?注册
x
分享淘帖 显示全部楼层
· 2020-9-24 19:54:34
哇撒,已经大批量生产了!杠杠的。
谢谢楼主
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
关闭
站长推荐 上一条 /8 下一条
快速回复 返回顶部 返回列表
