我用的芯片是STC89C52RC,A/D转换用的HX711,显示用的是12864,传感器用的是10KG的,问题:把100G砝码放在传感器上,数值一直跳,范围在98-104之间跳动,没有稳定下来,该怎么解决?
主程序如下 #include "main.h" #include "LCD12864.h" #include "HX711.h" #include "keyboard.h" unsigned long HX711_Buffer = 0; unsigned int Weight_Maopi = 0,Weight_Shiwu = 0; char Price_Count = 0; uchar KEY_NUM = 0; unsigned char Price_Buffer[6] = {0x00,0x00,0x00,0x00,0x00,0x00}; unsigned long Money = 0; bit Flag_OK = 0; volatile bit FlagTest = 0; //定时测试标志,每0.5秒置位,测完清0 //定时器0初始化 void Timer0_Init() { EA=1; ET0 = 1; //允许定时器0中断 TMOD = 1; //定时器工作方式选择 TL0 = 0xb0; TH0 = 0x3c; //定时器赋予初值 TR0 = 1; //启动定时器 } //定时器0中断 void Timer0_ISR (void) interrupt 1 using 0 { uchar Counter; TL0 = 0xb0; TH0 = 0x3c; //定时器赋予初值 //每0.5秒钟刷新重量 Counter ++; if (Counter >= 10) { FlagTest = 1; Counter = 0; } } void main() { Timer0_Init(); //初中始化完成,开断 LCD12864_Reset(); //初始化液晶 LCD12864_HAIZI_SET(); //设置为普通模式 LCD12864_NoWaitIdle_COM_Write(0x80); //指针设置 LCD12864_write_word("※※※※※※※※"); LCD12864_NoWaitIdle_COM_Write(0x90); //指针设置 LCD12864_write_word("※※欢迎使用※※"); LCD12864_NoWaitIdle_COM_Write(0x88); //指针设置 LCD12864_write_word("※10公斤电子秤※"); LCD12864_NoWaitIdle_COM_Write(0x98); //指针设置 LCD12864_write_word("※※※※※※※※"); Get_Maopi(); //称毛皮重量 Delay_ms(2000); //延时2s,等待传感器稳定 loop: Price_Count = 0; KEY_NUM = 0; Price_Buffer[0] = 0; Price_Buffer[1] = 0; Price_Buffer[2] = 0; Price_Buffer[3] = 0; Price_Buffer[4] = 0; Price_Buffer[5] = 0; Price_Buffer[6] = 0; Money = 0; Flag_OK = 0; Get_Maopi(); //称毛皮重量 LCD12864_NoWaitIdle_COM_Write(0x01); //清空 while(1) { LCD12864_NoWaitIdle_COM_Write(0x80); //指针设置 LCD12864_write_word("★10公斤电子秤★"); if( Flag_OK == 0) { if (FlagTest==1) { Get_Weight(); FlagTest = 0; } // Get_Weight(); //称重 //显示当前重量 LCD12864_NoWaitIdle_COM_Write(0x90); LCD12864_write_word("重量:"); LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); if( Weight_Shiwu/10000 != 0) { LCD12864_Data_Write(Weight_Shiwu/10000 + 0x30); } else { LCD12864_Data_Write(' '); } LCD12864_Data_Write(Weight_Shiwu%10000/1000 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Weight_Shiwu%1000/100 + 0x30); LCD12864_Data_Write(Weight_Shiwu%100/10 + 0x30); LCD12864_Data_Write(Weight_Shiwu%10 + 0x30); LCD12864_write_word("Kg"); } LCD12864_NoWaitIdle_COM_Write(0x88); LCD12864_write_word("单价:"); LCD12864_Data_Write(' '); if( Price_Count == 0 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[0] + 0x30); } if( Price_Count == 1 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[1] + 0x30); } if( Price_Count == 2 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[2] + 0x30); } if( Price_Count == 3 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[3] + 0x30); } LCD12864_Data_Write( '.' ); if( Price_Count == 4 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[4] + 0x30); } if( Price_Count == 5 ) { LCD12864_Data_Write('_'); } else { LCD12864_Data_Write( Price_Buffer[5] + 0x30); } LCD12864_write_word("元"); LCD12864_NoWaitIdle_COM_Write(0x98); LCD12864_write_word("金额:"); LCD12864_NoWaitIdle_COM_Write(0x9f); LCD12864_write_word("元"); KEY_NUM = KEY_Scan(); if( KEY_NUM != 0x55) //当返回的不是初值时候,确认按键按下。 { if(KEY_NUM == 10) //数字A键,去皮功能 { Get_Maopi(); //去皮 } if(KEY_NUM == 15) //数字B键清除键,二次测量 { goto loop; } if(KEY_NUM == 12) //数字C输入单价错误时返回上一步 { Price_Count--; if( Price_Count < 0) { Price_Count = 0; } } if(KEY_NUM == 13) //数字D键,计算总价 { Money = Price_Buffer[0] * 100000 + Price_Buffer[1] * 10000 + Price_Buffer[2]*1000 + Price_Buffer[3]*100+Price_Buffer[4]*10+Price_Buffer[5]; Money = Money * Weight_Shiwu / 1000; LCD12864_NoWaitIdle_COM_Write(0x9b); if( Money/1000000 > 0 ) { LCD12864_Data_Write(Money/1000000 + 0x30); LCD12864_Data_Write(Money%1000000/100000 + 0x30); LCD12864_Data_Write(Money%100000/10000 + 0x30); LCD12864_Data_Write(Money%10000/1000 + 0x30); LCD12864_Data_Write(Money%1000/100 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Money%100/10 + 0x30); LCD12864_Data_Write(Money%10 + 0x30); } else { if( Money/100000 > 0 ) { LCD12864_Data_Write(' '); LCD12864_Data_Write(Money%1000000/100000 + 0x30); LCD12864_Data_Write(Money%100000/10000 + 0x30); LCD12864_Data_Write(Money%10000/1000 + 0x30); LCD12864_Data_Write(Money%1000/100 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Money%100/10 + 0x30); LCD12864_Data_Write(Money%10 + 0x30); } else { if( Money/10000 > 0 ) { LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(Money%100000/10000 + 0x30); LCD12864_Data_Write(Money%10000/1000 + 0x30); LCD12864_Data_Write(Money%1000/100 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Money%100/10 + 0x30); LCD12864_Data_Write(Money%10 + 0x30); } else { if( Money/1000 > 0 ) { LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(Money%10000/1000 + 0x30); LCD12864_Data_Write(Money%1000/100 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Money%100/10 + 0x30); LCD12864_Data_Write(Money%10 + 0x30); } else { LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(' '); LCD12864_Data_Write(Money%1000/100 + 0x30); LCD12864_Data_Write('.'); LCD12864_Data_Write(Money%100/10 + 0x30); LCD12864_Data_Write(Money%10 + 0x30); } } } } Flag_OK = 1; } if(KEY_NUM >= 0 && KEY_NUM <= 9) //显示输入的价格值 { if( Price_Count < 6 ) { Price_Buffer[Price_Count] = KEY_NUM; Price_Count++; } } } } } void Get_Weight() { HX711_Buffer = HX711_Read(); HX711_Buffer = HX711_Buffer/100; if(HX711_Buffer > Weight_Maopi) { Weight_Shiwu = HX711_Buffer; Weight_Shiwu = Weight_Shiwu - Weight_Maopi; //获取实物的AD采样数值。 Weight_Shiwu = (unsigned int)((float)Weight_Shiwu/4.109+0.05); //计算实物的实际重量 //因为不同的传感器特性曲线不一样,因此,每一个传感器需要矫正这里的2.15这个除数。 //当发现测试出来的重量偏大时,增加该数值。 //如果测试出来的重量偏小时,减小改数值。 //该数值一般在4.30附近调整之间。因传感器不同而定。 //+0.05是为了四舍五入百分位 if( Weight_Shiwu > 10000 ) { Buzzer = 0; //打开警报 LED=!LED; LCD12864_COM_Write(0x90); LCD12864_write_word("※※※超重※※※"); } else { if(Weight_Shiwu==0) LED=1; else if(Weight_Shiwu>0) LED=0; Buzzer = 1; //关闭警报 } } else if(HX711_Buffer < Weight_Maopi - 30) { Buzzer = 0; //负重量报警 } // Weight_Shiwu=Weight_Shiwu/2; } //**************************************************** //获取毛皮重量 //**************************************************** void Get_Maopi() { uchar i = 0; uint Temp_Weight = 0; Weight_Maopi = 0; for( i = 0 ; i < 10 ; i++) { HX711_Buffer = HX711_Read(); Temp_Weight = HX711_Buffer/100; if( Temp_Weight > Weight_Maopi) { Weight_Maopi = Temp_Weight; } } } //**************************************************** //MS延时函数(12M晶振下测试) //**************************************************** void Delay_ms(uint n) { unsigned int i,j; for(i=0;i }
6个回答
这就要用到各种算法啦~~~~
做个小的滤波,如何和上一次测量值相差2个,就不更新显示,
软件滤波,推荐参考一本书《匠人手记》里面有详细写各种滤波算法的实现,楼主如果有兴趣可以去买一本或者找个PDF看看。
滤波 加算法
AD几位的?
可以参考网络上的一阶滤波方法,做个动态调整 void DynamicFilter(FILTER_PARAMETER_STRU *Par) { float tmp=0.0; if(fabs((*Par).NewValue - (*Par).OldValue)>100.0) { (*Par).NewValue=(*Par).OldValue; return; } (*Par).Dir_Thre.bit0 = (*Par).Dir_Thre.bit1; (*Par).Dir_Thre.bit1 = 0; tmp = (*Par).NewValue - (*Par).OldValue; if(tmp >= 0)(*Par).Dir_Thre.bit1 = 1; if((*Par).Dir_Thre.bit0 == (*Par).Dir_Thre.bit1) //µÝÔö¼«ÐÔÏàͬ { (*Par).Fliter_Counter += 1; if(fabs(tmp) >= FITLER_VALUE_THRESHOLD)(*Par).Fliter_Counter += 2; if((*Par).Fliter_Counter >= FILTER_COUNTER_MAX) { (*Par).FilterScale += FILTER_SCALE_STEP; if((*Par).FilterScale >= FILTER_SCALE_MAX) (*Par).FilterScale = FILTER_SCALE_MAX; } } else { (*Par).Fliter_Counter = 0; (*Par).FilterScale = 0.005; } (*Par).NewValue = ((*Par).OldValue)*(1.0-((*Par).FilterScale)) + ((*Par).FilterScale)*((*Par).NewValue); (*Par).OldValue = (*Par).NewValue; } |
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-Linux C接口编程入门之ioctl操作
621 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十七章 machine.WDT类实验
483 浏览 0 评论
1110 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-通用文件I/O模型之close
1259 浏览 0 评论
《DNK210使用指南 -CanMV版 V1.0》第十五章 按键中断实验
1123 浏览 0 评论
11484 浏览 31 评论
GMT+8, 2024-10-19 00:33 , Processed in 0.780683 second(s), Total 82, Slave 63 queries .
