我想点亮一盏灯
#include #include typedef unsigned char uchar; typedef unsigned char uint; //****************************************IO端口定义*************************************** ***it MISO =P2^0; ***it MOSI =P2^3; ***it SCK =P2^2; ***it CE =P2^4; ***it CSN =P2^5; ***it IRQ =P2^1; //***it LS138A = P2^2; //定义138译码器的输入A脚由P2.2控制 //***it LS138B = P2^3; //定义138译码器的输入脚B由P2.3控制 //***it LS138C = P2^4; //定义138译码器的输入脚C由P2.4控制 //***********************************数码管0-9编码******************************************* char Disp_Tab[10]={0x0F,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9共阳段码 /*char code TxBuf[]= { 0x01,0x02,0x03,0x4,0x05,0x06,0x07,0x08, 0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16, 0x17,0x18,0x19,0x20}; */ //************************************按键********************************************** ***it KEY1=P1^0; ***it KEY2=P1^1; //***********************************数码管位选************************************************** //***it led1=P2^1; //***it led0=P2^0; //***it led2=P2^2; //***it led3=P2^3; //*********************************************NRF24L01************************************* #define TX_ADR_WIDTH 5 // 5 uints TX address width #define RX_ADR_WIDTH 5 // 5 uints RX address width #define TX_PLOAD_WIDTH 20 // 20 uints TX payload #define RX_PLOAD_WIDTH 20 // 20 uints TX payload uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址 uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址 //***************************************NRF24L01寄存器指令******************************************************* #define READ_REG 0x00 // 读寄存器指令 #define WRITE_REG 0x20 // 写寄存器指令 #define RD_RX_PLOAD 0x61 // 读取接收数据指令 #define WR_TX_PLOAD 0xA0 // 写待发数据指令 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令 #define NOP 0xFF // 保留 //*************************************SPI(nRF24L01)寄存器地址**************************************************** #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 Config' register address #define EN_AA 0x01 // 自动应答功能设置 #define EN_RXADDR 0x02 // 可用信道设置 #define SETUP_AW 0x03 // 收发地址宽度设置 #define SETUP_RETR 0x04 // 自动重发功能设置 #define RF_CH 0x05 // 工作频率设置 #define RF_SETUP 0x06 // 发射速率、功耗功能设置 #define STATUS 0x07 // 状态寄存器 #define OBSERVE_TX 0x08 // 发送监测功能 #define CD 0x09 // 地址检测 #define RX_ADDR_P0 0x0A // 频道0接收数据地址 'RX address pipe0' register address #define RX_ADDR_P1 0x0B // 频道1接收数据地址 #define RX_ADDR_P2 0x0C // 频道2接收数据地址 #define RX_ADDR_P3 0x0D // 频道3接收数据地址 #define RX_ADDR_P4 0x0E // 频道4接收数据地址 #define RX_ADDR_P5 0x0F // 频道5接收数据地址 #define TX_ADDR 0x10 // 发送地址寄存器 #define RX_PW_P0 0x11 // 接收频道0接收数据长度 'RX payload width, pipe0' register address #define RX_PW_P1 0x12 // 接收频道1接收数据长度 'RX payload width, pipe1' register address #define RX_PW_P2 0x13 // 接收频道2接收数据长度 'RX payload width, pipe2' register address #define RX_PW_P3 0x14 // 接收频道3接收数据长度 'RX payload width, pipe3' register address #define RX_PW_P4 0x15 // 接收频道4接收数据长度 'RX payload width, pipe4' register address #define RX_PW_P5 0x16 // 接收频道5接收数据长度 'RX payload width, pipe5' register address #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置 'FIFO Status Register' register address //************************************************************************************** void Delay(unsigned int s); void inerDelay_us(unsigned char n); void init_NRF24L01(void); uint SPI_RW(uint byte); uchar SPI_Read(uchar reg); void SetRX_Mode(void); uint SPI_RW_Reg(uchar reg, uchar value); uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars); uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars); unsigned char nRF24L01_RxPacket(unsigned char* rx_buf); void nRF24L01_TxPacket(unsigned char * tx_buf); /*void Display(unsigned LedNumVal) { unsigned int i,j; unsigned int LedOut[4]; //进入循环状态 LedOut[0]=Disp_Tab[0]; LedOut[1]=0x89; LedOut[2]=Disp_Tab[LedNumVal>>4]; LedOut[3]=Disp_Tab[LedNumVal&0x0f]; //LedOut[4]=Disp_Tab[0]; //千位 // LedOut[5]=Disp_Tab[0]; //百位带小数点 // LedOut[6]=Disp_Tab[0]; //十位 // LedOut[7]=Disp_Tab[0]; //个位 for(j=0;j<500;j++) { for( i=0; i<4; i++) //实现8位动态扫描循环 { switch(i) //使用switch 语句控制位选 也可以是用查表的方式 学员可以试着自己修改 { case 0:P2=0x01;break;//LS138A=0; LS138B=0; LS138C=0; break; case 1:P2=0x02;break;//LS138A=1; LS138B=0; LS138C=0; break; case 2:P2=0x04;break;//LS138A=0; LS138B=1; LS138C=0; break; case 3:P2=0x08;break;//LS138A=1; LS138B=1; LS138C=0; break; // case 4:P2=0x01;break;//LS138A=0; LS138B=0; LS138C=1; break; // case 5:P2=0x01;break;//LS138A=1; LS138B=0; LS138C=1; break; // case 6:P2=0x01;break;//LS138A=0; LS138B=1; LS138C=1; break; // case 7:P2=0x01;break;//LS138A=1; LS138B=1; LS138C=1; break; } P0 = LedOut[i]; //将字模送到P0口显示 Delay(120); P2=0x00; } } } */ //*****************************************长延时***************************************** void Delay(unsigned int s) { unsigned int i; for(i=0; i //****************************************************************************************** uint bdata sta; //状态标志 ***it RX_DR =sta^6; ***it TX_DS =sta^5; ***it MAX_RT =sta^4; /****************************************************************************************** /*延时函数 /******************************************************************************************/ void inerDelay_us(unsigned char n) { for(;n>0;n--) _nop_(); } //**************************************************************************************** /*NRF24L01初始化 //***************************************************************************************/ void init_NRF24L01(void) { inerDelay_us(100); CE=0; // chip enable CSN=1; // Spi disable SCK=0; // Spi clock line init high SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写本地地址 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 写接收端地址 SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 频道0自动 ACK应答允许 SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21 SPI_RW_Reg(WRITE_REG + RF_CH, 0); // 设置信道工作为2.4GHZ,收发必须一致 SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节 SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); //设置发射速率为2MHZ,发射功率为最大值0dB TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 } /**************************************************************************************************** /*函数:uint SPI_RW(uint uchar) /*功能:NRF24L01的SPI写时序 Writes one byte to nRF24L01, and return the byte read from nRF24L01 during write, according to SPI protocol 最基本的函数,完成GPIO 模拟SPI的功能。将输出字节(MOSI)从MSB 循环输出,同时将输入字节(MISO ) 从LSB 循环移入。上升沿读入,下降沿输出。(从SCK 被初始化为低电平可以判断出)。 /****************************************************************************************************/ uint SPI_RW(uint byte) { uint bit_ctr; for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit { MOSI = (byte & 0x80); // output 'byte', MSB to MOSI byte = (byte << 1); // shift next bit into MSB.. SCK = 1; // Set SCK high.. byte |= MISO; // capture current MISO bit SCK = 0; // ..then set SCK low again } return(byte); // return read byte } /**************************************************************************************************** /*函数:uchar SPI_Read(uchar reg) /*功能:NRF24L01的SPI时序。读取寄存器值的函数:基本思路就是通过READ_REG 命令(也就是0x00+寄存器地址), 把寄存器中的值读出来。对于函数来说也就是把reg 寄存器的值读到reg_val 中去。 /****************************************************************************************************/ uchar SPI_Read(uchar reg) { uchar reg_val; CSN = 0; // CSN low, initialize SPI communication... SPI_RW(reg); // Select register to read from.. reg_val = SPI_RW(0); // ..then read registervalue CSN = 1; // CSN high, terminate SPI communication return(reg_val); // return register value } /****************************************************************************************************/ /*功能:NRF24L01读写寄存器函数 寄存器访问函数:用来设置24L01 的寄存器的值。基本思路就是通过WRITE_REG 命令(也就是0x20+寄存器地址)把要 设定的值写到相应的寄存器地址里面去,并读取返回值。对于函数来说也就是把value 值写到reg 寄存器中。 需要注意的是,访问NRF24L01 之前首先要enable 芯片(CSN=0;),访问完了以后再disable芯片(CSN=1;)。 /****************************************************************************************************/ uint SPI_RW_Reg(uchar reg, uchar value) { uint status; CSN = 0; // CSN low, init SPI transaction status = SPI_RW(reg); // select register SPI_RW(value); // ..and write value to it.. CSN = 1; // CSN high again return(status); // return nRF24L01 status byte } /****************************************************************************************************/ /*函数:uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于读数据,reg:为寄存器地址,pBuf:为待读出数据地址,uchars:读出数据的个数 接收缓冲区访问函数:主要用来在接收时读取FIFO缓冲区中的值。基本思路就是通过READ_REG 命令把数据从接 收 FIFO(RD_RX_PLOAD)中读出并存到数组里面去。 /****************************************************************************************************/ uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status uchar for(uchar_ctr=0;uchar_ctr CSN = 1; // Set CSN high again return(status); // return nRF24L01 status uchar } /********************************************************************************************************* /*函数:uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) /*功能: 用于写数据:为寄存器地址,pBuf:为待写入数据地址,uchars:写入数据的个数 发射缓冲区访问函数:主要用来把数组里的数放到发射 FIFO 缓冲区中。基本思路就是通过WRITE_REG 命令把 数据存到发射 FIFO(WR_TX_PLOAD)中去。 /*********************************************************************************************************/ uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars) { uint status,uchar_ctr; CSN = 0; //SPI使能 // Set CSN low, init SPI tranaction status = SPI_RW(reg); // Select register to write to and read status byte for(uchar_ctr=0; uchar_ctr /* { Display(*pBuf);//显示程序 Delay(400) ; SPI_RW(*pBuf); Delay(2000) ; pBuf++; } */ CSN = 1; // // Set CSN high again ,关闭SPI return(status); // // return nRF24L01 status byte } /****************************************************************************************************/ /*函数:void SetRX_Mode(void) /*功能:数据接收配置 This function initializes one nRF24L01 device to RX Mode, set RX address, writes RX payload width, select RF channel, datarate & LNA HCURR. After init, CE is toggled high, which means that this device is now ready to receive a datapacket. /****************************************************************************************************/ void SetRX_Mode(void) { CE=0; SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收发完成中断响应,16位CRC ,主接收,???????接收没有 CE = 1; inerDelay_us(130); } /******************************************************************************************************/ /*函数:unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) /*功能:数据读取后放如rx_buf接收缓冲区中 /******************************************************************************************************/ unsigned char nRF24L01_RxPacket(unsigned char* rx_buf) //接收函数,返回1表示有数据收到,否则没有数据接受到 { unsigned char revale=0; sta=SPI_Read(STATUS); // 读取状态寄存其来判断数据接收状况 // read register STATUS's value if(RX_DR) // 判断是否接收到数据 // ifreceive data ready (RX_DR) interrupt { CE = 0; //SPI使能 SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer revale =1; //读取数据完成标志 } SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到数据后RX_DR,TX_DS,MAX_PT都置高为1,通过写1来清楚中断标志. //clear RX_DR or TX_DS or MAX_RT interrupt flag return revale; } /*********************************************************************************************************** /*函数:void nRF24L01_TxPacket(unsigned char * tx_buf) /*功能:发送 tx_buf中数据 /**********************************************************************************************************/ void nRF24L01_TxPacket(unsigned char * tx_buf) { CE=0; //StandBy I模式 SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 装载接收端地址 SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 装载数据// Writes data to TX payload SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断响应,16位CRC,主发送 ???????????发送中被屏蔽,而接收中没有屏蔽! // Set PWR_UP bit, enable CRC(2 bytes) & Prim:TX. MAX_RT & TX_DS enabled.. CE=1; //置高CE,激发数据发送 inerDelay_us(10); // CE=0; } //************************************主函数************************************************************ void main(void) { unsigned char tf=0; unsigned char TxBuf[20] ={0x00}; unsigned char RxBuf[20] ={0x00}; init_NRF24L01() ; while(1) { if(KEY1==1) { Delay(30); if(KEY1==1) { tf=1; TxBuf[1] = 1; while(KEY1==1) ; } } if(tf==1) { nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data // TxBuf[1] = 0x00; Delay(1000); tf=0; } SetRX_Mode(); if(nRF24L01_RxPacket(RxBuf)) { P0=Disp_Tab[RxBuf]; Delay(1000); } RxBuf[1]=0x00; } } |
1个回答
网上有例程,可以自己百度一下
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1498 浏览 1 评论
2345 浏览 1 评论
3906 浏览 2 评论
如何用DRG模式控制AD9910管脚可以输出如图所示的雷达脉冲信号
29602 浏览 0 评论
29410 浏览 1 评论
GMT+8, 2024-5-11 10:26 , Processed in 0.647655 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
