1个回答
头一次听说双极性控制我很吃惊,这电路怎么能控制电机,别人讲的头头是道,我搭了个电路实际测试,先上图,原理图,搭的电路,还有电机(N20带编码器)。
void TIM8_PWM_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7; //TIM8_1、TIM8_2的PWM输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //TIM8_1N的PWM输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //TIM8_2N的PWM输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); TIM_DeInit(TIM8); TIM_TimeBaseInitStructure.TIM_Prescaler=0; TIM_TimeBaseInitStructure.TIM_Period=5000-1; //14.4KHz TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1; TIM_TimeBaseInit(TIM8, &TIM_TimeBaseInitStructure); TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable; TIM_OCInitStructure.TIM_Pulse=0; TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_High; TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Reset; TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset; TIM_OC1Init(TIM8,&TIM_OCInitStructure); TIM_OC2Init(TIM8,&TIM_OCInitStructure); TIM_BDTRInitStructure.TIM_OSSRState=TIM_OSSRState_Enable; TIM_BDTRInitStructure.TIM_OSSIState=TIM_OSSIState_Enable; TIM_BDTRInitStructure.TIM_LOCKLevel=TIM_LOCKLevel_OFF; TIM_BDTRInitStructure.TIM_DeadTime=0x48; //13.89ns*72=1us TIM_BDTRInitStructure.TIM_Break=TIM_Break_Disable; //刹车功能 TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High; //刹车输入高电平有效 TIM_BDTRInitStructure.TIM_AutomaticOutput=TIM_AutomaticOutput_Enable; //自动输出使能 TIM_BDTRConfig(TIM8,&TIM_BDTRInitStructure); TIM_OC1PreloadConfig(TIM8,TIM_OCPreload_Enable); TIM_OC2PreloadConfig(TIM8,TIM_OCPreload_Enable); TIM_ARRPreloadConfig(TIM8,ENABLE); TIM_Cmd(TIM8,ENABLE); TIM_CCPreloadControl(TIM8,DISABLE); //ENABLE TIM_CtrlPWMOutputs(TIM8,ENABLE); } 测试结果如下: 1、PWM1固定50%占空比,PWM2小于50%反转,大于50%正转, 2、PWM2=100%,正转最大速度6310RPM,空载37.7mA,扭矩还行,堵转131mA, 3、PWM2=0,反转最大速度6550RPM,空载33.2mA, 4、PWM1=PWM2=50%,电机静止,电流24.2mA, 5、PWM2=2000,反转960RPM,空载电流36mA,扭矩非常小,堵转38.9mA, 6、占空比为0,电流为0。 7、PWM1=0, PWM2=1000,正转2350RPM,电流20.6mA PWM2=2000,正转5140RPM,电流28.6mA PWM2=3000,正转7830RPM,电流37.0mA PWM2=4000,正转10650RPM,电流45.4mA PWM2=5000,正转13500RPM,电流39.2mA,力矩最大,堵转0.44A。 双极性的最高速度达不到最高,输出力矩小,但是据说双极性电机反应快, 双极性适合低速,小扭矩,频繁启停的场合,比如平衡车, 底盘控制还是单极性效率更高, 互补PWM,可以通过把一路输出固定为0转换为单极性控制,其正反转性能一致,这样的实际意义就是可以用无刷电机的控制电路控制有刷电机。 |
只有小组成员才能发言,加入小组>>
2001 浏览 0 评论
7435 浏览 4 评论
34894 浏览 18 评论
4621 浏览 0 评论
22151 浏览 33 评论
563浏览 2评论
756浏览 1评论
833浏览 1评论
3468浏览 0评论
728浏览 0评论
GMT+8, 2024-5-9 10:43 , Processed in 0.897002 second(s), Total 49, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
