The compiler uses a set of virtual registers—located in data memory—to be used like any other registers. A minimum of 8 virtual registers are required by the compiler, but as many as 32 can be used. A larger set of virtual registers makes it possible for the compiler to allocate more variables into registers. However, a larger set of virtual registers also requires a larger data memory area. In the Large data model you should probably use a larger number of virtual registers, for example 32, to help the compiler generate better code. |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1903 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3660 浏览 4 评论
5038 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1739 浏览 1 评论
9403 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
679浏览 2评论
727浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
694浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1205浏览 1评论
1790浏览 1评论
GMT+8, 2024-5-4 13:02 , Processed in 0.507024 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
