CMD文件报错,请问能不能改变MEMERY[ ]里面的内存段的大小啊 。比如说我想将SHRAM o = 0x80000000 l = 0x00020000这个128k的内存段改大一点。有没有人遇到过类似的问题,怎么解决的。 |
6 个讨论
这是工程中原始的CMD文件中报的错 **** Build of configuration Debug for project test **** "D:\CCS7\ccsv7\utils\bin\gmake" -k -j 4 all -O 'Building target: test.out' 'Invoking: C6000 Linker' "D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/bin/cl6x" -mv6740 -g --define=c6748 --diag_wrap=off --display_error_number --diag_warning=225 -z -m"test.map" --stack_size=0x800 --heap_size=0x800 -i"D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/lib" -i"D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/include" --reread_libs --display_error_number --diag_wrap=off --warn_sections --xml_link_info="test_linkInfo.xml" --rom_model -o "test.out" "./EMIFAPinmuxSetup.obj" "./FFT.obj" "./FindN.obj" "./GetParameter.obj" "./GrLine.obj" "./fontcm40.obj" "./lcd.obj" "./main.obj" "../C6748.cmd" -llibc.a "../C6748.cmd", line 45: error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".far" size 0xc7432 . Available memory ranges: SHRAM size: 0x20000 unused: 0x16208 max hole: 0x16208 undefined first referenced symbol in file --------- ---------------- CacheEnable ./main.obj CacheEnableMAR ./main.obj CacheWB ./main.obj ConfigRasterDisplayEnable ./lcd.obj EMIFAAsyncDevDataBusWidthSelect ./main.obj EMIFAAsyncDevOpModeSelect ./main.obj EMIFAExtendedWaitConfig ./main.obj EMIFAWaitTimingConfig ./main.obj GPIODirModeSet ./lcd.obj GPIOPinRead ./main.obj GPIOPinWrite ./lcd.obj GrCircleDraw ./GrLine.obj GrCircleFill ./GrLine.obj GrContextInit ./lcd.obj GrLineDraw ./GrLine.obj >> Compilation failure makefile:148: recipe for target 'test.out' failed GrOffScreen16BPPInit ./lcd.obj GrRectDraw ./GrLine.obj GrRectFill ./GrLine.obj GrStringDraw ./GrLine.obj GrStringWidthGet ./main.obj IntDSPINTCInit ./main.obj IntEnable ./lcd.obj IntEventClear ./lcd.obj IntEventMap ./lcd.obj IntGlobalEnable ./main.obj IntRegister ./lcd.obj LCDPinMuxSetup ./lcd.obj PSCModuleControl ./lcd.obj RasterClearGetIntStatus ./lcd.obj RasterClkConfig ./lcd.obj RasterDMAConfig ./lcd.obj RasterDMAFBConfig ./lcd.obj RasterDisable ./lcd.obj RasterEnable ./lcd.obj RasterEndOfFrameIntEnable ./lcd.obj RasterFIFODMADelayConfig ./lcd.obj RasterHparamConfig ./lcd.obj RasterIntStatus ./lcd.obj RasterLSBDataOrderSelect ./lcd.obj RasterModeConfig ./lcd.obj RasterNibbleModeDisable ./lcd.obj RasterTiming2Configure ./lcd.obj RasterVparamConfig ./lcd.obj TimerConfigure ./main.obj TimerEnable ./main.obj TimerIntDisable ./main.obj TimerIntEnable ./main.obj TimerIntStatusClear ./main.obj TimerPeriodSet ./main.obj TouchDetect ./main.obj TouchInit ./main.obj g_sFontCm24 ./GrLine.obj touch_flag ./main.obj error #10234-D: unresolved symbols remain error #10010: errors encountered during linking; "test.out" not built gmake[1]: *** [test.out] Error 1 gmake: *** [all] Error 2 makefile:144: recipe for target 'all' failed **** Build Finished **** 将SHRAM改为DDR2后.far上面的×没了(编译通过了?),报了后来的错 **** Build of configuration Debug for project test **** "D:\CCS7\ccsv7\utils\bin\gmake" -k -j 4 all -O 'Building target: test.out' 'Invoking: C6000 Linker' "D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/bin/cl6x" -mv6740 -g --define=c6748 --diag_wrap=off --display_error_number --diag_warning=225 -z -m"test.map" --stack_size=0x800 --heap_size=0x800 -i"D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/lib" -i"D:/CCS7/ccsv7/tools/compiler/ti-cgt-c6000_8.1.4/include" --reread_libs --display_error_number --diag_wrap=off --warn_sections --xml_link_info="test_linkInfo.xml" --rom_model -o "test.out" "./EMIFAPinmuxSetup.obj" "./FFT.obj" "./FindN.obj" "./GetParameter.obj" "./GrLine.obj" "./fontcm40.obj" "./lcd.obj" "./main.obj" "../C6748.cmd" -llibc.a undefined first referenced symbol in file --------- ---------------- CacheEnable ./main.obj CacheEnableMAR ./main.obj CacheWB ./main.obj ConfigRasterDisplayEnable ./lcd.obj EMIFAAsyncDevDataBusWidthSelect ./main.obj EMIFAAsyncDevOpModeSelect ./main.obj EMIFAExtendedWaitConfig ./main.obj EMIFAWaitTimingConfig ./main.obj GPIODirModeSet ./lcd.obj GPIOPinRead ./main.obj GPIOPinWrite ./lcd.obj GrCircleDraw ./GrLine.obj GrCircleFill ./GrLine.obj GrContextInit ./lcd.obj GrLineDraw ./GrLine.obj GrOffScreen16BPPInit ./lcd.obj GrRectDraw ./GrLine.obj GrRectFill ./GrLine.obj GrStringDraw ./GrLine.obj GrStringWidthGet ./main.obj IntDSPINTCInit ./main.obj IntEnable ./lcd.obj >> Compilation failure makefile:148: recipe for target 'test.out' failed IntEventClear ./lcd.obj IntEventMap ./lcd.obj IntGlobalEnable ./main.obj IntRegister ./lcd.obj LCDPinMuxSetup ./lcd.obj PSCModuleControl ./lcd.obj RasterClearGetIntStatus ./lcd.obj RasterClkConfig ./lcd.obj RasterDMAConfig ./lcd.obj RasterDMAFBConfig ./lcd.obj RasterDisable ./lcd.obj RasterEnable ./lcd.obj RasterEndOfFrameIntEnable ./lcd.obj RasterFIFODMADelayConfig ./lcd.obj RasterHparamConfig ./lcd.obj RasterIntStatus ./lcd.obj RasterLSBDataOrderSelect ./lcd.obj RasterModeConfig ./lcd.obj RasterNibbleModeDisable ./lcd.obj RasterTiming2Configure ./lcd.obj RasterVparamConfig ./lcd.obj TimerConfigure ./main.obj TimerEnable ./main.obj TimerIntDisable ./main.obj TimerIntEnable ./main.obj TimerIntStatusClear ./main.obj TimerPeriodSet ./main.obj TouchDetect ./main.obj TouchInit ./main.obj g_sFontCm24 ./GrLine.obj touch_flag ./main.obj error #10234-D: unresolved symbols remain error #10010: errors encountered during linking; "test.out" not built gmake[1]: *** [test.out] Error 1 makefile:144: recipe for target 'all' failed gmake: *** [all] Error 2 **** Build Finished **** |
fqweerw 发表于 2020-8-4 07:22 不需要贴这么长的同一个error,这个error error #10234-D: unresolved symbols remain就是告诉用户这些函数没有找到。看看***子: http://processors.wiki.ti.com/index.php/Main_Page Think Over Before Asking. http://www.catb.org/~esr/faqs/smart-questions.html#goal |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3649 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9386 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
670浏览 2评论
717浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
678浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1200浏览 1评论
1779浏览 1评论
GMT+8, 2024-4-27 05:50 , Processed in 0.693736 second(s), Total 55, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
