以下是LCD显示所指向的地址,
#define FSMC_LCD_ADDRESS 0x64000002 当摄像头获取图片之后,通过DMA将数据传输至此处, GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOA, &GPIO_InitStructure); /* D5,DCMI_VSYNC(PB6/7) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOB, &GPIO_InitStructure); /* D0..D4(PC6/7/8/9/11) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOC, &GPIO_InitStructure); /* D6,D7(PE5/6) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ; GPIO_Init(GPIOE, &GPIO_InitStructure); /* DCMI configuration *******************************************************/ DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous; DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware; DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Rising; DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High; DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High; DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame; DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b; DCMI_Init(&DCMI_InitStructure); /* Configures the DMA2 to transfer Data from DCMI to the LCD ****************/ /* Enable DMA2 clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); /* DMA2 Stream1 Configuration */ DMA_DeInit(DMA2_Stream1); DMA_InitStructure.DMA_Channel = DMA_Channel_1; DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS; //此处是DMA的目的地址 DMA_InitStructure.DMA_Memory0BaseAddr = FSMC_LCD_ADDRESS; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; DMA_InitStructure.DMA_BufferSize = 1; //与串口数据大小一样 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址增模式关闭 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;//存储器地址增模式关闭 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;//摄像头数据寄存器大小为1个字 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//液晶显示屏数据大小为半个字 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//循环模式可传输连续的数据流 DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA2_Stream1, &DMA_InitStructure); 请问如何才能将存在给地址的图片的数据取出呢? 通过指针吗?该怎么写呢? |
5个回答
ALIENTEK MINISTM32 扩展实验13 内部FLASH图片显示实验_AN1103(告诉你如何用LCD显示image2lcd生成的图像数据)
呵呵,我自己摸索成功了,晚上花了一整晚
还不睡觉?
嗯嗯,晚上整理 了一下资料到空间分享了。晚安啊原子大哥
原子哥,这个事stm32f207,做项目需要摄像头,但是207的资料非常少,所以只能过来问问你啊~
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
706 浏览 0 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
461 浏览 1 评论
299 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
260 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
628 浏览 2 评论
1395浏览 9评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
90浏览 3评论
50浏览 3评论
STM32CUBEMX4.22.1在main函数里面添加一行语句就死机的原因?
59浏览 3评论
52浏览 3评论
GMT+8, 2024-5-8 10:05 , Processed in 0.985450 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
