你好先生,
我们在音频项目中使用了opamp ic LM358,用于放大从麦克风到微控制器的信号。 您能否验证所附电路,如果您有任何意见,请告诉我。 问候 JOM 以上来自于谷歌翻译 以下为原文 Hello Sir, We have used opamp ic LM358 in our audio project, which used for amplification of signal from mic to adc of microcontroller. Could you please verify the attached circuit, let me know if you have any comments. Regards Jom |
2个回答
你好,先生,
对于音频信号(10nF和1kOhm => 15.9kHz和1.5nF以及330欧姆=> 322kHz),截止频率太高。 如果你想保持增益不变,你应该将10nF和1.5nF电容分别增加到至少10uF和22uF。 最好的祝福, P 以上来自于谷歌翻译 以下为原文 Hi Sir, The cutoff frequencies are too high for audio signal (10nF and 1kOhm => 15.9kHz and 1.5nF and 330 Ohm => 322kHz). If you want to keep the gain unchanged, you should increase the 10nF and 1.5nF capacitors to respectively at least 10uF and 22uF. Best Regards, P |
这款双通道运算放大器利用四通道运算放大器完善的电路设计,具有低功耗,共模输入电压范围,可扩展至地/ VEE,以及单电源或分离电源供电。 LM358系列相当于LM324的一半。这些放大器与单电源应用中的标准运算放大器类型相比具有几个明显的优它们可以在低至3.0 V或高达32 V的电源电压下工作,静态电流约为MC1741的五分之一(基于每个放大器)。共模输入范围包括负电源,从而消除了许多应用中外部偏置元件的必要性。输出电压范围还包括负电源电压。的帮助
https://writeversity.com/ 帮助学生了解每篇自定义书面论文的基础知识,以及创意写作的要素。 以上来自于谷歌翻译 以下为原文 Utilizing the circuit designs perfected for quad op-amps, this dual op-amp features low power drain, a common mode input voltage range extending to ground/VEE, and single supply or split supply operation. The LM358 series is equivalent to one-half of an LM324. These amplifiers have several distinct advantages over standard operational amplifier types in single supply applications. They can operate at supply voltages as low as 3.0 V or as high as 32 V, with quiescent currents about one-fifth of those associated with the MC1741 (on a per amplifier basis). The common mode input range includes the negative supply, thereby eliminating the necessity for external biasing components in many applications. The output voltage range also includes the negative power supply voltage. The assistance of https://writeversity.com/ helps students understand the basics of every custom written paper, as well as the elements of creative writing. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1554 浏览 1 评论
2235 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1517 浏览 1 评论
2876 浏览 6 评论
5366 浏览 21 评论
386浏览 4评论
628浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
295浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
722浏览 3评论
591浏览 3评论
GMT+8, 2024-5-7 22:17 , Processed in 0.769999 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
