嗨,1。您能否建议一些合适的视频卡,可以在16902B主机内部另外安装,并支持2个外部DVI连接显示器?
你测试过吗? 我没有在安捷伦手册中找到任何建议,即使数据表中提到了这种可能性。 2.当我关闭一些安装在16902B内部的LA模块时,没有从框架上拆下来,那些供电的电源真的关闭了吗? 这是为了节省电力(并减少过热)而无需从主机上物理移除LA扩展板。 谢谢 以上来自于谷歌翻译 以下为原文 Hi, 1. Can you advice some suitable video card which could be installed additionally to inside 16902B mainframe and supports 2 external DVI - connected displays ? Did you test any ? I did not find any recommendations in Agilent manuals, even that possibility is mentioned in the datasheet. 2. When I switch-off some of LA modules installed to inside 16902B, not removing from the frame, does the Power supplied to those boards really switched-off ? That is to save the power (and reduce overheating) without physical removal of LA extension boards from mainframe. Thanks |
1个回答
> 1.您能否建议一些合适的视频卡,可以在16902B主机内部附加安装>并支持2个外部DVI连接显示器?
你测试过吗? 我没有在安捷伦手册中找到任何建议,即使数据表中提到了这种可能性。 我们没有具体的建议。 在多年前的16902A首次发布后不久,我看到了一个带有4个21英寸显示器的演示。 因为它只是一台PC,所以任何合适的卡都可以使用。 请确保您使用的是最新版本的LA SW,当前为5.10,并且已安装所有Microsoft补丁。 >> 2.当我关闭一些安装在16902B内部的LA模块时,没有从框架上拆下,>提供给这些板的电源真的关闭了吗? 这是为了节省功率(并减少>过热)而无需从主机上物理移除LA扩展板。 不,他们只在SW中被禁用。 您不应该遇到任何过热问题,任何组合的卡,只要: - 空插槽中有卡填充物 - 两侧都是透明的,可以接触到环境空气。 当彼此相邻设置2帧时,我看到过热,因此一方从另一帧获得暖空气。 人 以上来自于谷歌翻译 以下为原文 > 1. Can you advice some suitable video card which could be installed additionally to inside 16902B mainframe > and supports 2 external DVI - connected displays ? Did you test any ? I did not find any recommendations > in Agilent manuals, even that possibility is mentioned in the datasheet. We have no specific recommendations. Shortly after first release of the 16902A, years ago, I saw a demo with a 4 21 inch displays. Since it's "just" a PC, any card that fits should work. Please make sure that you are using the latest version of LA SW, currently 5.10, and all of your Microsoft patches are installed. > > 2. When I switch-off some of LA modules installed to inside 16902B, not removing from the frame, > does the Power supplied to those boards really switched-off ? That is to save the power (and reduce > overheating) without physical removal of LA extension boards from mainframe. No, they are only disabled in SW. You should not experience any overheating problems, with any combination of cards, as long as: - Empty slots have a card filler in them - Both sides are clear and have access to ambient air. I have seen overheating when 2 frames were set next to each other, so one was getting warm air from the other. Al |
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1871 浏览 1 评论
1726 浏览 5 评论
2595 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1569 浏览 4 评论
513浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
371浏览 0评论
1429浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
283浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-11 03:42 , Processed in 1.110883 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
