大家好,我是微控制器和微芯片的初学者。我试图在我的dsPIC33上编程一个延迟函数,以便等待一个以毫秒为单位的指定时间,以进行去绑定、验证时钟配置等。我遇到一个问题,我相信它与我的定时器寄存器或定义多少cl的整数变量的溢出有关。MyConfigureOscillator()函数应该创建25MIPS的Fcy。我的timer4配置有预缩放器256。因此,对于单个毫秒延迟,我需要等待:25000000/(256*1000)“counts”=1ms97.65Timer4“counts”=1msThe Timer4重新执行以获得X毫秒的等待,等待直到Timer4+Timer5达到97*X。我认为在我的比较变量声明中发生了一个问题:uint32_T.=(uint32_T)(97*.);在调试期间的变量屏幕中,这个比较变量包含0x0000000000,它告诉我它的32位宽。调用函数DelayMs(1000)时,比较变量包含十进制值31464。我认为这是溢出的,但我不知道为什么。此时,我正在考虑只拆卸一个简单的nop()或while循环,这对于确定时钟周期没有帮助,以便更容易地设置延迟函数。这是我到目前为止的代码:main.csystem.csystem.hMicrocontroller:dsPIC33EP256MC506开发板:MCLV-2程序员:真正的ICEC编译器:MPLAB X 3.45对此的任何建议或帮助都非常感谢!我正在与另一个新用户KPATEL0同时在BLDC控制项目上工作。
以上来自于百度翻译 以下为原文 Hello All, I am a beginner with microcontrollers and microchip. I am trying to program a delay function on my dsPIC33 to wait a specified time in milliseconds for debouncing, validating clock configuration, etc. I'm experiencing an issue which I believe to be associated with overflows with either my timer register or my integer variable which defines how many clock cycles to wait until a millisecond has passed. My ConfigureOscillator() function should be creating a Fcy of 25MIPS. My Timer4 is configured with a pre-scaler of 256. Therefore, for a single millisecond delay I need to wait: 25,000,000 / (256 * 1000) "counts" = 1 ms 97.65 "counts" of Timer4 = 1 ms Therefore to obtain a wait of X milliseconds, wait until Timer4 + Timer5 reaches 97 * X. I think an issue is occurring in my declaration of my compare variable: uint32_T compare = (uint32_T) (97 * delay); In the variables screen during debugging this compare variables contains 0x 0000 0000 to begin with, which tells me its 32 bits wide. Upon calling the function delayMS(1000); the compare variable contains decimal value 31464. I think this is overflowing but I do not know why. At this point I'm considering just disassembling a simple nop() or while loop that does nothing to determine the clock cycles for an easier way of setting up a delay function. Here is my code thus far: main.c const unsigned int PWM_STATE1_CLKW[6] = {0xC600,0xC700,0xC500,0xC500,0xC700,0xC600}; const unsigned int PWM_STATE2_CLKW[6] = {0xC700,0xC600,0xC600,0xC700,0xC500,0xC500}; const unsigned int PWM_STATE3_CLKW[6] = {0xC500,0xC500,0xC700,0xC600,0xC600,0xC700}; #include #include "system.h" #include "user.h" /****************************CONFIGURATION****************************/ void Delay_us(unsigned int); void Delay_ms(unsigned int); int ADCValue, i; /*=======================================================================* * Fixed width word size data types: * * int8_T, int16_T, int32_T - signed 8, 16, or 32 bit integers * * uint8_T, uint16_T, uint32_T - unsigned 8, 16, or 32 bit integers * * real32_T, real64_T - 32 and 64 bit floating point numbers * *=======================================================================*/ typedef signed char int8_T; typedef unsigned char uint8_T; typedef int int16_T; typedef unsigned int uint16_T; typedef long int32_T; typedef unsigned long uint32_T; typedef float real32_T; typedef double real64_T; int main(void) { ConfigureOscillator(); Init_Ports(); while(1) { LATDbits.LATD5 = 1; //make LED pin high Delay_ms(10); LATDbits.LATD5 = 0; //make LED pin low Delay_ms(1000); } } // DELAY UP TO 2600 MICROSECONDS void Delay_us(unsigned int delay) { TMR2 = 0; // Resetting timer 2 T2CONbits.TON = 1; // Start timer 2 while(TMR2 < (25 * delay)) nop(); T2CONbits.TON = 0; } void Delay_ms(unsigned int delay) { TMR4 = 0; TMR5HLD = 0; T4CONbits.TON = 1; // Start timer 4+5 uint32_T compare = (uint32_T) (97 * delay); uint32_T tmp; while((TMR5HLD | TMR4 << 16) < compare) tmp = (TMR5HLD | TMR4 << 16); nop(); T4CONbits.TON = 0; } /********************************************************************* Function: void __attribute__((interrupt, no_auto_psv)) _T1Interrupt (void) PreCondition: None. Overview: Half-second heartbeat monitor ********************************************************************/ void __attribute__((interrupt, no_auto_psv)) _T1Interrupt (void) { LATDbits.LATD6 = 1; //make LED pin high Delay_ms(10); LATDbits.LATD6 = 0; //make LED pin low IFS0bits.T1IF = 0; } system.c /******************************************************************************/ /* Files to Include */ /******************************************************************************/ /* Device header file */ #include #include #include #include "system.h" /* variables/params used by system.c */ /******************************************************************************/ /* System Level Functions */ /* */ /* Custom oscillator configuration funtions, reset source evaluation */ /* functions, and other non-peripheral microcontroller initialization */ /* functions get placed in system.c. */ /* */ /******************************************************************************/ /* Refer to the device Family Reference Manual Oscillator section for information about available oscillator configurations. Typically this would involve configuring the oscillator tuning register or clock switching using the compiler's __builtin_write_OSCCON functions. Refer to the C Compiler for PIC24 MCUs and dsPIC DSCs User Guide in the compiler installation directory /doc folder for documentation on the __builtin functions.*/ /* TODO Add clock switching code if appropriate. An example stub is below. */ void ConfigureOscillator(void) { // Fosc = 8 MHz * (M / (N1 * N2) // Fcy = Fosc / 2 // Fosc = 50,000,000 Hz // Fcy = 25,000,000 Hz PLLFBD = 0x0030; /* M = 50 default */ CLKDIVbits.PLLPOST = 1; /* N1 = 2 default */ CLKDIVbits.PLLPRE = 0; /* N2 = 4 default */ OSCTUN = 0; // FRC OSCILLATOR TUNING REGISTER // Center frequency (7.37 MHz nominal) /* Initiate Clock Switch to Primary Oscillator with PLL (NOSC = 0x3) */ __builtin_write_OSCCONH(0x03); __builtin_write_OSCCONL(0x01); while (OSCCONbits.COSC != 0x3); while (_LOCK == 0); /* Wait for PLL lock */ } void Init_Ports(void) { //Timers initialization //Timer 1 TMR1 = 0; // Resetting timer 1 PR1 = (FCY / (256 * 2));// overflows at a rate of 2 Hz T1CON = 0x8030; // internal Tcy*256 //Timer 4&5 T4CON = 0x0038; //32 bit timer, pre-scaler of 256 TMR4 = 0; // LSB T4CONbits.TSIDL = 0; // allow counter to increment while idle TMR5HLD = 0; // MSB //IPC0bits.T1IP = 5; // Set Timer 1 Interrupt Priority Level IFS0bits.T1IF = 0; // Clear Timer 1 Interrupt Flag IEC0bits.T1IE = 1; // Enable Timer1 interrupt } void nop(void) { __asm__ volatile ("nop"); } system.h /******************************************************************************/ /* System Level #define Macros */ /******************************************************************************/ #include #include "p33EP256MC506.h" /* TODO Define system operating frequency */ /* Microcontroller MIPs (FCY) */ #define SYS_FREQ 50000000L #define FCY SYS_FREQ/2 /******************************************************************************/ /* System Function Prototypes */ /******************************************************************************/ /* Custom oscillator configuration funtions, reset source evaluation functions, and other non-peripheral microcontroller initialization functions go here. */ void ConfigureOscillator(void); /* Handles clock switching/osc initialization */ void Init_Ports(void); void nop(void); Microcontroller: dsPIC33EP256MC506 Dev Board: MCLV -2 Programmer: REAL ICE Compiler: MPLAB X 3.45 Any advice or assistance with this is greatly appreciated! FYI I'm working concurrently on a BLDC control project with another new user, kpatel0. |
9个回答
转换到
以上来自于百度翻译 以下为原文 Change uint32_T compare = (uint32_T) (97 * delay); to uint32_T compare = 97 * (uint32_T)delay; |
修改,比较:正确地允许比较保持值97000十进制。但是,现在的问题是,tmp没有正确地保存TMR4和TMR5HLD的值。我拍了一张屏幕截图给你们看我在看什么,但是很明显我的访问被拒绝上传……Access Denied你们没有权限访问“http://www..hip.com/for./upload.aspx?”参考文献#18.6f5ffea5.1478628121.2e9710(文件大小小于200kB)所以我将告诉你寄存器的值。tmp=33226小数=0x000081CATMR5HLD=130小数TMR4=33226小数。作为tmp的两个LSBytes的p和TMR4不能正常工作。tmp=(TMR5HLD|TMR4<<16);//将TMR5HLD值附加到MSBytes以及将TMR4附加到LSBytes有什么想法吗?
以上来自于百度翻译 以下为原文 Well, modifying compare to: uint32_T compare = 97UL * delay; Correctly allows compare to hold the value 97000 decimal. However, now the issue is that tmp is not correctly holding the values of both TMR4 and TMR5HLD. I took a screenshot to show you guys what I'm seeing, but apparently my access is denied to upload... Access Denied You don't have permission to access "http://www.microchip.com/forums/upload.aspx?" on this server. Reference #18.6f5ffea5.1478628121.2e9710 (The file size is less than 200kB) So instead, I'll tell you the values of the registers. tmp = 33226 decimal = 0x 000081CA TMR5HLD = 130 decimal TMR4 = 33226 decimal So I think my append code (that attempts to set TMR5HLD as the MSB two bytes of tmp and TMR4 as two LSBytes of tmp) is not working correctly. tmp = (TMR5HLD | TMR4 << 16); // Append TMR5HLD value to the MSBytes and TMR4 to the LSBytes Any ideas? |
您似乎没有想到C使用操作数的类型而不是目的地的类型进行计算。
以上来自于百度翻译 以下为原文 tmp = (TMR5HLD | (uint32_T)TMR4 << 16); // Append TMR5HLD value to the MSBytes and TMR4 to the LSBytes You don't seem to have got the concept that C does calculations using the type of the operands, not the type of the destination. |
必须首先读取TMR4,以便将TMR5的内容加载到其保持寄存器TMR5HLD中,TMR5HLD是32位定时器值的上位字。TMR4是上个字。试试这个:
以上来自于百度翻译 以下为原文 TMR4 must be read first in order to load the contents of TMR5 into its holding register TMR5HLD, which is the upper word of the 32-bit timer value. TMR4 is _not_ the upper word. Try this: tmp = TMR4; tmp |= (uint32_T) TMR5HLD << 16; |
…而且你还纠正了16位值的位置。我没有注意到代码和注释不匹配。
以上来自于百度翻译 以下为原文 ... and you also corrected where the 16 bit values were placed. I didn't notice the code didn't match the comment. |
uint16.;...uint32_T.=97*.;//97*delay是16位*16位值,使用16位mathuint32_T.=97UL*.;//97*delay是32位*16位值,使用32位mathuint32_T.=97*(uint32_T).;//97*delay是16位*32位值,使用3位value.2位数学
以上来自于百度翻译 以下为原文 uint16 delay; ... uint32_T compare = 97 * delay; // 97 * delay is a 16 bit * a 16 bit value done using 16 bit math uint32_T compare = 97UL * delay; // 97 * delay is a 32 bit * a 16 bit value done using 32 bit math uint32_T compare = 97 * (uint32_T)delay; // 97 * delay is a 16 bit * a 32 bit value done using 32 bit math |
谢谢大家的反馈。我终于得到了延迟功能正确工作。这里是函数的最后代码:谢谢教我关于C操作数的计算。直到提到这件事,我才意识到这一点。现在我可以用我的应用程序前进!乔格林
以上来自于百度翻译 以下为原文 Thanks for all the feedback guys. I've finally gotten the delay function to work correctly. Here is the final code for the function: // [TMR5][TMR4] holds up to 2147483648 decimal // max value for compare = 214783648 / 97 // DELAY UP TO 22139006 ms void Delay_ms(unsigned int delay) { TMR5HLD = 0; // Reset timer values TMR4 = 0; T4CONbits.TON = 1; // Start 32 bit timer uint32_T timer_4_ticks = 97UL * delay; // Calculate clock ticks to wait uint32_T tmp = 0; while(tmp < timer_4_ticks) { tmp = TMR4; tmp |= (uint32_T) TMR5 << 16; } T4CONbits.TON = 0; } Thanks for teaching me about C operand calculations. I did not realize this until it was mentioned. Now I can move forward with my application! jgolen |
我建议在读取计时器时使用TMR5HLD代替TMR5。见邮报第6号。
以上来自于百度翻译 以下为原文 I would suggest using TMR5HLD instead of TMR5 when reading the timer. See post #6. |
只有小组成员才能发言,加入小组>>
4847 浏览 9 评论
1846 浏览 8 评论
1763 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2973 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2075 浏览 5 评论
472浏览 1评论
1123浏览 1评论
314浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
376浏览 0评论
270浏览 0评论
GMT+8, 2024-5-14 23:20 , Processed in 1.237762 second(s), Total 95, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
