我在流FIFO模式下配置了LIS3DH。然后我将WATERMARK级别设置为8个字节,并且我轮询FIFO_SRC_REG以查看WTM位是否为1,然后我收集FIFO中累积的8个字节的数据。现在我的问题是,在代码中,出于调试目的,我显示了我收集的数据,这减少了我在程序运行n秒时读取的数据点数。也就是说,当我运行代码而不显示相同的n秒时,几乎是正在读取的数据点的两倍。为什么是这样 ?
在程序中,我也检查FIFO_SRC_REG中的溢出标志。但它在代码运行期间从未设置过。所以我不应该在阅读和打印时丢失任何数据。 我的问题: 1.溢出标志是否在Stream模式下不起作用?即当新数据被覆盖时,它是否会保持高位? 2.当从中读取数据时,FIFO是否停止接受数据? #lis3dh-fifo#lis3dh#lis3dh-spi 以上来自于谷歌翻译 以下为原文 I configured the LIS3DH in stream FIFO mode. Then I set the WATERMARK level as 8 bytes and I poll the FIFO_SRC_REG to see if the WTM bit is 1 and then I collect the 8 bytes of data accumulated in FIFO. Now my problem is, in the code, for debug purposes, I display the data I collected and this reduces the number of data points I read when the program is run for n seconds. That is, when I run the code without displaying for the same n seconds, almost double the amount of data points is being read. Why is this ? In the program I check the overrun flag in FIFO_SRC_REG too. But it is never set during the run of the code. So I should not be losing any data while reading and printing it. My questions : 1. Does the overrun flag not work in Stream mode ? i.e when new data is overwritten does it not stay high ? 2. Does the FIFO stops accepting data when data is being read from it ? #lis3dh-fifo #lis3dh #lis3dh-spi |
1个回答
2.当从中读取数据时,FIFO是否停止接受数据? 有关详细信息,请查看应用说明中的第8.3章 http://www.st.com/resource/en/application_note/cd00290365.pdf 。 以上来自于谷歌翻译 以下为原文 1. Does the overrun flag not work in Stream mode ? i.e when new data is overwritten does it not stay high ? 2. Does the FIFO stops accepting data when data is being read from it ? For details please check chapter 8.3 in the application note http://www.st.com/resource/en/application_note/cd00290365.pdf . |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1468 浏览 1 评论
2137 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1511 浏览 1 评论
2833 浏览 6 评论
5263 浏览 21 评论
364浏览 4评论
553浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
279浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
628浏览 3评论
525浏览 3评论
GMT+8, 2024-4-26 19:35 , Processed in 0.782639 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
