扫一扫,分享给好友
大家好,我有一个labview程序可以打开1680A逻辑分析仪上已经生成的两个文件中的一个,具体取决于你在VI前面板上输入的文件。
我有一个完全正常工作的设置(逻辑分析仪的型号相同,但是比我现在使用的旧计算机),当我尝试在具有相同设置的另一台计算机上使用工作可执行文件时(就设备而言) ,它看起来好像甚至没有与逻辑分析仪通信。 我有一些技术人员下来,因为最初它被认为是一个文件共享的东西,但那已经整理好了,我们看到逻辑分析器和计算机确实来回沟通。 我正在使用带有网络接口卡和交叉电缆的计算机,因此我可以通过我们的工作组将逻辑分析仪连接到计算机。 我尝试将逻辑分析仪与其他设置配合使用,以确保它不仅仅是逻辑分析仪,而且完美运行。 另一台计算机是Windows XP,我正在尝试运行它但没有运气的是Windows 7.两种设置(就设备而言)都完全相同,一台只是一台较新的计算机 没有LabVIEW,这就是需要可执行文件的原因。 那么为什么我的VI不打开其中一个文件? 是一台计算机是XP而另一台是Windows 7? 或者是否需要更改逻辑分析仪上的某些设置才能使其正常工作? 感谢您的帮助。 以上来自于谷歌翻译 以下为原文 Hello all, I have a LabVIEW program that opens up one of two files that are already made on the 1680A Logic Analyzer depending on what file you type in on the front panel of the VI. I've got one setup working completely (same model of Logic Analyzer, but older computer than what I'm using now), and when I tried to use a working executable on another computer with the same setup (as far as equipment goes), it does not look as if it is even communicating with the Logic Analyzer. I had some tech guys come down because originally it was thought to be a file sharing thing, but that was sorted out, and we saw that the Logic Analyzer and the computer were indeed communicating back and forth. I am using a computer with a Network Interface Card and a crossover cable so I can hook up the Logic Analyzer to the computer over our workgroup. I tried using the Logic Analyzer with the other setup to make sure it wasn't just the Logic Analyzer, and it worked perfectly. The other computer is a Windows XP, and the one I'm currently trying to run it on but with no luck is Windows 7. Both setups (as far as equipment goes) are exactly the same, one is just a newer computer that doesn't have LabVIEW, which is why the executable is needed. So why won't my VI open one of the files? Is it something to do with one computer being XP and the other being Windows 7? Or does some setting on the Logic Analyzer need to be changed in order for this to work? Thanks for your help in advance. |
1个回答
只有小组成员才能发言,加入小组>>
2111 浏览 1 评论
1873 浏览 1 评论
1727 浏览 5 评论
2599 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1571 浏览 4 评论
519浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
374浏览 0评论
1434浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2267浏览 0评论
GMT+8, 2024-5-14 22:31 , Processed in 1.075961 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
