以为我会分享如何在Windows Vista / 7 64位上安装VEE 8.5或9。
VEE 8.5 / 9.0仍然可以作为32位应用程序运行但是没关系。这些是我的观察结果,并不一定得到安捷伦的支持。[list = 1:3mo9gbnl]步骤1:安装IO Libraries Suite 15.5.13009.1(10月14日发布) ,2009年下午4点(MST),网址为http://www.agilent.com/find/iosuite。 此版本本身支持64位Vista和7.步骤2:如果在Windows 7上运行,请右键单击setup.exe和“Agilent VEE Pro.msi”,转到“属性”,转到“数据库”选项卡,选择在Compatability中运行 Vista的模式(如果您使用的是VEE运行时,您可能需要使用解压缩程序,例如免费的7-zip,解压缩自解压.exe并更改所包含的.msi文件的兼容模式)步骤3 :启动VEE安装程序,如果它告诉您安装.NET,请执行该Alan CopelandAgilent Technologies,Inc.IO库支持--- 2009年10月22日更新,以包含修复安装过程中的错误的15.5.13009.1版本(32- 64位系统上缺少位注册表项) 以上来自于谷歌翻译 以下为原文 Thought I would share how to install VEE 8.5 or 9 on Windows Vista/7 64-bit. VEE 8.5 / 9.0 will still run as a 32-bit app but that is ok. These are my observations and are not necessarily supported by Agilent. [list=1:3mo9gbnl]Step 1: Install IO Libraries Suite 15.5.13009.1 (released 14October, 2009 at 4:00 PM MST) from http://www.agilent.com/find/iosuite. This version natively supports 64-bit Vista and 7. Step 2: If running on Windows 7, right-click the setup.exe and "Agilent VEE Pro.msi", go to Properties, go to Compatabilities tab, choose to run in Compatability mode of Vista (if you are using VEE runtime, you may need to use an unzip program, such as the free 7-zip, to unzip the self-extracting .exe and change the Compatibility mode on the included .msi file) Step 3: Start the VEE installer, if it tells you to install .NET, do that Alan Copeland Agilent Technologies, Inc. IO Libraries Support ---Updated 22October 2009 to include the release of 15.5.13009.1 which fixed a bug in the install process (32-bit registry entries were missing on 64-bit systems) |
1个回答
这也适用于Windows 7上的VEE运行时吗?
在步骤3中,如何将“VEE Run-time.msi”设置为兼容模式。 VEE运行时仅作为(?)提供,作为自解压setup.exe文件。 以上来自于谷歌翻译 以下为原文 Will this also work for VEE Run-time on Windows 7? In Step 3, how to set "VEE Run-time.msi" to compatibility mode. VEE run-time is only (?) available as a self-extracting setup.exe file. |
只有小组成员才能发言,加入小组>>
2100 浏览 1 评论
1856 浏览 1 评论
1714 浏览 5 评论
2582 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
504浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1412浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
273浏览 0评论
2259浏览 0评论
GMT+8, 2024-4-27 05:15 , Processed in 1.051115 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
