扫一扫,分享给好友
你好,
我有一个SPC560D MCU项目,它没有任何警告和错误。在一台计算机上,我使用SPC5Studio的节点锁定许可证版本和另一台机器(在实验室),我正在使用免费试用许可证。 SPC5Studio的节点锁定版本已更新至v3.7.x,而免费试用版本为v3.5.x.请查找两个版本附带的安装详细信息。当我在这两台机器上构建相同的项目(没有任何更改)时,我看到节点锁定机器生成的二进制文件的错误行为。我尝试比较两个版本生成的地图文件,这两个是匹配的。有没有人观察到这种行为?是什么原因? ST团队,您能否请尽快回复? 谢谢。 麦克风 以上来自于谷歌翻译 以下为原文 Hello, I have a project for SPC560D MCU which builds without any warnings and errors. On one computer, I am using a node locked license version of SPC5Studio and on another machine (which is at Lab), I am using free trial license. The node locked version of SPC5Studio is updated to v3.7.x while the free trial version is v3.5.x. Please find installation details attached for both the versions. When I build the same project (without any change) on these two machines, I am seeing erroneous behavior for the binary generated by the node locked machine. I tried comparing the map files generated by both builds and these two are matching. Has anyone observed such behavior? What is the reason? ST team, can you please respond to this ASAP? Thanks. Mike |
2个回答
有没有人经历过这种行为?
我看到生成的映射文件,并观察到变量和函数调用分配在RAM级别非常复杂。我看到很少有变量按顺序分配,并且在RAM空间之间分配给一个函数及其变量。这种行为是否正确?这是怎么处理的? 提前致谢。 麦克风 以上来自于谷歌翻译 以下为原文 Has anyone experienced such behavior? I am seeing the generated map file and observed that the variables and function call assignment is quite mixed one at RAM level. I am seeing few variables assigned in sequence and in between the RAM space is assigned to a function and its variables. Is this behavior correct? How is this handled? Thanks in advance. Mike |
你好迈克,
如果你从3.5.X到3.7.X的ppc-vle-gcc(Hightec编译器),它是相同的版本。 也许你的差异与3.5.0和3.7.0之间的SPC5-HAL“差异”有关 https://sourceforge.net/p/spc5-hal/code/HEAD/tree/tags/3.5.0 https://sourceforge.net/p/spc5-hal/code/HEAD/tree/tags/3.7.0 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Mike , if you ppc-vle-gcc (Hightec compiler) from 3.5.X to 3.7.X , it is the same version. Maybe your difference is linked to SPC5-HAL ''difference'' between 3.5.0 and 3.7.0 https://sourceforge.net/p/spc5-hal/code/HEAD/tree/tags/3.5.0 https://sourceforge.net/p/spc5-hal/code/HEAD/tree/tags/3.7.0 Best regards Erwan |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1463 浏览 1 评论
2131 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2830 浏览 6 评论
5257 浏览 21 评论
364浏览 4评论
550浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
279浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
622浏览 3评论
521浏览 3评论
GMT+8, 2024-4-26 08:55 , Processed in 0.787068 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
