我想在python 3中安装pyntcloud
windows10英特尔®实感 以上来自于谷歌翻译 以下为原文 i want to install pyntcloud in python 3 windows10 Intel® RealSense |
7个回答
对于那些希望为这个案例提供帮助的人来说,这是关于如何安装Pyntcloud的关于上一个问题的延续。
从下面的链接向下阅读。 Re:如何生成pointcloud并在python中绘制它 您好guantong,您是否仍然遇到与之前尝试安装Pyntcloud时相同的错误? 以上来自于谷歌翻译 以下为原文 For people who wish to contribute help to this case, it is a continuation of a previous question by guantong about how to install Pyntcloud. Read downward from the link below. Re: how to generate pointclouds and draw it in python Hi guantong, are you still getting the same errors as you did before when you try to install Pyntcloud? |
nywerwer 发表于 2018-11-28 09:42 谢谢,我安装git并再次尝试,因为你告诉我并成功安装: 在cmd:pip install git + https://github.com/daewoo/pyntcloud 两天前,我做了同样的步骤但失败了。 谢谢 以上来自于谷歌翻译 以下为原文 thank you ,i install git and tried again as you tell me and installed succefully: in cmd:pip install git+https://github.com/daavoo/pyntcloud two days ago ,i do the same steps but failed. thank you |
qwe048 发表于 2018-11-28 09:48 有时安装失败,然后在以后再次尝试时它会起作用。 所以Pyntcloud现在为你工作,拜托? 以上来自于谷歌翻译 以下为原文 Sometimes an installation fails, and then it works when trying again at a later date. So Pyntcloud is working for you now, please? |
nywerwer 发表于 2018-11-28 09:42 我有另一个问题: ImportError:无法导入名称'PyntCloud' 以上来自于谷歌翻译 以下为原文 i have another question: ImportError: cannot import name 'PyntCloud' |
我对你的问题的研究表明,Python的ImportError问题似乎很难解决。 一个建议是将'python -m'放在pip install指令的开头,以确保将库安装到计算机上的默认Python版本中,而不是另一个Python解释器。 所以Pyntcloud安装指令看起来像这样: python -m pip install git + https://github.com/daavoo/pyntcloud 以上来自于谷歌翻译 以下为原文 My research into your question suggests that ImportError problems with Python seem to be difficult to solve. One suggestion is to put 'python -m' at the start of the pip install instruction to make sure that the library is installed into the default version of Python on your computer, and not another Python interpreter. So the Pyntcloud install instruction would look like this: python -m pip install git+https://github.com/daavoo/pyntcloud |
nywerwer 发表于 2018-11-28 10:24 仍然不起作用...... 我正在使用anaconda 以上来自于谷歌翻译 以下为原文 still does not work... i am using anaconda |
日志的底线表明Pyntcloud已经成功构建。 我不确定之后的下一步是什么。 Pyntcloud的创建者回复的帖子(链接到下面)似乎暗示一旦安装完成,你应该去Pyntcloud存储库的根位置并使用 python setup.py安装 安装指南·问题#171·daavoo / pyntcloud·GitHub 如果这对您不起作用,我建议在GitHub上重新打开该链接的讨论,并为创建者Daavoo留下评论。 以上来自于谷歌翻译 以下为原文 The bottom line of the log says that Pyntcloud has been successfully built. I am not sure what the next step after that is though. A post (linked to below) in which the creator of Pyntcloud replies seems to suggest that once installation is complete, you should go to the root location of the Pyntcloud repository and use python setup.py install Installation guidelances · Issue #171 · daavoo/pyntcloud · GitHub If that does not work for you, I recommend re-opening that linked discussion on GitHub and leaving a comment for the creator, Daavoo. |
只有小组成员才能发言,加入小组>>
255浏览 0评论
GMT+8, 2024-4-27 06:21 , Processed in 0.661921 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
