你好,我正在制作一个带有PIC32 MM000 64 GPM036I/M2的板,这是一个带有暴露垫的QFN36封装。我找不到任何数据表上的连接到裸露焊盘的参考。显而易见的解决办法是把它接地。但我觉得奇怪的是它没有被指定。所以我想问题是,我应该把它连接到GND还是让它浮动?瑞格斯,丹尼尔
以上来自于百度翻译 以下为原文 Hello there, I'm making a board with the PIC32MM0064GPM036-I/M2, this is a QFN36 package with exposed pad. I can't find any reference on the datasheet to the connection of the exposed pad. The obvious solution is to connect it to ground. But I just find it odd that it's not specified. So I guess the question is; should I connect it to GND or leave it floating? Regads, Daniel |
10个回答
我想知道您的欧姆表是否可以用来确定暴露的焊盘是否连接到接地引脚。
以上来自于百度翻译 以下为原文 I wonder if your ohm meter might be used to determine if the exposed pad is connected to a ground pin ? |
这是个好主意,可悲的是我手边没有设备的样品。我对缺乏答复感到困惑。它是太愚蠢的问题,所以人们忽视它,或者它真的是如此神秘,如果EP连接到地面或没有?
以上来自于百度翻译 以下为原文 That's a good idea, sadly I don't have samples of the device at hand. I'm further puzzled by the lack of replies. Is it too dumb of a question so people ignore it, or is it really so mysterious if the EP is connected to ground or not? |
一个旧的帖子SysHtpt//www. McCHIPC.COM/FUMMS/FUNDPOST/41776.
以上来自于百度翻译 以下为原文 An old post says http://www.microchip.com/forums/FindPost/417746 |
我发现与PIC32 MZ2064 DAG176芯片相同的问题,建议是欧姆出来。结果,暴露的焊盘连接到GND。因此,获得免费样品,并按照吉姆的建议。
以上来自于百度翻译 以下为原文 I found the same problem with the PIC32MZ2064DAG176 chip, and the suggestion was to ohm it out. It turns out the exposed pad is connected to GND. Thus, get the free samples and follow Jim's advice. |
Q20N和DFN Packagehttp的AN2089A封装应用说明:
以上来自于百度翻译 以下为原文 AN2089 Package Application Note for QFN and DFN Package http://ww1.microchip.com/...appnotes/00002089a.pdf |
谢谢你的回复。从这里我收集的和链接的文章,似乎垫不是电连接到模具,但可以连接到GND散热。我会那样做。
以上来自于百度翻译 以下为原文 Thanks for the replies. From what I gather here and the linked articles, it seems the pad is not electrically connect to the die but can be connected to GND for heat dissipation. I will do that. |
我建议联系微芯片支持/ FAE确定的答案。
以上来自于百度翻译 以下为原文 I would suggest contacting Microchip Support / FAE for a definitive answer |
你说得对,我会的。我认为如果EP是电连接的,他们没有在数据表中声明,那将是非常可怕的。但这只是一个假设。就像我认为晶体振荡器在PIC32 MZ线工作一样,愚蠢的我。
以上来自于百度翻译 以下为原文 You are right, I will do that. I just think that it would be quite terrible if the EP was electrically connected and they didn't state it in the datasheet. But it's just an assumption. Like when I thought crystal oscillators worked in the PIC32MZ line, silly me. |
再次问好,我从Microchip的支持得到了答复,所以我张贴在这里为未来读者。您好,我正在制作一个板与PIC32 MM000 64 GPM036 I/m2,这是一个QFN36封装与暴露垫。我找不到任何数据表上的连接到裸露焊盘的参考。如果EP是浮动的,我能把它连接到地上,还是必须把它接地?RegardsHi Daniel,您可以将暴露的焊盘连接到地上,或者在数据表中没有指定的情况下将其保持浮动。QFN封装中的裸露焊盘用于增加封装的最大功耗。在大多数应用中,暴露的焊盘与接地连接。德雷斯
以上来自于百度翻译 以下为原文 Hello again, I got a reply from Microchip's support so I'm posting it here for future readers. Hello there, Hi Daniel, |
只有小组成员才能发言,加入小组>>
4825 浏览 9 评论
1831 浏览 8 评论
1749 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2957 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2061 浏览 5 评论
462浏览 1评论
1111浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
364浏览 0评论
264浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1800浏览 0评论
GMT+8, 2024-4-27 03:56 , Processed in 0.972298 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
