你好,我刚刚收到一些BM62蓝牙模块,我已经把它们放在我的PCB设计上了。根据DeVKIT手册上描述的步骤,我已经做了以下步骤:用DSP参数使用DSPoToLo.IS206XY012YDALALMODLISK1.1V1.06EXE生成.txt文件,生成.txt文件TH-UITOOLYIS206XY012Y1.DualMODISK1.1.V1.03.EXE与IC包= BM62 -使用MPET.EXE文件合并使用默认的bin文件IS206XY0012DualMODLISK1.1YE0.0.2Y0FCD.BIN & GT;然后我生成一个IPF文件,在BM62 EEPROSPION EEPROMYORKTooVo.V851.EXE上写入MPSE名称:IS2064 SY012YSPK02YV2.1BETAI试图写EEPROM,但我有以下错误:“设备的IC版本不匹配文件的IC版本:IS206XY012YDALALMODISK1.1.1E1.0”“当我与DeVKIT做相同的步骤时,它工作得很好,EEPROM工具给了我MPSE名称=IS206XY01212DualMosik1.1.1E1.0两者。模块是BM62,所以我真的不理解MPSE NAMECCAN的含义有人帮助这个错误吗?谢谢你的帮助
以上来自于百度翻译 以下为原文 Hi Gents, I've just received some BM62 bluetooth module, I've mouted them on my PCB design. According to the steps described on the DevKit manual I've done the following steps : - Generate the .txt file with the DSP parameters using DSPTool_IS206x_012_DualModeSPK1.1_v1.06.exe - Generate the .txt file with UITool_IS206x_012_DualModeSPK1.1_v1.03.exe with IC package=BM62 - Merge the files using MPET.exe using the default bin file IS206X_012_DUALMODESPK1.1_E1.0.0.2_0FCD.bin -> then I generate an Ipf file to write on BM62 EEPROM Using EEPROM_Tool_V4851.exe I've got MPSE Name : IS2064S_012_SPK02_V2.1_BETA I'm trying to write on the EEPROM but i've got the following error : ''Device's IC version doesn't match file's IC Version: IS206X_012_DUALMODESPK1.1_E1.0"" When I'm doing the same steps with the DevKit it is working fine, the EEPROM tool is giving me MPSE name = IS206X_012_DUALLMODESPK1.1_E1.0 both module are BM62 so I'm not really understanding the meaning of the MPSE Name Can anyone help with this error? Thanks for your help Regards Bruno |
1个回答
对于那些喜欢我的人需要一段时间才能找到解决办法。我一直在与BM64合作,并有相同的问题,但设法修复它。首先,这个响应实际上是从EVE板上的开关仍然设置在编程模式,而不是EEPROM负载模式。这是SW9模式:运行APP:1关,2开。编程:1关,2关。编程EEPROM:1开,2关。每当你改变开关状态,你也必须对芯片进行电源循环,否则它不会生效。
以上来自于百度翻译 以下为原文 For those who like me took a while yo get the solution. I have been working with the BM64 and had the same issue, but managed to fix it. First this response is actually from the switches on the eval board being set still in programming mode rather than eeprom load mode. That is SW9 modes: Running app: 1 off, 2 on. Programming: 1 off, 2 off. Programming eeprom: 1 on, 2 off. Whenever you change switch states you have to power cycle the chip too, else it won't take effect. |
只有小组成员才能发言,加入小组>>
4844 浏览 9 评论
1846 浏览 8 评论
1762 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2971 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2074 浏览 5 评论
472浏览 1评论
1123浏览 1评论
313浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
375浏览 0评论
270浏览 0评论
GMT+8, 2024-5-13 14:46 , Processed in 1.060401 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
