我正在看PIC32蓝牙音频开发板(DMS3200),它是由Microchip推荐的,用蓝牙技术测试PIC32微控制器的可行性。然而,这个板使用另一个蓝牙子板,它又使用BTM805CL2B蓝牙模块。BTM806CL2B与其他蓝牙模块,如BM64或BM62?他们会工作吗,我需要一些建议和确认之前,我承诺购买。谢谢建议/建议
以上来自于百度翻译 以下为原文 I am looking at the PIC32 Bluetooth Audio Development Board (DM320032) which is recommended by Microchip for testing PIC32 microcontroller feasibility with bluetooth tech. However, this board uses another bluetooth daughter board which in turn uses the BTM805CL2B bluetooth module. Can i replace this BTM806CL2B with other bluetooth module such as BM64 or BM62? will they work, i need some advice and confirmation before I commit to buy. thanks for advice/suggestion |
8个回答
嗨,似乎(从其数据表),BTM805CL2B是双模HCI蓝牙模块(BT2.1,BT3 HS和BT 4)。我不认为Microchip有任何蓝牙HCI模块……
以上来自于百度翻译 以下为原文 Hi, It seems (from its datasheet) that the BTM805CL2B is a dual mode HCI bluetooth module (BT2.1, BT3 HS & BT 4.0). I don't think Microchip has any Bluetooth HCI module... Regards |
您好,对于您来说,标准蓝牙模块和HCI蓝牙模块之间有很大的区别吗?HCI意味着你必须在CPU上运行蓝牙堆栈,因此你需要有一个经过认证的蓝牙堆栈。如果你使用一个非HCI模块(简单得多),你可以使用一个简单得多的PIC(基本上是任何PIC),因为蓝牙栈在蓝牙模块内部。您只需要发送命令。所以我建议您使用非HCI蓝牙模块LigEn52或BM66/BM64。重要的是,这些模块将在2017年6月从欧洲开始强制执行新的Red认证:HTTP://www. McCHIP.COM/设计中心/无线连接。红/红常问问题/问候
以上来自于百度翻译 以下为原文 Hi, Is it clear for you that there is a large difference between a standard bluetooth module and an HCI bluetooth module ? HCI means you must run the bluetooth stack on the CPU and therefore you need to have a certified bluetooth stack.If you use a non HCI module (much much simpler) you can use a much simpler PIC (basically any PIC) because the bluetooth stack is inside the bluetooth module. You only need to send commands. So I recommend that you use a non HCI bluetooth module like RN52 or BM62 / BM64. Also important is that these modules will go through the new RED certification which is mandatory in Europe from june 2017 onwards : http://www.microchip.com/design-centers/wireless-connectivity/red-frequently-asked-questions/ Regards |
嗨,RISC,谢谢你的回复。我猜,只是没有确认HCI和独立蓝牙模块,但你确认了。
以上来自于百度翻译 以下为原文 hi RISC, thanks for your reply. I guessed but just no confirmation about the HCI and standalone bluetooth module but you confirmed it. |
哦,克劳德,我写了很多细节,忘记了原来的问题。呸!RN52将是我的第一选择(注意它支持蓝牙音频和BTL3.0)理由:RN模块对于我来说是更容易编写代码的,因为我是硬件Guy。BM62将是我的第二选择,除非BTL4.2是一个关键需求。BM62:支持模拟音频输出(更小的尺寸在29×15 x)。BM64:既支持数字音频I2S格式,又支持模拟音频输出(32×15×2.5),既不需要删除,也不必替换BTM805部分、不同的形状因子和不同的软件。
以上来自于百度翻译 以下为原文 Oh crud, I wrote lots of details and lost track of the original question. Doh! RN52 would be my first choice (note it supports Bluetooth Audio & BTLE3.0) Reason: RN modules are always easier for me to write code for, as I'm a hardware guy. BM62 would be my second choice, unless BTLE4.2 was a critical requirement. BM62: Supports analog audio output (smaller size at 29 x 15 x 2.5mm) BM64: Supports both digital audio I2S format and analog audio output (32 x 15 x 2.5) Neither are a drop in to replace that BTM805 part, different form factor and different software. |
Hi @ RunDoCKToM,RN-52对我的应用程序没有好处(http://www. McCys.com /论坛/ M99027.9. ASPX)@ RISC已经说过RN-52只能用于接收音频。我有RN-52模块,并在即将到来的几天内进行突破和测试。基本上,我想通过USB或蓝牙将音频发送到PIC32 MX,并将音频重新发送到另一个蓝牙功能的设备,如耳机。BM64/BM62能做到这一点吗?我需要更多的确认。但我已经订购了它们。
以上来自于百度翻译 以下为原文 Hi @roundrocktom, RN-52 is no good for my application(http://www.microchip.com/forums/m990279.aspx) @RISC has said RN-52 can only be used to receive audio. I have RN-52 module and working on breakout break and test is still to be done in coming days. Basically I want to send audio to PIC32MX via USB or bluetooth and resend that audio to another bluetooth enabled device such as headset. Can BM64/BM62 do this? I need more confirmation. But I have already ordered them anyway. |
记住,论坛是对等的,而不是由微芯片积极监控。为了得到正式的回答,我需要在MicroChIP.COM/SputPro上提交的问题,去年我坐在一张桌子上,讨论开始了。我记得Microchip有一个RN52解决方案来做你需要的。查看RN52数据表显示“MIC”和“说话者”连接。通过V1.16软件查看一个较早的问题得到解决。我错过了一些东西。我会订购一些RN52模块,作为我的后备项目之一,是把蓝牙扬声器添加到我的工作车间,因此,MIC和SPKR是我所需要的理想。RISC一直是一个伟大的资源,所以我错过了一些东西。需要做更多的挖掘。这可能有帮助。http://MyCHIPCDeals.com/On和次谐波:语音记录器InONOTo:我认为这是用和声1.6完成的,我将使用同一版本的Orthic、IDE-X和XC32来进行示例…一旦我明白了我在做什么,确认了功能硬件,那么我就在最新的版本上尝试它。通过PM(私人MSG)发送你的电子邮件。
以上来自于百度翻译 以下为原文 Keep in mind the forum is peer to peer, and not actively monitored by Microchip. To get an official answer requires the question to be submitted to microchip.com/support Last year at Masters I was sitting at a table, and the discussion came up. I remember Microchip had a RN52 solution for doing what you need. Looking at the RN52 datasheet shows "MIC" and "Speaker" connections. Looking through the v1.16 software shows an earlier issue was resolved. I'm missing something. I'll order some RN52 Modules, as one of my back burner projects is to add BlueTooth Speakers to my work shop, hence that MIC and SPKR is ideal for what I need. RISC has been a great resource, so I am missing something. Need to do more digging. This maybe of help. http://microchipdeveloper.com/harmony:voice-recorder-intro Note: I think that was done with Harmony 1.6 -- I'll go through the examples using the same version of Harmony, IDE-X, and XC32... Once I understand what I am doing, and confirmed functional hardware, ONLY THEN do I attempt it on the lastest version. Send me your email via PM (private msg) |
嗨,AFAIK,没有可用的微芯片蓝牙模块可以提供音频流…在过去有一个RN52SRC模块可以流音频,但它在几年前中断了(名字是RN52SRC……)。你可能需要在市场上寻找蓝牙音频源。但是我猜周围的人很少(可能很多人也会因为欧洲的红色指令而很快死去)。
以上来自于百度翻译 以下为原文 Hi, AFAIK, none of the available Microchip bluetooth modules can source an audio stream... In the past there was an RN52SRC module which could stream audio but it was discontinued a couple of years ago (name was RN52SRC.....). you may have to look on the market place for bluetooth audio sourcing solutions but my guess is that there are very few around (probably many will also die soon due to RED directive in Europe...). Regards |
RISC对我来说是个坏消息。我认为每一个蓝牙模块都是双向的-可以通过Bluuto-连接(如RN-52和耳机)来信源和接收器。我读到了高级音频分发配置文件(A2DP):这个蓝牙配置文件定义了一个音频设备的两个角色:源和汇:源(SRC):当它充当一个设备时,SRC是一个SRC。一种数字音频流的源,它被传送到微微网的SNK。Sink(SNK):一个设备是SNK,当它充当在同一个微微网上从SRC传送的数字音频流的接收器时。但是所有RN-52,BC64/BC62指定A2DP。TI的cc2560怎么样?
以上来自于百度翻译 以下为原文 @RISC that is bad news for me. i thought every bluetooth module is two way- can source and sink via blutooth connection- like RN-52 and headset. i read about Advanced Audio Distribution Profile (A2DP): This Bluetooth profile defines two roles of an audio device: source and sink:
只有小组成员才能发言,加入小组>>
5077 浏览 9 评论
1953 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3115 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2186 浏览 5 评论
631浏览 1评论
503浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
366浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
530浏览 0评论
438浏览 0评论
GMT+8, 2024-9-27 08:13 , Processed in 1.438886 second(s), Total 60, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
