亲爱的SPC5Studio团队,
我按照安装程序(备份许可证和工作区,卸载v3.7.1,删除工作区...),我现在有2个问题: - 我将我的v3.7项目导出为zip文件并在v4.0中导入。我添加了Platform,init和LL驱动程序SLA包,并生成了组件。哪里可以找到驱动程序设置?时钟组件显示时钟设置,确定,但FlexCAN,DSPI设置在哪里?即使我使用向导创建应用程序,我也被卡住了。时钟设置不使用我在configuation.xml中使用的值。 v4.0中是否仍支持v3.7 configuration.xml? - 我将http和https代理设置设置为手动,具有正确的服务器地址,端口,登录和密码,清除袜子条目,并且在启动时日志显示''系统属性https.proxyPort未设置但应该是8080.''和等所有6个属性。申请后只有一次有效,但在寻找更新或市场时,我有两个可能的问题: - 10次中的9次,日志显示''Provisioning exception''包含''需要HTTP代理身份验证:http://hightec.spc5studio.com/content.xml ''。 要么 - 10次中的1次,取出开始但转移极慢(2kB / s ......)并在20分钟后停止。 ST网站的回复也很慢。 ST端是否有任何问题,或者这可能来自我的代理配置?你会建议什么? 以上来自于谷歌翻译 以下为原文 Dear SPC5Studio Team, I followed the installation procedure (backup licence and workspace, uninstall v3.7.1, remove workspace...) and I now have 2 problems: - I exported my v3.7 project in zip file and imported it in v4.0. I added the Platform, init and LL drivers SLA packages and I generate the components. WHERE COULD DRIVERS SETTINGS BE FOUND? The clock component shows clock settings, ok, but where are FlexCAN, DSPI settings??? Even if I create an app using the wizard, i'm stuck. The clock settings are not using the values I used in my configuation.xml. Is the v3.7 configuration.xml still supported in v4.0? - I set the http and https proxy settings to manual with correct server address, port, login and pwd, clear socks entries, and at startup the log says ''System property https.proxyPort is not set but should be 8080.'' and so on for all 6 properties. Only one time it worked after applying but when looking for updates or market place I had 2 possible issues: - 9 times out of 10, the log shows ''Provisioning exception'' containing ''HTTP Proxy Authentication Required: http://hightec.spc5studio.com/content.xml ''. OR - 1 time out of 10, the fetching starts but the transfer is extremely slow (2kB/s...) and stops after 20 minutes. The ST website is also very slow to respond. Is there any issues on the ST side or could this come from my proxy config? What would you recommand? |
15个回答
你好Aurelien,
1)我们更新了SPC5Studio 4.0中的“用户界面” 你应该进入大纲视图(参见截图) 您可以找到您的驱动程序设置 帮助内容中的“组装应用程序”一章。 组件结构不变 您可以将应用程序从3.7导入4.0。 2)这是您身边的代理身份验证问题。 在Windows中==>优先 手动设置HTTP,HTTPS。 企业IT会杀了我们;-) 如果您的问题没有解决..我将直接发送网络链接。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , 1) We have updated the ''user interface'' in SPC5Studio 4.0 you should go in Outline view (cf screenshot) You can find your drivers settings chapter ''assembling your application'' in Help contents. The components structure are unchanged you can import an application from 3.7 into 4.0. 2) it is a proxy authentication issue from your side. In Windows ==> Preferences Set HTTP, HTTPS in manual. Corporate IT will kill us ;-) if your problem is not solved .. i will send a web link directly. Best regards Erwan |
你好,Erwan,
感谢您的答复。 1)看到import_fail.png图片atached - 当我导入我的项目时,有一些错误,手动添加组件后,他们不重用configuration.xml数据。更糟糕的是,当我保存configuration.xml时,所有设置都会丢失!请解释一下如何导入v3.7项目的zip备份。 2)看到atached的network_settings.png和network_settings_log_on_startup.png图片 - 你说要手动设置http和https,而不是袜子。但这一切都是手动或不是,不可能取消选择袜子。在启动时甚至在应用设置后,它们都没有被使用,我无法连接到更新站点或市场。请帮忙。 以上来自于谷歌翻译 以下为原文 Hello Erwan, thank you for your response. 1) see import_fail.png picture atached - When I import my project, there are some errors and after manually adding components, they do not reuse the configuration.xml data. Even worst, when I save configuration.xml, all settings are lost! Please, explain me how to import a zip backup of a v3.7 project. 2) see network_settings.png and network_settings_log_on_startup.png pictures atached - you said to set http and https to manually, but not socks. But it all manually or not, it is not possible to unselect socks. On startup and even after applying settings, they are not used and I can't connect to update site or market. Please help. |
你好Aurelien,
1)出现错误,您尚未安装SPC5-HAL SPC56ECXX组件 您需要从Marketplace安装。 (SPC5-HAL)。 2)您的代理在8080端口上运行良好?如果您的互联网浏览器中没有端口设置。默认情况下输入端口80。 无论如何,我通过zip文件发送完整的更新站点。 在几分钟内,您应该收到通知 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , 1) there is an error, You have not installed SPC5-HAL SPC56ECXX Component You need to install from the Marketplace. (SPC5-HAL). 2) Your proxy is well on the port 8080 ? if you have no port settings in your internet browser. put port 80 by default. Anyway , i am sending the full update site by zip file. in some minutes , you should receive a notification Best regards Erwan |
已发送2封邮件
1为hightec 1用于SPC5Studio组件 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 2 mails has been sent 1 for hightec 1 for SPC5Studio Components Best regards Erwan |
是的,我的IT确认我的代理端口是8080。
当我浏览地址时http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates4/ http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates4/the%20file%20content.xml 不在场。这是正常的吗? 访问更新站点时是否自动提取存在的文件content.jar? 我通过邮件收到了文件链接。大约100MB下载停止...我将从家里下载它们... 以上来自于谷歌翻译 以下为原文 Yes, my IT confirmed that my proxy port is 8080. When I browse the address http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates4/ http://spc5.drive.cloudforge.com/projects/spc5releases/SPC5Studio/updates4/the%20file%20content.xml is not present. Is that normal? Does the file content.jar which is present is automatically extracted when accessing update site? I received the files link by mail. Arround 100MB the download stops... I will download them from home... |
我还注意到,当我下载content.jar时,Windows正在使用JVM并且无法打开该文件(参见屏幕截图)。但7-zip打开它......
以上来自于谷歌翻译 以下为原文 I also noticed that when I download content.jar, Windows is using the JVM and can't open the file (see screenshot). But 7-zip opens it... |
你好Aurelien,
IT World不是我最好的朋友。 我在安全文件传输工具中打开了一张IT票证。 不要尝试通过更新站点链接下载。 我已经在zip文件中发送了一个“临时”链接。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , IT World is not my best friend. I have opened a IT ticket in Secure File Transfer Tool. Do not try to download by the update site link. i have sent a ''temporary'' link into the zip file. Best Regards Erwan |
我在家里下载了这些文件并且工作正常,所以它来自我工作的网络配置。
我安装了hightec编译器,但是我有一个不支持的永久浮动许可证文件......我应该如何安装它? 以上来自于谷歌翻译 以下为原文 I downloaded the files at home and it worked fine so it's coming from my network config at work. I installed hightec compiler but I have a permanent floating license file which is not supported... How should I install it? |
你好Aurelien,
我正在查看Hightec Floating许可证。 我正在创建一个更改请求以集成您的浮动许可证 我们的hightec编译器位于: C: SPC5Studio 日食插件 com.st.tools.spc5.tools.hightec.win32_1.0.0.201306281422 克斯 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , I am checking with Hightec Floating license. i am creating a Change request to integrate your floating license our hightec compiler is located : c:SPC5Studioeclipsepluginscom.st.tools.spc5.tools.hightec.win32_1.0.0.201306281422hightec Best regards Erwan |
你好Aurelien,
你能确认Hightec版吗? 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , Could you confirm Hightec version ? Best Regards Erwan |
我正在使用Hithtec Power PC工具链v4.6.6.0。
要使用浮动许可证,密钥RLM_LICENSE必须是端口和服务器(例如mailto:5053 @ server )。 我实际上有以下问题:我无法解决此链接器错误: C:/hightec/toolchains/powerpc/v4.6.6.0/bin /../ LIB / GCC / PPC-HT-EABI / 4.6.4 /../../../../ PPC-HT- eabi / bin / ld.exe:错误:找不到-lm ld.exe没有-lm选项,我不知道在哪里纠正这个。 我切换到hightec / eclipse环境,它没有任何问题。 Reagrds, 光环©留置权 以上来自于谷歌翻译 以下为原文 I'm using Hithtec Power PC toolchain v4.6.6.0. To use a floating licence the key RLM_LICENSE has to be the port and server (e.g. mailto:5053@server ). I actually have the following problem: I couldn't solve this linker error: c:/hightec/toolchains/powerpc/v4.6.6.0/bin/../lib/gcc/ppc-ht-eabi/4.6.4/../../../../ppc-ht-eabi/bin/ld.exe: error: cannot find -lm ld.exe has no -lm option and I don't know where to correct this. I switched to the hightec/eclipse environment and it builds without any problem. Reagrds, Aurélien |
你好Aurelien,
我也可以用浮动许可编译。 链接器选项默认设置为-lm,-lc 你必须设置-lc 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , I can compile with floating license too. Linker Options is set -lm,-lc by default you have to set -lc Best regards Erwan |
你好,Erwan,
看附件。我在链接器设置中添加了-lc选项但未成功。 -lm没有设置。我该在哪里纠正这个? 问候, 光环©留置权 以上来自于谷歌翻译 以下为原文 Hello Erwan, see file attached. I added -lc option to linker settings without success. -lm was not set. Where should I correct this? Regards, Aurélien |
你好Aurelien,
你应该 1)取消设置环境变量USE_LDOPT。 在C / C ++ / Build / Environment中 2)或将此变量环境置为空 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Aurelien , you should 1) unset your environment variable USE_LDOPT. in C/C++/Build/Environment 2) or Put this variable environment Empty Best regards Erwan |
你好,Erwan,
问题解决了!我是对的,我删除了这把钥匙。 谢谢 以上来自于谷歌翻译 以下为原文 Hello Erwan, problem solved! I were right, I removed this key. Thank you |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1610 浏览 1 评论
2295 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1519 浏览 1 评论
2901 浏览 6 评论
5397 浏览 21 评论
397浏览 4评论
673浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
296浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
746浏览 3评论
629浏览 3评论
GMT+8, 2024-5-14 08:19 , Processed in 1.203341 second(s), Total 103, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
