我正在寻找一个工作站来运行一个名为SolidWorks 2011的3D建模软件,其中包括Windows 7 64位和6到12GB的RAM,以及一个nVidia Quadro FX 4800.i7处理器和Xeon处理器有什么区别?
比如i7-920和X5550。 为什么Xeon处理器通常放在工作站计算机中。 以上来自于谷歌翻译 以下为原文 I am looking to build a workstation for running a 3D modeling software called SolidWorks 2011 with windows 7 64 bit and 6 to 12GB of ram, and an nVidia Quadro FX 4800. What is the difference between an i7 Processor and a Xeon Processor? Such as i7-920 and an X5550. Why are Xeon Processors commonly put in workstation computers. |
3个回答
嗨,基本上它们之间的区别是Xeon有2个QPI链接(允许它与双插槽主板中的另一个处理器同时工作),具有ECC内存支持并允许高达144 GB的内存(ory,其中i7仅允许最多
24 GB带非ECC内存。)当然价格,Xeon X5550比i7 920贵很多。 HTH 以上来自于谷歌翻译 以下为原文 Hi, basically the difference between those are that Xeon has 2 QPI links (which allows it to work simultaniously with another processor in dual socket motherboards), has ECC memory support and allows up to 144 GB of mem(ory where i7 only allows up to 24 GB with non ECC memory. ) and of course the price, Xeon X5550 is a lot more expensive than the i7 920. HTH |
与Xeon一起使用它们总是更好。
毫无疑问。 我在DX48BT2上运行X3380,它比它取代的QX9650更好,运行温度更低,并且平均分配所有4个核心的工作流程,在一个或两个核心完成所有工作。 以上来自于谷歌翻译 以下为原文 Go with the Xeon they are always better. No question about it. I'm running a X3380 on a DX48BT2 , and it's way better than the QX9650 that it replaced , Runs cooler and spreads the work flow across all 4 core evenly , in steed of have one or two cores doing all the work . |
jfsdwer 发表于 2018-10-11 14:31 对我来说卖点是ECC内存纠错。 内存故障和位丢失将会发生。 (在某些系统中比其他系统多得多) 在Xeon中,纠正了单个位错误,系统继续运行而没有任何明显的影响。 没有ECC,数据或代码被改变,这通常导致不希望的后果。 (像蓝屏) 在构建服务器或高端工作站时,ECC是必须的。 以上来自于谷歌翻译 以下为原文 Selling point for me is the ECC memory error correction. Memory faults and bit drops are going to happen. (in some systems a lot more than others) In the Xeon, a single bit error is corrected and the system continues without any noticabble impact. Without ECC, data or code is altered which generally results in undesired consequences. (like a Blue Screen) When building servers or high end workstations, ECC is a must have. |
只有小组成员才能发言,加入小组>>
260浏览 0评论
GMT+8, 2024-5-15 01:42 , Processed in 0.672484 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
