我用的硬件是TMDSEVM6678LE评估版,CCS5.2,pdk_C6678_1_1_2_5。我想将测试SRIO内环的工程(路径C:tipdk_C6678_1_1_2_5packagestidrvsrioexampleSRIOLoopbackDioIsr)和测试网络的工程(路径C:tipdk_C6678_1_1_2_5packagestidrvpaexampleemacExample)合并成一个工程。我的整个工程如附件所示(编译时要将附件中SRIO_LoopbackDioIsrexampleproject文件夹内的emac包含进去)。我的做法是:将emacExample中的C代码加入SRIOLoopbackDioIsr工程中,cfg文件用loopbackDioIsr.cfg。下边是main函数: Void main(Void) [ Task_Params cpswTaskParams; /* Get the core number. */ coreNum = CSL_chipReadReg (CSL_CHIP_DNUM); #if 0 //SRIO测试函数 Task_Params taskParams; #ifdef SIMULATOR_SUPPORT #warn SRIO DIO LSU ISR example is not supported on SIMULATOR !!! System_printf ("SRIO DIO LSU ISR example is not supported on SIMULATOR. Exiting!n"); return; #else System_printf ("Executing the SRIO DIO example on the DEVICEn"); #endif /* Initialize the system only if the core was configured to do so. */ if (coreNum == 0) [ System_printf ("Debug(Core %d): System Initialization for CPPI & QMSSn", coreNum); /* System Initialization */ if (system_init() < 0) return; //Cpsw_SingleCoreApp(); /* Power on SRIO peripheral before using it */ if (enable_srio () < 0) [ System_printf ("Error: SRIO PSC Initialization Failedn"); return; ] /* Device Specific SRIO Initializations: This should always be called before * initializing the SRIO Driver. */ if (SrioDevice_init() < 0) return; /* Initialize the SRIO Driver */ if (Srio_init () < 0) [ System_printf ("Error: SRIO Driver Initialization Failedn"); return; ] /* SRIO Driver is operational at this time. */ System_printf ("Debug(Core %d): SRIO Driver has been initializedn", coreNum); /* Write to the SHARED memory location at this point in time. The other cores cannot execute * till the SRIO Driver is up and running. */ isSRIOInitialized[0] = 1; /* The SRIO IP block has been initialized. We need to writeback the cache here because it will * ensure that the rest of the cores which are waiting for SRIO to be initialized would now be * woken up. */ CACHE_wbL1d ((void *) &isSRIOInitialized[0], 128, CACHE_WAIT); ] else [ /* All other cores need to wait for the SRIO to be initialized before they proceed. */ System_printf ("Debug(Core %d): Waiting for SRIO to be initialized.n", coreNum); /* All other cores loop around forever till the SRIO is up and running. * We need to invalidate the cache so that we always read this from the memory. */ while (isSRIOInitialized[0] == 0) CACHE_invL1d ((void *) &isSRIOInitialized[0], 128, CACHE_WAIT); /* Start the QMSS. */ if (Qmss_start() != QMSS_SOK) [ System_printf ("Error: Unable to start the QMSSn"); return; ] //Cpsw_SingleCoreApp(); System_printf ("Debug(Core %d): SRIO can now be used.n", coreNum); ] if (coreNum == 0) [ /* Create the DIO Example Task.*/ Task_Params_init(&taskParams); taskParams.priority = 1; Task_create(dioExampleTask, &taskParams, NULL); ] #endif #if 1 //emac测试函数 if (!cpswSimTest) [ passPowerUp(); ] /* Initialize the task params */ Task_Params_init(&cpswTaskParams); //cpswTaskParams.priority = 2; /* Create the CPSW single core example task */ Task_create((Task_FuncPtr)&Cpsw_SingleCoreApp, &cpswTaskParams, NULL); #endif /* Start the BIOS */ BIOS_start(); ] main 函数中有两个测试函数,一个是网络测试函数,一个是SRIO测试函数,每个函数单独测试,运行正常。现在我想将两者一起用,即在一个核中既运行网络测试函数,又可以运行SRIO函数。我的做法参考了http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/198711.aspx,改法如下: 1.对Cpsw_SingleCoreApp任务的Init_Qmss函数中的 qmssInitConfig.maxDescNum = NUM_HOST_DESC;修改成qmssInitConfig.maxDescNum = NUM_HOST_DESC+128; memset (gHostDesc, 0, SIZE_HOST_DESC * (NUM_HOST_DESC));修改成memset (gHostDesc, 0, SIZE_HOST_DESC * (NUM_HOST_DESC+128)); memCfg.descNum = NUM_HOST_DESC;修改成memCfg.descNum = NUM_HOST_DESC+128; cppiDescCfg.descNum = NUM_HOST_DESC修改成cppiDescCfg.descNum = NUM_HOST_DESC+128; 2.由于SRIO和emac都初始化了QMSS,将SRIO的QMSS初始化加到Cpsw_SingleCoreApp函数中; .SRIO的QMSS初始化函数如下: void mysrioqmssinit() [ Int32 result; Qmss_MemRegInfo memRegInfo; /* Memory Region 1Configuration */ memRegInfo.descBase = (UInt32 *)Convert_CoreLocal2GlobalAddr((UInt32)gHostDesc); memRegInfo.descSize = SIZE_HOST_DESC; memRegInfo.descNum = NUM_HOST_DESC; memRegInfo.manageDescFlag = Qmss_ManageDesc_MANAGE_DESCRIPTOR; memRegInfo.memRegion = Qmss_MemRegion_MEMORY_REGION1;//Qmss_MemRegion_MEMORY_REGION_NOT_SPECIFIED; memRegInfo.startIndex = 128; /* Initialize and inset the memory region. */ //Success - Inserted Memory region index. Range is 0 to 19. //Failure - QMSS_INVALID_PARAM // Failure - QMSS_NOT_INITIALIZED // Failure - QMSS_MEMREGION_ALREADY_INITIALIZED //Failure - QMSS_MEMREGION_INVALID_PARAM //Failure - QMSS_MAX_DESCRIPTORS_CONFIGURED //Failure - QMSS_MEMREGION_INVALID_INDEX //Failure - QMSS_MEMREGION_OVERLAP //Failure - QMSS_QUEUE_OPEN_ERROR //Failure - QMSS_RESOURCE_MEMORY_REGION_INIT_DENIED //Failure - QMSS_RESOURCE_LINKING_RAM_INIT_DENIED result = Qmss_insertMemoryRegion (&memRegInfo); if (result < QMSS_SOK) [ System_printf ("Error inserting memory region: %dn", result); return; ] ] 3.在Cpsw_SingleCoreApp中初始化顺序如下: Init_Qmss(); mysrioqmssinit(); Init_Cppi (); Init_PASS (); Init_Cpsw (); Setup_Tx (); Setup_Rx (); Setup_PASS (); 4.运行结果:在函数mysrioqmssinit()中 result = Qmss_insertMemoryRegion (&memRegInfo)的返回值为-135,但是emac函数运行正常; 现在我的问题是: 1.我这样初始化正确与否?哪里出了毛病? 2.将srio和emac合并,还需要做什么修改? |
4个回答
另外感觉在所有的附带例程中没有找到一个既使用SRIO又使用网络的工程文件,发现所有的例程都是测试一种接口;我想一个工程应用肯定不只使用一种接口,TI支持应该有此类合并使用SRIO和网络的工程文件吧,希望可以提供一份例程代码参考,谢谢
EMAC和SRIO都是navigator peripheral,各自的工程中都会对QMSS进行初始化,各自需要分配descriptor,以及相应的队列queue资源。在合并时需要注意QMSS的初始化只能一次,注意queue的使用分配不能冲突,对descriptor总数的定义要根据两个模块的需求有所增加。
根据你的错误提示,可以查看 Qmss_insertMemoryRegion的实现,返回值-135对应QMSS_MAX_DESCRIPTORS_CONFIGURED,即在申请描述符时发现已经耗尽,可以将系统定义的最大描述符个数增大。在集成过程中遇到类似问题,可以查看pdk中相关函数的源码对应错误类型进行解决。 |
zbb9612 发表于 2018-6-19 04:46 Andy,你好,按照你的意见修改了相关值,但是又出现返回值是-137,经查询得知是QMSS_MEMREGION_OVERLAP,意思是/** QMSS memory region overlap */ ,但是我一个分配的是Qmss_MemRegion_MEMORY_REGION0,一个是Qmss_MemRegion_MEMORY_REGION1,而且index也不同,为什么还会出现这样的情况?有无工程合并时的QMSS初始化code提供参考? |
fb3544 发表于 2018-6-19 04:53 其实你可以参考一下PDK中CPPI的几个例子,你的问题就能够解决了。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3649 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9386 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
670浏览 2评论
717浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
678浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1200浏览 1评论
1779浏览 1评论
GMT+8, 2024-4-27 05:14 , Processed in 0.614191 second(s), Total 47, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
