单片机/MCU论坛
直播中
hanhan1129
14年用户 174经验值
擅长:便携及消费电子
私信 关注
[问答]
LCD1602显示数据异常
目的:
用1602显示6行数据,分3页显示。每行数据输入后,按确定键保存当前输入的数据。两行输入完成后,按翻页键
翻到下一页,继续输入数据。当翻页键按到第4次时,重新显示第一页之前输入的数据,后面两页依次类推。
目前的主要问题是第4次按下时,无法显示之前输入的数据。
程序如下:
#include
#include
#include
#define uint unsigned int
#define uchar unsigned char
#define ulong unsigned long
/******************LCD1602**********************/
***it LCD_RS = P2^3;  //
***it LCD_RW = P2^4;  //
***it LCD_EN = P2^5;  //
***it dula   = P2^6;  //
***it wela   = P2^7;  //
***it pulse  = P1^1;  //
#define LCD_DA P0
#define KEY  P3  //
uchar code title[6][16]=
"T :",
"t1:",
"t2:",
"d1:",
"d2:",
"N :"
uchar code table1[]={"    SVC TEST    "};
uchar code table2[]={" Set Parameters "};
long int data_a=0;
long int data_b=0;
ulong data_1=0;
ulong data_2=0;
ulong data_3=0;
ulong data_4=0;
ulong data_5=0;
ulong data_6=0;
ulong dispaly[10];
uchar i,j;
uchar key=0xff;
uchar a=0;
uchar b=8;
uchar x=0;
uchar flag=0;
uchar flag1=0;
uchar enterflag=0;
void delay(uint time)
uint i,j;
for(i=time;i>0;i--)
for(j=110;j>0;j--);
void DelayS(uint time)
delay(1000*time);
void delay_fmq(uint time)
uint x,y;
for(x=time;x>0;x--)
for(y=5;y>0;y--);
void write_com(uchar com)
LCD_RS=0;
LCD_RW=0;
LCD_EN=0;
LCD_DA=com;
delay(2);
LCD_EN=1;
delay(2);
LCD_EN=0;
void write_date(uchar date)
LCD_RS=1;
LCD_RW=0;
LCD_EN=0;
LCD_DA=date;
delay(2);
LCD_EN=1;
delay(2);
LCD_EN=0;
void LCD_Clear(void)
   write_com(0x01);
   delay(5);
void W_lcd(unsigned char x,unsigned char y,unsigned char Data)
if(y==0)
  write_com(0x80 + x);
else
  write_com(0xc0 + x);
write_date(Data);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if(y==0)
  else
  write_com(0xC0 + x);
while(*s)
  write_date(*s);
        s++;
void LCD_init()
dula=0;
wela=0;
write_com(0x38);
    delay(5);
    write_com(0x38);
    delay(5);
    write_com(0x38);
    delay(5);
write_com(0x0f);
    delay(5);
write_com(0x06);
    delay(5);
write_com(0x01);
    delay(5);
void Start(unsigned long T,unsigned long t1,unsigned long t2,unsigned long d1,unsigned long d2,unsigned long N)
unsigned long Low_time,High_time;
unsigned long Low_S,High_S;
unsigned int Low_Ms,High_Ms;
unsigned char n;
for(n=1;n<=N;n++)
  Low_time=t1+n*d1;
  High_time=t2+n*d2;
  Low_S=(T+Low_time)/1000;
  Low_Ms=(T+Low_time)%1000;
  High_S=High_time/1000;
  High_Ms=High_time%1000;
  pulse =0;
  DelayS(Low_S);
  delay(Low_Ms);
  pulse =1;
  DelayS(High_S);
  delay(High_Ms);
void stop()
pulse=1;
short keycheckdown()
short temp1,temp2,temp,a=0xff;
KEY=0xf0;
delay(20);
temp1=KEY;
KEY=0xff;
delay(20);
KEY=0x0f;
delay(20);
temp2=KEY;
KEY=0xff;
temp=(temp1&0xf0)|(temp2&0xf);
    switch(temp)
     case 0xee :a=7;
    break;
     case 0xed :a=8;
    break;
     case 0xeb :a=9;
    break;
  case 0xe7 :a=0x0a;
    break;
     case 0xde :a=4;
    break;
    case 0xdd :a=5;
    break;
     case 0xdb :a=6;
    break;
   case 0xd7 :a=0x0b;
    break;
   case 0xbe :a=1;
    break;
     case 0xbd :a=2;
    break;
     case 0xbb :a=3;
    break;
  case 0xb7 :a=0x0c;
    break;
     case 0x7e :a=0;
    break;
   case 0x7d :a=0x0e;
    break;
   case 0x7b :a=0x0f;
    break;
    case 0x77 :a=0x0d;
    break;
  default :a=0xff;
return a;
void display_a()
dispaly[6]=data_a%10000000/1000000;
dispaly[5]=data_a%1000000/100000;
dispaly[4]=data_a%100000/10000;
dispaly[3]=data_a%10000/1000;
dispaly[2]=data_a%1000/100;
dispaly[1]=data_a%100/10;
dispaly[0]=data_a%10;
write_com(0x80+3);
    if(data_a>999999)
  write_date('0'+dispaly[6]);
    if(data_a>99999)
  write_date('0'+dispaly[5]);
    if(data_a>9999)
  write_date('0'+dispaly[4]);
if(data_a>999)
  write_date('0'+dispaly[3]);
if(data_a>99)
  write_date('0'+dispaly[2]);
if(data_a>9)
  write_date('0'+dispaly[1]);
write_date('0'+dispaly[0]);
void display_b()
write_com(0xc0+3);
dispaly[6]=data_b%10000000/1000000;
dispaly[5]=data_b%1000000/100000;
dispaly[4]=data_b%100000/10000;
dispaly[3]=data_b%10000/1000;
dispaly[2]=data_b%1000/100;
dispaly[1]=data_b%100/10;
dispaly[0]=data_b%10;
    if(data_b>999999)
    if(data_b>99999)
    if(data_b>9999)
if(data_b>999)
if(data_b>99)
if(data_b>9)
void display_1()
if(data_1<10000000&&data_1>-1)
  dispaly[6]=data_1%10000000/1000000;
  dispaly[5]=data_1%1000000/100000;
  dispaly[4]=data_1%100000/10000;
  dispaly[3]=data_1%10000/1000;
  dispaly[2]=data_1%1000/100;
  dispaly[1]=data_1%100/10;
  dispaly[0]=data_1%10;
  write_com(0x80+3);
   if(data_1>999999)
   if(data_1>99999)
   if(data_1>9999)
   if(data_1>999)
   if(data_1>99)
   if(data_1>9)
void display_2()
if(data_2<10000000&&data_2>-1)
  dispaly[6]=data_2%10000000/1000000;
  dispaly[5]=data_2%1000000/100000;
  dispaly[4]=data_2%100000/10000;
  dispaly[3]=data_2%10000/1000;
  dispaly[2]=data_2%1000/100;
  dispaly[1]=data_2%100/10;
  dispaly[0]=data_2%10;
  write_com(0x80+0x40+3);
   if(data_2>999999)
   if(data_2>99999)
   if(data_2>9999)
   if(data_2>999)
   if(data_2>99)
   if(data_2>9)
void display_3()
if(data_3<10000000&&data_3>-1)
  dispaly[6]=data_3%10000000/1000000;
  dispaly[5]=data_3%1000000/100000;
  dispaly[4]=data_3%100000/10000;
  dispaly[3]=data_3%10000/1000;
  dispaly[2]=data_3%1000/100;
  dispaly[1]=data_3%100/10;
  dispaly[0]=data_3%10;
  write_com(0x80+3);
   if(data_3>999999)
   if(data_3>99999)
   if(data_3>9999)
   if(data_3>999)
   if(data_3>99)
   if(data_3>9)
void display_4()
if(data_4<10000000&&data_4>-1)
  dispaly[6]=data_4%10000000/1000000;
  dispaly[5]=data_4%1000000/100000;
  dispaly[4]=data_4%100000/10000;
  dispaly[3]=data_4%10000/1000;
  dispaly[2]=data_4%1000/100;
  dispaly[1]=data_4%100/10;
  dispaly[0]=data_4%10;
   if(data_4>999999)
   if(data_4>99999)
   if(data_4>9999)
   if(data_4>999)
   if(data_4>99)
   if(data_4>9)
void display_5()
if(data_5<10000000&&data_5>-1)
  dispaly[6]=data_5%10000000/1000000;
  dispaly[5]=data_5%1000000/100000;
  dispaly[4]=data_5%100000/10000;
  dispaly[3]=data_5%10000/1000;
  dispaly[2]=data_5%1000/100;
  dispaly[1]=data_5%100/10;
  dispaly[0]=data_5%10;
  write_com(0x80+3);
   if(data_5>999999)
   if(data_5>99999)
   if(data_5>9999)
   if(data_5>999)
   if(data_5>99)
   if(data_5>9)
void display_6()
if(data_6<10000000&&data_6>-1)
  dispaly[6]=data_6%10000000/1000000;
  dispaly[5]=data_6%1000000/100000;
  dispaly[4]=data_6%100000/10000;
  dispaly[3]=data_6%10000/1000;
  dispaly[2]=data_6%1000/100;
  dispaly[1]=data_6%100/10;
  dispaly[0]=data_6%10;
   if(data_6>999999)
   if(data_6>99999)
   if(data_6>9999)
   if(data_6>999)
   if(data_6>99)
   if(data_6>9)
void Keypro(uchar Funkey)
switch(Funkey)
  case 1: write_com(0x0f);
     write_com(0x10);
     break;
  case 2: write_com(0x0f);
     write_com(0x14);
      break;
  case 3:  if(enterflag==3) enterflag=0;
     if(flag==0)
      if(enterflag==1)
       data_1=data_a;
       data_a=0;
       display_b();
      if(enterflag==2)
       data_2=data_b;
       data_b=0;
     if(flag==1)
      if(enterflag==1)
       data_3=data_a;
       data_a=0;
       display_b();
      if(enterflag==2)
       data_4=data_b;
       data_b=0;
     if(flag==2)
      if(enterflag==1)
       data_5=data_a;
       data_a=0;
       display_b();
      if(enterflag==2)
       data_6=data_b;
       data_b=0;
     break;
  case 4:
     if(flag==3)  {flag=0;}
      if(flag==0)
       LCD_Clear();
       LCD_Write_String(0, 0, Title[flag*2]);
            display_1();
       LCD_Write_String(0, 1, Title[flag*2+1]);
               display_2();
      if(flag==1)
       LCD_Clear();
            display_3();
              display_4();
      if(flag==2)
       LCD_Clear();
            display_5();
               display_6();
     write_com(0x80+3);
     break;
  case 0: break;
void main()
LCD_init();
LCD_Write_String(0,0,Title[0]);
LCD_Write_String(0,1,Title[1]);
    while(1)
  key=keycheckdown();
  if(0xff!=key)
   if(key<10)
    if(a<7)
     data_a=data_a*10+key;
     b=8;
     display_a();
    a++;
       if(b<7)
     data_b=data_b*10+key;
     a=8;
     display_b();
    b++;
         else
    switch(key)
     case 0x0a:   a=0;b=0;     //left
            x=1;
             Keypro(x);
          break;
     case 0x0b: a=0;b=0;     //right
          x=2;
          Keypro(x);
          break;
     case 0x0c: a=0;b=0;      //down
          flag++;
          enterflag=0;
          x=4;
          Keypro(x);
          break;
     case 0x0d: a=8;b=0;      //enter
           enterflag++;
           x=3;
             Keypro(x);
          break;
   do{KEY=0xf0;}
   while(KEY!=0xf0);
已退回5积分
回帖(3)
花景肆。
2016-6-2 20:04:38
2222222 啊啊啊啊啊啊啊啊啊啊啊啊啊
举报
chenwei6991627
2016-6-2 20:15:07
是不是被你覆盖掉了啊
举报
hanhan1129
2016-6-4 08:37:16
引用: chenwei6991627 发表于 2016-6-2 20:15
是不是被你覆盖掉了啊
应该没有吧,我每次都保存到单独的变量中啊
举报
更多回帖
