EasyEDA-中国人自已的EDA工具
直播中
GerryChen
10年用户 188经验值
擅长:电源/新能源 MEMS/传感技术 处理器/DSP
私信 关注
EasyEDA开源硬件——英特尔®爱迪生模块接口包
Description: The Intel® Edison is an ultra small computing platform that will change the way you look at embedded electronics. Each Edison is packed with a huge amount of tech goodies into a tiny package while still providing the same robust strength of your go-to single board computer. Powered by the Intel® Atom™ SoC dual-core CPU and including an integrated WiFi, Bluetooth LE, and a 70-pin connector to attach a veritable slew of shield-like “Blocks” which can be stacked on top of each other. It’s no wonder how this little guy is lowering the barrier of entry on the world of electronics!
This Interface Starter Pack includes everything you need to get your Edison connected, essentially, any way you need. With this pack you will be able to snap four connector-type “Blocks” to your Edison to provide linking with I2C, PWM, ADC, or to motors via Dual H-Bridge. All you need to bring to this party is your own Intel® Edison.
ADC_Block SCH
ADC_Block SCH1
Dual_H-Bridge_Block SCH
I2C_Breakout_Block SCH
PWM_Block SCH
ADC_Block PCB
Dual_H-Bridge_Block PCB
I2C_Breakout_Block PCB
PWM_Block PCB
EasyEDA项目链接:https://easyeda.com/oshw/Interface_Pack_for_Intel_Edison_Open_hardware-9lfxrI0iA
EasyEDA链接:    https://easyeda.com
更多回帖
