FPGA|CPLD|ASIC论坛
直播中
joyjie
9年用户 27经验值
擅长:可编程逻辑
私信 关注
[问答]
xilinx fpga。microblaze ,uart串口通信软件设计求帮忙改成能回送数据的。。。
#include
#include "xparameters.h"
#include "xuartlite.h"
#include "xintc.h"
#include "xil_exception.h"
#include "xgpio.h"
#include "xstatus.h"
#include "xgpio_l.h"
#include "xil_assert.h"
#include "xil_io.h"
#include "xuartlite_l.h"
/************************** Constant Definitions *****************************/
#define XPAR_GPIO_0_DEVICE_ID       1
#define UARTLITE_DEVICE_ID      XPAR_UARTLITE_1_DEVICE_ID
#define INTC_DEVICE_ID          XPAR_INTC_0_DEVICE_ID
#define UARTLITE_INT_IRQ_ID     XPAR_INTC_0_UARTLITE_1_VEC_ID
#define GPIO_DEVICE_ID                        XPAR_GPIO_0_DEVICE_ID /*XPAR_GPIO2MCU_DEVICE_ID*/
* The following constant controls the length of the buffers to be sent
* and received with the UartLite device.
#define TEST_BUFFER_SIZE        50
/************************** Function Prototypes ******************************/
int CodeRecv(u16 DeviceId);
int UartIntConfig(XUartLite *UartLitePtr);
void SendHandler(void *CallBackRef, unsigned int EventData);
//void RecvHandler(void *CallBackRef, unsigned int EventData);
void RecvHandler(void);
void WriteFIFO(u8 data);
int ReadFIFO(void);
/************************** Variable Definitions *****************************/
XUartLite UartLite;            /* The instance of the UartLite Device */
XIntc IntCtrl;     /* The instance of the Interrupt Controller */
XGpio GpioOutput;
u8 ReceiveBuffer[50]={0};
u8 SendBuffer[50]={0};
/* u8 SendBuffer[50]={0x01,0x02,0x31,0x43,0x55,0xAA,0x0C,0xA9,0x08,0x01,
           0x04,0x00,0x07,0x08,0x09,0x0A,0x00,0x00,0x00,0x00,
               0xE4,0xA5,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,
               0x0E,0x0F,0x01,0x02,0x31,0x43,0x00,0x00,0x01,0x02}; */
* The following counters are used to determine when the entire buffer has
* been sent and received.
static volatile int TotalReceivedCount;
static volatile int TotalSentCount;
static volatile int ***uf;
* @head        FIFO头,用于串口的接收数据的写入
* @tail        FIFO尾,用于串口的接收数据的读出
* @bar        写入的数据已经完成一圈
static volatile int head,tail,bar;
static volatile u8 hasrev;
* Main function to call the UartLite interrupt example.
* @param        None
* @return        XST_SUCCESS if successful, XST_FAILURE if unsuccessful
* @note                None
int main(void)
        ***uf=0;
        if(! XGpio_Initialize(&GpioOutput, GPIO_DEVICE_ID))
                return XST_FAILURE;
        //  if(! XGpio_SelfTest(&GpioOutput)){
        //          return XST_FAILURE;
        if (! CodeRecv(UARTLITE_DEVICE_ID))
                return XST_FAILURE;
        return XST_SUCCESS;
* This function does a minimal test on the UartLite device and driver as a
* design example. The purpose of this function is to illustrate
* how to use the XUartLite component.
* This function sends data and expects to receive the same data through the
* UartLite. The user must provide a physical loopback such that data which is
* transmitted will be received.
* This function uses interrupt driver mode of the UartLite device. The calls
* to the UartLite driver in the handlers should only use the non-blocking
* calls.
* @param        DeviceId is the Device ID of the UartLite Device and is the
*                XPAR__DEVICE_ID value from xparameters.h.
* @return        XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note
* This function contains an infinite loop such that if interrupts are not
* working it may never return.
        int sum=0,k=0;
        int index,temp;
        int p=0;
        int l = 0;
        if ( XUartLite_Initialize(&UartLite, DeviceId)!= XST_SUCCESS)
                return XST_FAILURE;
         * Perform a self-test to ensure that the hardware was built correctly.
        /*Status = XUartLite_SelfTest(&UartLite);
        if (Status != XST_SUCCESS) {
                return XST_FAILURE;
        }*///在串口没接的情况下,串口自检会失败
         * Connect the UartLite to the interrupt subsystem such that interrupts can
         * occur. This function is application specific.
        if (UartIntConfig(&UartLite)!=XST_SUCCESS)
                return XST_FAILURE;
         * Enable the interrupt of the UartLite so that interrupts will occur.
        XUartLite_EnableInterrupt(&UartLite);
        //XUartLite_SendByte(XPAR_RS232_BASEADDR, SendBuffer[***uf++]);
        while(1){
                u8 SendCMD [16]={0};
                sum=0;
                temp=ReadFIFO();
                while(temp==-1)
                        temp=ReadFIFO();
                if((u8)temp==0x55) {
                        temp=ReadFIFO();
                        while(temp==-1)
                                temp=ReadFIFO();
                        if((u8)temp==0xaa){
                                for(index=0;index<15;index++) {
                                        temp=ReadFIFO();
                                        while(temp==-1)
                                                temp=ReadFIFO();
                                        SendCMD[index]=temp;
                                        sum +=temp;
                                sum &=0xff;
                                temp=ReadFIFO();
                                while(temp==-1)
                                        temp=ReadFIFO();
                                if(sum == temp){
                                        /*p=0;
                                        for (k=1;k<12;k++) {
                                                XGpio_WriteReg(XPAR_GENERIC_GPIO_BASEADDR,0,SendCMD[k+p]+((k+16)<<8));
                                                for (sum=0;sum<2;sum++);
                                                        XGpio_WriteReg(XPAR_GENERIC_GPIO_BASEADDR,0,0);
                                                p=(k>1)?1:0;
                                        p=0;
                                        l = 0;
                                                XGpio_WriteReg(XPAR_GENERIC_GPIO_BASEADDR,0,SendCMD[k+p+l]+((k+16)<<8));
                                                p=(k != 0)?1:0;
                                                l = (k < 9 )?0:2;
                                        p=0;
        return XST_SUCCESS;
* This function is the handler which performs processing to send data to the
* UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized. It is called when the transmit
* FIFO of the UartLite is empty and more data can be sent through the UartLite.
* This handler provides an example of how to handle data for the UartLite,
* but is application specific.
* @param        CallBackRef contains a callback reference from the driver.
*                In this case it is the instance pointer for the UartLite driver.
* @param        EventData contains the number of bytes sent or received for sent
*                and receive events.
* @return        None.
* @note                None.
        TotalSentCount = EventData;
* This function is the handler which performs processing to receive data from
* the UartLite. It is called from an interrupt context such that the amount of
* processing performed should be minimized.  It is called data is present in
* the receive FIFO of the UartLite such that the data can be retrieved from
* the UartLite. The size of the data present in the FIFO is not known when
* this function is called.
* @param        CallBackRef contains a callback reference from the driver, in
*                this case it is the instance pointer for the UartLite driver.
* @return        None.
* @note                None.
         //while(!XUartLite_IsReceiveEmpty(XPAR_RS232_BASEADDR))
         WriteFIFO(XUartLite_RecvByte(XPAR_RS232_BASEADDR));
         //XUartLite_SendByte(XPAR_RS232_BASEADDR, SendBuffer[(***uf++)%50]);
* This function setups the interrupt system such that interrupts can occur
* for the UartLite device. This function is application specific since the
* actual system may or may not have an interrupt controller. The UartLite
* could be directly connected to a processor without an interrupt controller.
* The user should modify this function to fit the application.
* @param    UartLitePtr contains a pointer to the instance of the UartLite
*           component which is going to be connected to the interrupt
*           controller.
* @Return   XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note     None.
        int Status;
         * Initialize the interrupt controller driver so that it is ready to
         * use.
        Status = XIntc_Initialize(&IntCtrl, INTC_DEVICE_ID);
                return XST_FAILURE;
         * Connect a device driver handler that will be called when an interrupt
         * for the device occurs, the device driver handler performs the
         * specific interrupt processing for the device.
        Status = XIntc_Connect(&IntCtrl, UARTLITE_INT_IRQ_ID,
                           (XInterruptHandler)RecvHandler,
                           (void *)UartLitePtr);
                return XST_FAILURE;
         * Start the interrupt controller such that interrupts are enabled for
         * all devices that cause interrupts, specific real mode so that
         * the UartLite can cause interrupts through the interrupt controller.
        Status = XIntc_Start(&IntCtrl, XIN_REAL_MODE);
                return XST_FAILURE;
         * Enable the interrupt for the UartLite device.
        XIntc_Enable(&IntCtrl, UARTLITE_INT_IRQ_ID);
         * Initialize the exception table.
        Xil_ExceptionInit();
         * Register the interrupt controller handler with the exception table.
        Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
                         (Xil_ExceptionHandler)XIntc_InterruptHandler,
                         &IntCtrl);
         * Enable exceptions.
        Xil_ExceptionEnable();
        return XST_SUCCESS;
*           controller.
* @note     None.
        ReceiveBuffer[head] =data;
        if(head==49) {
                bar=1;
                head=0;
        else
                head++;
*           controller.
* @note     None.
int ReadFIFO(void)
        if(tail                 return ReceiveBuffer[tail++];
        else if(tail==head)
                return -1;
        else if(bar) {
                if(tail<49)
                else {
                        bar=0;
                        tail=0;
                        return ReceiveBuffer[49];
        else
                return -1;
现成的从上位机到软核的串口软件代码,,现在需要添加往上位机回送数据的代码,,要求原样不动的回送回去就行求大神带飞。。。。
已退回5积分
回帖(2)
低调de炫耀爱
2015-7-24 10:38:03
这么长段的代码 已无力吐槽 楼主应该把自己的程序标注一下 提问题要提重点哦!
举报
joyjie
2015-7-29 23:27:52
顶一下,,怎么就没得人来呢、、
举报
更多回帖
