工程资源中心
直播中
京五环以外
11年用户 3299经验值
擅长:EMC/EMI设计
私信 关注
[通信设备]
采用 TPS40422 和电源块 II CSD87384:双相,带 PMPBus 接口
`描述及特性
It is a two phase Synchronous Buck converter to provide high current with low ripple and fast dynamic response for high speed processor core applications. Same approach can also be used to power Memory and Input / Output power voltages, typically 1.2V to 3.3V. The two phase interleave reduces output ripple and allows faster response to rapidly changing loads. The two phases distribute power loss to eliminate need for added heat sink hardware. The "Project File" for the TPS40422 to communicate with TI's Fusion GUI is included. Output voltage and current limit can be adjusted and monitored thru the GUI. Additional settings can be accessed thru the same GUI. Test Report includes thermal images to show load capability, both with and without fan cooling. Testing done at 12Vin, where voltage stresses, losses and output ripple greatest. Design will work also at 5Vin with same high speed control loop, due to Input Voltage Feed Forward in the TPS40422.
PMP8999 Schematic.pdf (165.52 KB)
(下载次数: 2, 2015-5-8 10:13 上传)
PMP8999 Test Results.pdf (629.03 KB)
PMP8999 BOM.pdf (113.2 KB)
PMP8999 PCB.pdf (830.86 KB)
更多回帖
