工程资源中心
登录
直播中
京五环以外
10年用户
3188经验值
擅长:EMC/EMI设计
私信
[智能家居]
High Efficiency Syncronous Buck Regulator (12V/15V @ 5A)
Efficiency
描述及特性
This synchronous buck regulator provides 96% efficiency when regula
ti
ng 24Vin to 15V out @ 5A. The output can be set to regulate 12V , if desired. PMP8493 uses TPS40170 wide input synchronous buck controller.
PMP8493 Test Results.pdf
(1.23 MB)
(下载次数: 1, 2015-5-6 16:56 上传)
PMP8493 BOM.pdf
(17.96 KB)
PMP8493 Schematic.pdf
(40.28 KB)
更多回帖
rotate(-90deg);
回复
相关帖子
Efficiency
LTC3605 Project -
15V
5A
Monolithic
Buck
Regulator
5-14V
to 3.3
V
5A
3
LT8630 Demo Circuit -
High
Efficiency
µPower
Buck
Regulator
(13-100
V
to
12V
@ 600mA)
5
LTC3895 Project -
High
Efficiency
High
Voltage
Buck
Converter with Rsense Current Sensing (14-130
V
to
12V
5A
5
LTC3895 Project -
High
Efficiency
High
Voltage
Buck
Converter with DCR Current Sensing (14-130
V
to
12V
5A
1
LTC3789 Project -
High
Efficiency
4-Switch Synchronous
Buck
-Boost Supply (
5-36V
to
12V
5A
1
LTM4662 Demo Circuit - Dual
High
Efficiency
Buck
Regulator
(4.5-20
V
to 1.2
V
15A
& 1.5
V
15A
3
LT8390 Demo Circuit -
High
Efficiency
250W
Buck
-Boost
Regulator
(9-36
V
to
12V
@ 25
A
15
15V
电压怎么降到
12V
2644
LTC3605演示电路-
15V
5A
、4 MHz、同步降压稳压器(
12V
至1.8
V@5A
1
LTC3605演示电路-
15V
5A
、4 MHz、同步降压稳压器(
12V
至1.8
V@5A
3
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
首页
论坛版块
小组
免费开发板试用
ebook
直播
搜索
登录
