工程资源中心
直播中
京五环以外
11年用户 3299经验值
擅长:EMC/EMI设计
私信 关注
[智能电网与能源]
Interfacing SDRAM Memory on High Performance Microcontrollers
`描述
This reference desing demonstrates how to implement and interface SDRAM Memory to the performance microcontroller TM4C129XNCZAD. The implementation is made possible by using the EPI Interface of the Microcontroller to interface a 256Mbit SDRAM at 60MHz which allows developers to implement additional memory for code and data when interfacing with High Speed LCD Panels.
特性
• Designed for (formerly Tiva MCU) DK-TM4C129X EVM with integrated Smart QVGA LCD Panel for Graphics Rendering http://www.ti.com.cn/tool/cn/TIDM-CONNECTED-ETHERNET
• Extend the useable memory space to 512Mbit, 16-bit SDRAM with the 60MHz External Peripherial Interface (EPI) for high memory throughput and footprint applications
• Driver library components to simplify code development
• Source code contains projects for Code Composer Studio
Interfacing SDRAM Memory on High Performance Microcontrollers Design Guide.pdf (1.24 MB)
(下载次数: 1, 2015-4-8 10:32 上传)
Interfacing SDRAM Memory on High Performance Microcontrollers Gerber.zip (22.54 KB)
Interfacing SDRAM Memory on High Performance Microcontrollers Schematic.pdf (259.4 KB)
更多回帖
