工程资源中心
直播中
京五环以外
11年用户 3299经验值
擅长:EMC/EMI设计
私信 关注
[消费电子]
Automotive Hall Sensor Rotary Encoder
`描述
This is an incremental rotary encoder that uses contactless magnetic sensing to detect rotational speed and direction.  The two Hall Effect sensors measure the 66-pole ring magnet and output two signals in quadrature.  This automotive-qualified solution is a low-cost and far more reliable alternative to conventional mechanical contact-based encoders, as it uses solid-state sensing that is immune to physical wear, dirt, corrosion, and RF noise.
特性
  • Extremely simple, reliable, and low-cost
  • Greater design flexibility over mechanical rotary encoder modules, and potential for cost savings
  • 66-pole magnet provides 132 detections per 360° of rotation (1 per 2.7°)
  • >20kHz Hall Effect sensor bandwidth provides low 15µs latency
  • Digital sensing and digital signaling offer noise immunity
  • Automotive qualified to AEC-Q100
TIDA-00480 Schematic.pdf (338.59 KB)
(下载次数: 2, 2015-3-13 09:33 上传)
TIDA-00480 Test Results.pdf (125.62 KB)
(下载次数: 1, 2015-3-13 09:33 上传)
tidc956.zip (383.95 KB)
tidrdb7.zip (721.86 KB)
TIDA-00480 Assembly Drawing.pdf (151.23 KB)
TIDA-00480 BOM.pdf (209.59 KB)
TIDA-00480 Design Considerations.pdf (146.99 KB)
TIDA-00480 Fabrication Drawing.pdf (399.16 KB)
TIDA-00480 PCB.pdf (918.79 KB)
更多回帖
