module getValue1(input clk,
input [7:0]da
tinB,
input ntrig,
input rdclk,
input [2:0] type1,
input type_en,
input req,
output reg [7:0] datout,
output reg [11:0]rdaddr,
output reg busy,
output reg RDY=0,
output reg [11:0] wraddr
reg [2:0] TYPE=4;
reg ntrig_next,busy_next,req_next,startWr; //用于判断边沿,start标识边沿后持续时间段(标识一帧)
reg [2:0] startRd;
reg [7:0] datinB_next; //datinA_next,用于判断过零点
reg [15:0] zeroB[50:0]; //起/始像素点(过零点 pixel)
reg [7:0] averB[25:0];//
reg [7:0] memB[4095:0];
reg [7:0]index_Bz,index_Bs ;//过零点 pixel 数组下标
reg [7:0] index_Bv;//过零点 pixel 数组下标
reg [15:0]index_Bm;//非零像素数组下标
reg startBz;//非零区段标识
reg [7:0] widthB;//
reg [31:0] sumB;//sumA,
reg [15:0]len_memB,len_Rd,len_zeroB;//
reg [7:0] len_averB;//
always @(posedge clk)
begin
//下降沿触发延时,延时一帧处理
ntrig_next<=ntrig;
if((ntrig_next)&(~ntrig)) //下降沿
begin
startWr<=1;
wraddr<=0;
index_Bz<=0;
index_Bv<=0;
index_Bm<=0;///长度可能大于255
end
if(startWr==1)//标识持续读取一帧
begin
busy<=1;
datinB_next<=datinB;
////----B 通道--------
if((datinB_next==0)&&(datinB>0)) //起始点
begin
startBz<=1;
index_Bs<=index_Bz;
zeroB[index_Bz]<=wraddr;//zeroA[1]开始存数据,[0]用于存长度
index_Bz<=index_Bz+1;
sumB<=datinB;//sumB<=0;
end
if(startBz) sumB<=sumB+datinB;
if((datinB_next>0)&&(datinB==0))//终了点
begin
startBz<=0;
widthB<=wraddr-zeroB[index_Bs];//widthB<=zeroB[index_Bz]-zeroB[index_Bs];
if(((wraddr-zeroB[index_Bs])>0)&&((wraddr-zeroB[index_Bs])<3640))//if((widthB>2)&&(widthB<500)) if((widthB>0)&&(widthB<500))
begin
averB[index_Bv]=sumB/(wraddr-zeroB[index_Bs]);//averB[index_Bv]=sumB/widthB;
index_Bv<=index_Bv+1;
end
else index_Bz<=index_Bs;//超出,则覆盖本次
end
//------------去掉 0 数值的帧内容---------
if(datinB>0)
begin
memB[index_Bm]=datinB;//自memA[2]开始存数据,[0:1]用于存长度
index_Bm<=index_Bm+1;
end
wraddr<=wraddr+1;
end//end startWr==1
if((startWr==1)&&(wraddr>=3647))
begin
startWr<=0;
busy<=0;
//-------B--------
len_zeroB<=(index_Bz<<1);//过零点位置数组 B ,位置16bit,长度*2
// zeroB[0]<=len_zeroB+1;
len_averB<=index_Bv; //平均值数组B
// averB[0]<=len_averB+1;
len_memB<=index_Bm; //非零值数组B
// memB[0]<=len_memB+1;
end
end
always @(posedge rdclk)
begin
busy_next<=busy;
req_next<=req;
datout<=8'h0;
if((busy_next==1)&&(busy==0))//(||((~req_next)&(req))) //busy 下降沿 or req 上升沿
begin
startRd<=1;//下降沿触发
RDY<=1;
rdaddr<=0;
case (type1)
3'h4://读取过零点位置数组 B
//len_Rd<=len_zeroB;
begin
len_Rd<=len_zeroB;
if(len_zeroB!=0)
datout<=8'h55;
else
datout<=8'h00;
end
3'h5://读取平均值数组B
//len_Rd<=len_averB;
begin
len_Rd<=len_averB;
if(len_averB!=0)
datout<=8'h55;
else
datout<=8'h00;
end
3'h6://读取 非零数组B
//len_Rd<=len_memB;
begin
len_Rd<=len_memB;
if(len_memB!=0)
datout<=8'h55;
else
datout<=8'h00;
end
default://reserve
datout<=0;
endcase
//datout<=8'h55;
end
if(startRd==1&&len_Rd>0)//
begin
datout<=len_Rd+2; //55 len data
startRd<=2;//startRd<=2;
RDY<=1;
end
if(RDY==1&&len_Rd==0)//清零,防止触发后没有合适的数据,导致RDY一直为1,不停发送零
RDY<=0;
if(startRd==2)//if(startRd==2)
begin
case (type1)
3'h4://读取过零点位置数组 B
begin
if(rdaddr[0]==0) datout<=zeroB[rdaddr>>1][15:8];
if(rdaddr[0]==1) datout<=zeroB[rdaddr>>1][7:0];
end
3'h5://读取平均值数组B
datout<=averB[rdaddr];
3'h6://读取 非零数组B
datout<=memB[rdaddr];
default://reserve
datout<=0;
endcase
rdaddr<=rdaddr+1;
RDY<=1;
end
if((rdaddr>=len_Rd)&&(rdaddr!=0))//if(rdaddr>=len_Rd)//
begin
startRd<=0;
RDY<=0;
rdaddr<=0;
len_Rd<=0;
end
end
endmodule
主要占用资源的是以上模块,加上后Total Logic Elements由10%直接增加到94%,芯片型号是cyclone 4 E系列。
图中,如果不把typeA[2..0]连接到getvalue1,Total Logic Elements只用了10%,连接上后,Total Logic Elements直接飙到了94%,请问是哪里出了问题,还是getvalue1模块的问题,getvalue1中的代码有什么优化的方法可以减少Total Logic Elements的使用。
