FPGA|CPLD|ASIC论坛
直播中
wuyu
11年用户 47经验值
擅长:测试与测量
私信 关注
[经验]
我写的fir滤波器
我写了一个滤波器的程序,但是仿真的结果不符合,我找不到错误,希望你能抽空帮我看一下。 滤波器的系数为-12     9   -12   -22    -3    -1   -38   -32    61   124    61   -32   -38    -1    -3   -22   -12   9   -12
程序如下,其中constant为滤波器的系数
library ieee;
use ieee.std_logic_arith.all;
use ieee.std_logic_1164.all;
entity filter is  port(
   clk,reset  :in std_logic;
   sample_in  :in signed (8 downto 0);
   result_out :out signed(21 downto 0));
end filter;
architecture behave of filter is
type coef_arr is array(0 to 18) of signed (7 downto 0);
  constant coefs : coef_arr:=("10001100","00001001","10001100","10010110","10000011",
  "10000001","10100110","10100000","00111101","01111110","00111101","10010000","10100110",
  "10000001","10000011","10010110","10001100","00001001","10001100");
begin
process(clk,reset)
        type  shift_register is array (18 downto 0) of signed (8 downto 0);
        variable shift  : shift_register;
        variable temp   : signed(8 downto 0);
        variable mul_value :signed(16 downto 0);
        variable acc_value : signed (21 downto 0);
begin
        if(reset='0')then
           for i  in 0 to 17 loop
                shift(i):="000000000";
           end loop;
       result_out<="0000000000000000000000";
     elsif (clk'event and clk='1')then
                temp:=sample_in;
                mul_value:=temp*coefs(0);
                acc_value:=conv_signed(mul_value,22);
                for i in 17 downto 0 loop
                                mul_value:=shift(i)*coefs(i+1);
                                acc_value:=acc_value+conv_signed(mul_value,22);
                                shift(i+1):=shift(i);
                end loop;
                shift(0):=temp;
        end if;
        result_out<=acc_value;
end process;
end behave;
我输入一个从1到10的序列用matlab进行卷积的结果为
din=[1:1:10];
>> h=[-12,9,-12,-22,-3,-1,-38,-32,61,124,61,-32,-38,-1,-3,-22,-12,9,-12];
>> conv(h,din)
ans =
  Columns 1 through 8
         -12         -15         -30         -67        -107        -148        -227        -338
  Columns 9 through 16
        -388        -314         -47         -31         169         490         621         711
  Columns 17 through 24
        1197        1664        1128        -162        -883        -642        -303        -333
  Columns 25 through 28
        -340        -135         -18        -120
仿真结果如下为什么两个不一样啊
更多回帖
