完整的 UART 接收中断示例
#include
#include
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/uart.h"
#include "esp_log.h"
static const char *TAG = "UART_EXAMPLE";
// UART 配置
#define UART_PORT_NUM UART_NUM_1
#define UART_BAUD_RATE 115200
#define UART_TXD_PIN 17
#define UART_RXD_PIN 16
#define UART_BUF_SIZE 1024
#define UART_QUEUE_LEN 20
static void uart_event_task(void *pvParameters)
uart_event_t event;
size_t buffered_size;
uint8_t *dtmp = (uint8_t *)malloc(UART_BUF_SIZE);
for (;;) {
// 等待 UART 事件
if (xQueueReceive(uart_get_event_queue(UART_PORT_NUM), &event, portMAX_DELAY)) {
bzero(dtmp, UART_BUF_SIZE);
switch (event.type) {
case UART_DATA:
// 数据接收事件
uart_read_bytes(UART_PORT_NUM, dtmp, event.size, portMAX_DELAY);
ESP_LOGI(TAG, "Received %d bytes: %.*s", event.size, event.size, dtmp);
break;
case UART_FIFO_OVF:
ESP_LOGI(TAG, "HW FIFO Overflow");
uart_flush_input(UART_PORT_NUM);
xQueueReset(uart_get_event_queue(UART_PORT_NUM));
break;
case UART_BUFFER_FULL:
ESP_LOGI(TAG, "Ring Buffer Full");
break;
case UART_BREAK:
ESP_LOGI(TAG, "UART Break");
break;
case UART_PARITY_ERR:
ESP_LOGI(TAG, "UART Parity Error");
break;
case UART_FRAME_ERR:
ESP_LOGI(TAG, "UART Frame Error");
break;
case UART_PATTERN_DET:
// 模式检测(可用于帧尾检测)
uart_get_buffered_data_len(UART_PORT_NUM, &buffered_size);
int pos = uart_pattern_pop_pos(UART_PORT_NUM);
ESP_LOGI(TAG, "Pattern detected at position: %d", pos);
if (pos != -1) {
uart_read_bytes(UART_PORT_NUM, dtmp, pos, 100 / portTICK_PERIOD_MS);
ESP_LOGI(TAG, "Pattern data: %.*s", pos, dtmp);
break;
default:
ESP_LOGI(TAG, "UART event type: %d", event.type);
break;
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
void app_main(void)
// UART 配置参数
uart_config_t uart_config = {
.baud_rate = UART_BAUD_RATE,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
.source_clk = UART_SCLK_DEFAULT,
// 配置 UART 参数
ESP_ERROR_CHECK(uart_param_config(UART_PORT_NUM, &uart_config));
// 设置 UART 引脚
ESP_ERROR_CHECK(uart_set_pin(UART_PORT_NUM, UART_TXD_PIN, UART_RXD_PIN,
UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE));
// 安装 UART 驱动
ESP_ERROR_CHECK(uart_driver_install(UART_PORT_NUM,
UART_BUF_SIZE * 2, // 接收缓冲区大小
UART_BUF_SIZE * 2, // 发送缓冲区大小
UART_QUEUE_LEN, // 事件队列大小
NULL, // 事件队列句柄
0)); // 中断分配标志
// 如果需要模式检测(帧尾检测),可以设置模式
// uart_enable_pattern_det_baud_intr(UART_PORT_NUM, '\n', 1, 9, 0, 0);
// uart_pattern_queue_reset(UART_PORT_NUM, UART_QUEUE_LEN);
// 创建 UART 事件处理任务
xTaskCreate(uart_event_task, "uart_event_task", 4096, NULL, 12, NULL);
// 发送测试数据
const char *test_data = "Hello UART!\n";
uart_write_bytes(UART_PORT_NUM, test_data, strlen(test_data));
ESP_LOGI(TAG, "UART initialized successfully");
对应的 CMakeLists.txt
# CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
project(uart_example)
set(SOURCES
main/main.c
idf_component_register(SRCS ${SOURCES}
INCLUDE_DIRS ".")
target_link_libraries(${CMAKE_PROJECT_NAME} PRIVATE -Wl,--start-group -lgcc -lstdc++ -Wl,--end-group)
如果仍有问题,尝试这个简化版本
#include
static const char *TAG = "UART_SIMPLE";
void app_main(void)
// 基本 UART 配置
.baud_rate = 115200,
// 安装 UART 驱动(使用默认引脚)
uart_driver_install(UART_NUM_0, 1024, 0, 0, NULL, 0);
uart_param_config(UART_NUM_0, &uart_config);
ESP_LOGI(TAG, "UART basic example running");
while(1) {
char test_str[] = "Hello World\n";
uart_write_bytes(UART_NUM_0, test_str, sizeof(test_str));
vTaskDelay(1000 / portTICK_PERIOD_MS);
完整的 UART 接收中断示例
#include
#include
// UART 配置
uart_event_t event;
for (;;) {
// 等待 UART 事件
case UART_DATA:
// 数据接收事件
break;
case UART_FIFO_OVF:
break;
break;
case UART_BREAK:
break;
break;
break;
// 模式检测(可用于帧尾检测)
if (pos != -1) {
break;
default:
break;
free(dtmp);
dtmp = NULL;
vTaskDelete(NULL);
void app_main(void)
// UART 配置参数
// 配置 UART 参数
// 设置 UART 引脚
// 安装 UART 驱动
NULL, // 事件队列句柄
0)); // 中断分配标志
// 创建 UART 事件处理任务
// 发送测试数据
对应的 CMakeLists.txt
# CMakeLists.txt
set(SOURCES
main/main.c
INCLUDE_DIRS ".")
如果仍有问题,尝试这个简化版本
#include
void app_main(void)
// 基本 UART 配置
while(1) {
举报
