我根据紫光同创的资料运行sudo RK_ROOTFS_SYSTEM=debian ./build.sh*,然后在Start packing firmwares这一步报错,完整运行一次所有编译要接近一个半小时,我感觉这应该是编译的最后一步,所以问问只运行这一步的命令是什么
初次接触嵌入式新人,如果问了蠢问题还请谅解,感谢
报错信息
[36m==========================================[0m
[36m Start packing firmwares[0m
[36mLinking /home/rk/SDK/output/firmware/parameter.txt from /home/rk/SDK/device/rockchip/.chip/parameter-buildroot-fit.txt...[0m
[35mPreparing partiton oem[0m
[36mMerging /home/rk/SDK/device/rockchip/common/extra-parts/oem/normal into /home/rk/SDK/output/extra-parts/oem[0m
[35mPacking /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem.fs[0m
Using host tools in /home/rk/SDK/buildroot/output/rockchip_rk3568/host (except for mke2fs)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem (auto sized)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(14271KB)
/sbin/mke2fs: symbol lookup error: /sbin/mke2fs: undefined symbol: test_io_manager
Retring with increased size....(1/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(18367KB)
Retring with increased size....(2/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(22463KB)
Retring with increased size....(3/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(26559KB)
Retring with increased size....(4/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(30655KB)
Retring with increased size....(5/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(34751KB)
Retring with increased size....(6/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(38847KB)
Retring with increased size....(7/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(42943KB)
Retring with increased size....(8/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(47039KB)
Retring with increased size....(9/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(51135KB)
Retring with increased size....(10/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(55231KB)
Retring with increased size....(11/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(59327KB)
Retring with increased size....(12/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(63423KB)
Retring with increased size....(13/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(67519KB)
Retring with increased size....(14/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(71615KB)
Retring with increased size....(15/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(75711KB)
Retring with increased size....(16/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(79807KB)
Retring with increased size....(17/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(83903KB)
Retring with increased size....(18/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(87999KB)
Retring with increased size....(19/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(92095KB)
Retring with increased size....(20/20)
Making /home/rk/SDK/output/extra-parts/oem.img from /home/rk/SDK/output/extra-parts/oem with size(96191KB)
FATAL: Failed to make image!
[31mERROR: Running /home/rk/SDK/device/rockchip/common/scripts/mk-extra-parts.sh - post_build_hook failed
