https://www.kendryte.com/k230_canmv/zh/main/zh/ai_dev_doc.html#id11 根据这个里面的例程(windows)修改文件地址后报错如下
C:InstallAnaconda3envsYOLOpython.exe C:AllPycharmProjectsyolov11toK230models_compare.py Traceback (most recent call last): File "C:AllPycharmProjectsyolov11toK230models_compare.py", line 119, in nncase_results = kmodel_inference(kmodel_path,kmodel_input_data,model_input_size) File "C:AllPycharmProjectsyolov11toK230models_compare.py", line 76, in kmodel_inference sim.load_model(kmodel)Run
timeError进程已结束,退出代码为 1测试了kmodel应该是没有问题的,如下:
import oskmodel_path = "./models/numDetect_yolov5su.kmodel"print("kmodel_path:", kmodel_path)print("File exists:", os.path.exists(kmodel_path))with open(kmodel_path, 'rb') as f: kmodel = f.read()print("kmodel size:", len(kmodel))=============================================================================C:InstallAnaconda3envsYOLOpython.exe C:AllPycharmProjectsyolov11toK230test.py kmodel_path: ./models/numDetect_yolov5su.kmodelFile exists: Truekmodel size: 9768648进程已结束,退出代码为 0尝试了把nncase降级到2.8.3(原来是2.9.0)也没用
import osimport cv2import numpy as npimport onnxruntime as ortimport nncaseimport math# 参数定义IMG_PATH = "../numDetect/dataset/data/images/test/0_91.jpg"MEAN = [0, 0, 0]STD = [1, 1, 1]MODEL_INPUT_SIZE = [320, 320]ONNX_MODEL = "../numDetect/runs/detect/train/weights/best.onnx" # ONNX 模型文件KMODEL_PATH = "./models/yolov5su.kmodel" # kmodel 模型文件def get_onnx_input(img_path,mean,std,model_input_size): # 读取图片,图片数据一般是RGB三通道,颜色范围为[0, 255.0] image_fp32=cv2.imread(img_path) # 如果模型输入要求是RGB的,则转换为RGB格式,如果要求是BGR的,则不需要转换 image_fp32=cv2.cvtColor(image_fp32, cv2.COLOR_BGR2RGB) # 缩放成模型输入大小 image_fp32 = cv2.resize(image_fp32, (model_input_size[0], model_input_size[1])) # 数据类型为float32, image_fp32 = np.asarray(image_fp32, dtype=np.float32) # 数据标准化,先归一化到[0,1]范围内,然后减均值除方差 image_fp32/=255.0 for i in range(3): image_fp32[:, :, i] -= mean
image_fp32[:, :, i] /= std # 按照模型输入要求处理成NCHW排布或者NHWC排布 image_fp32 = np.transpose(image_fp32, (2, 0, 1)) return image_fp32.copy()def get_kmodel_input(img_path,mean,std,model_input_size): # 读取图片,图片数据一般是RGB三通道,颜色范围为[0, 255.0] image_uint8=cv2.imread(img_path) # 如果模型输入要求是RGB的,则转换为RGB格式,如果要求是BGR的,则不需要转换 image_uint8=cv2.cvtColor(image_uint8, cv2.COLOR_BGR2RGB) # 缩放成模型输入大小 image_uint8 = cv2.resize(image_uint8, (model_input_size[0], model_input_size[1])) # 数据类型为uint8,因为转换kmodel的时候开启了预处理,并且设定了标准化参数,因此这里的输入就不需要实现标准化了 image_uint8 = np.asarray(image_uint8, dtype=np.uint8) # 按照模型输入要求处理成NCHW排布或者NHWC排布 image_uint8 = np.transpose(image_uint8, (2, 0, 1)) return image_uint8.copy()def onnx_inference(onnx_path,onnx_input_data): # 创建 ONNX 推理会话(加载模型) ort_session = ort.InferenceSession(onnx_path) # 获取模型输出名称列表,用于后续调用推理 output_names = [] model_outputs = ort_session.get_outputs() for i in range(len(model_outputs)): output_names.append(model_outputs.name) # 获取模型的输入信息 model_input = ort_session.get_inputs()[0] # 第一个输入(通常只有一个) model_input_name = model_input.name # 输入的名称(键) model_input_type = np.float32 # 输入数据类型,这里假设是 float32 model_input_shape = model_input.shape # 输入张量的形状(维度) # 处理输入数据,需确保和模型输入形状一致 model_input_data = onnx_input_data.astype(model_input_type).reshape(model_input_shape) # 执行推理,传入输入名称和数据,返回所有输出结果 onnx_results = ort_session.run(output_names, { model_input_name : model_input_data }) return onnx_resultsdef kmodel_inference(kmodel_path,kmodel_input_data,model_input_size): # 初始化nncase 模拟器 sim = nncase.Simulator() # 读取kmodel with open(kmodel_path, 'rb') as f: kmodel = f.read() # 加载kmodel sim.load_model(kmodel) # 读取输入数据 input_shape = [1, 3, model_input_size[1], model_input_size[0]] dtype = sim.get_input_desc(0).dtype # 处理输入数据,需确保和模型输入形状一致 kmodel_input = kmodel_input_data.astype(dtype).reshape(input_shape) # 设置模拟器输入tensor,此处为单输入 sim.set_input_tensor(0, nncase.RuntimeTensor.from_numpy(kmodel_input)) # 模拟器推理kmodel模型 sim.run() # 获取推理输出 kmodel_results = [] for i in range(sim.outputs_size): kmodel_result = sim.get_output_tensor(i).to_numpy() # 转换为numpy数组 kmodel_results.append(kmodel_result) # 保存到列表中 return kmodel_resultsdef cosine_similarity(onnx_results,kmodel_results): output_size=len(kmodel_results) # 将每个输出展成一维,然后计算余弦相似度 for i in range(output_size): onnx_i=np.reshape(onnx_results, (-1)) kmodel_i=np.reshape(kmodel_results, (-1)) cos = (onnx_i @ kmodel_i) / (np.linalg.norm(onnx_i, 2) * np.linalg.norm(kmodel_i, 2)) print('output {0} cosine similarity : {1}'.format(i, cos)) returnif __name__ == '__main__': img_path=IMG_PATH mean=MEAN std=STD model_input_size=MODEL_INPUT_SIZE # ONNX 模型文件 onnx_model = ONNX_MODEL # kmodel 模型文件 kmodel_path = KMODEL_PATH # 生成onnx模型输入数据 onnx_input_data = get_onnx_input(img_path,mean,std,model_input_size) # 生成kmodel模型输入数据 kmodel_input_data = get_kmodel_input(img_path,mean,std,model_input_size) # onnx模型推理 onnx_results = onnx_inference(onnx_model,onnx_input_data) # kmodel模型推理 nncase_results = kmodel_inference(kmodel_path,kmodel_input_data,model_input_size) # 计算输出相似度 cosine_similarity(onnx_results,nncase_results) 修改什么文件地址了
