我在使用
STM32WBA55G-DK1开发我的BLE Audio应用。我参考了ST提供的BLE_Audio_TMAP_Periopheral示例工程。
目前平板电脑连接我的应用正常,平板可以使能BLE Audio。但是当平板开始播放音乐的时候,BLE Audio协议栈上送的CAP_UNICAST_SERVER_ASE_STATE_EVT事件异常,其状态一开始是ASE_STATE_CODEC_CONFIGURED,然后是ASE_STATE_RELEASING。
作为对比,我使用BLE_Audio_TMAP_Periopheral进行测试,其CAP_UNICAST_SERVER_ASE_STATE_EVT状态是变化规律如下
ASE_STATE_CODEC_CONFIGURED->ASE_STATE_QOS_CONFIGURED->ASE_STATE_ENABLING->ASE_STATE_STREAMING。
是什么导致我的应用ASE状态没能从ASE_STATE_CODEC_CONFIGURED变迁到ASE_STATE_QOS_CONFIGURED?
下面是我的log
1204.392 CAP Event: 0x0d
1204.392 Preferred Server QoS Set
tings is requested for
ASE ID 1 (Type ASE_SINK)
1204.392 Target Latency : TARGET_LATENCY_BALANCED_RELIABILITY
1204.392 Target Phy TARGET_LE_2M_PHY to achieve the Target Latency
1204.393 Codec ID
1204.393 Coding format : AUDIO_CODING_FORMAT_LC3
1204.393 Company id : 0x0000
1204.393 VS codec id : 0x0000
1204.393 Frequency : SAMPLE_FREQ_48000_HZ
1204.393 Frame Duration : FRAME_DURATION_10_MS
1204.393 Octets Per Codec Frame : 155
1204.393 Codec Frame Blocks Per SDU : 1
1204.393 Min Controller Delay in Source role 8336 us
1204.393 Max Controller Delay in Source role 110000 us
1204.393 Min Controller Delay in Sink role 4136 us
1204.393 Max Controller Delay in Sink role 50000 us
1204.393 Calculated SDU Interval : 10000 us
1204.393 num_snk_ases:2 num_src_ases:1
1204.393 ==>> CODEC_ReadLocalSupportedControllerDelay result 0x00
1204.394 ==>> CODEC_ReadLocalSupportedControllerDelay result 0x00
1204.394 Computed Min Controller Delay with 2 Snk ASEs and 1 Src ASEs : 14608 us
1204.394 WARNING : Controller Delay Min ( 14608 us) could be higher than the frame duration (10 ms)
1204.394 Submitted Min Presentation Delay 10010 us
1204.394 Submitted Max Presentation Delay 50010 us
1204.394 CAP Event: 0x0d
1204.395 Preferred Server QoS Settings is requested for
ASE ID 2 (Type ASE_SINK)
1204.395 Target Latency : TARGET_LATENCY_BALANCED_RELIABILITY
1204.395 Target Phy TARGET_LE_2M_PHY to achieve the Target Latency
1204.395 Codec ID
1204.395 Coding format : AUDIO_CODING_FORMAT_LC3
1204.395 Company id : 0x0000
1204.396 VS codec id : 0x0000
1204.396 Frequency : SAMPLE_FREQ_48000_HZ
1204.396 Frame Duration : FRAME_DURATION_10_MS
1204.396 Octets Per Codec Frame : 155
1204.396 Codec Frame Blocks Per SDU : 1
1204.396 Min Controller Delay in Source role 8336 us
1204.396 Max Controller Delay in Source role 110000 us
1204.396 Min Controller Delay in Sink role 4136 us
1204.396 Max Controller Delay in Sink role 50000 us
1204.396 Calculated SDU Interval : 10000 us
1204.396 num_snk_ases:2 num_src_ases:1
1204.396 ==>> CODEC_ReadLocalSupportedControllerDelay result 0x00
1204.396 Computed Min Controller Delay with 2 Snk ASEs and 1 Src ASEs : 14608 us
1204.397 WARNING : Controller Delay Min ( 14608 us) could be higher than the frame duration (10 ms)
1204.397 Submitted Min Presentation Delay 10010 us
1204.397 Submitted Max Presentation Delay 50010 us
1204.397 CAP Event: 0x13
1204.397 Preferred Server Configuration for QoS Configuration:
1204.397 Framing:BAP_FRAMING_UNFRAMED
1204.397 Preferred Phy
E_2M_PHY_PREFERRED
1204.397 PrefRetransmissionNumber:2
1204.397 MaxTransportLatency:5 ms
1204.397 PresentationDelayMin:10010 us
1204.397 PresentationDelayMax:50010 us
1204.398 PrefPresentationDelayMin:10010 us
1204.398 PrefPresentationDelayMax:50010 us
1204.398 Codec specific configuration for the ASE:
1204.398 CodingFormat:AUDIO_CODING_FORMAT_LC3
CompanyID:0x00
VsCodecID:0x00
1204.398 Audio Stream Endpoint State
ASE_ID:1 Type:ASE_SINK State:ASE_STATE_CODEC_CONFIGURED
1204.399 CAP Event: 0x13
1204.399 Preferred Server Configuration for QoS Configuration:
1204.399 Framing:BAP_FRAMING_UNFRAMED
1204.399 Preferred Phy
E_2M_PHY_PREFERRED
1204.399 PrefRetransmissionNumber:2
1204.399 MaxTransportLatency:5 ms
1204.399 PresentationDelayMin:10010 us
1204.399 PresentationDelayMax:50010 us
1204.399 PrefPresentationDelayMin:10010 us
1204.399 PrefPresentationDelayMax:50010 us
1204.399 Codec specific configuration for the ASE:
1204.399 CodingFormat:AUDIO_CODING_FORMAT_LC3
CompanyID:0x00
VsCodecID:0x00
1204.400 Audio Stream Endpoint State
ASE_ID:2 Type:ASE_SINK State:ASE_STATE_CODEC_CONFIGURED
1204.630 CAP Event: 0x13
1204.631 Audio Stream Endpoint State
ASE_ID:1 Type:ASE_SINK State:ASE_STATE_RELEASING
1204.631 CAP Event: 0x13
ASE_ID:1 Type:ASE_SINK State:ASE_STATE_IDLE
ASE_ID:2 Type:ASE_SINK State:ASE_STATE_RELEASING
ASE_ID:2 Type:ASE_SINK State:ASE_STATE_IDLE
