TI论坛
直播中
哈哈哈
11年用户 963经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
ADS1293怎么把串口输出的原始数据转换为正常的心电数据?
  • 您好,我想请教的问题就是:不知道怎么进行把目前串口输出的原始数据转换为正常的心电数据。我是通过心电发生器发射心电信号到ADS1293模块,进而到主控制模块,通过串口输出ECG数据。但是这个数据跟普通看到的心电数据不是一个类型,但是我不知道怎么进行转换。
    希望有人可以及时回复我,非常感谢~!(附上有关我的3导联的部分代码)
    void ADS1293_Init_3Lead(void)
    ti_ADS1293_SPIWriteReg(0x01,0x11);//Connects channel 1¡¯s INP to IN2 and INN to IN1.
    TI_ADS1293_SPIWriteReg(0x02,0x19);// Connect channel 2¡¯s INP to IN3 and INN to IN1.
    //TI_ADS1293_SPIWriteReg(0x03,0x2E);// Connects channel 3¡¯s INP to IN5 and INN to IN6.
    TI_ADS1293_SPIWriteReg(0x0A,0x07);// Enables the common-mode detector on input pins IN1, IN2 and IN3.
    TI_ADS1293_SPIWriteReg(0x0C,0x04);//Connects the output of the RLD amplifier internally to pin IN4.
    //Connects the first buffer of the Wilson reference to the IN1 pin, the second buffer to the IN2 pin, and the third buffer to the IN3 pin.
    //TI_ADS1293_SPIWriteReg(0x0D,0x01);
    // TI_ADS1293_SPIWriteReg(0x0E,0x02);
    //TI_ADS1293_SPIWriteReg(0x0F,0x03);
    // TI_ADS1293_SPIWriteReg(0x10,0x01);//Connects the output of the Wilson reference internally to IN6.
    TI_ADS1293_SPIWriteReg(0x12,0x04);// Uses external crystal and feeds the output of the internal oscillator module to the digital.
    TI_ADS1293_SPIWriteReg(0x21,0x02);// Configures the R2 decimation rate as 5 for all channels.
    TI_ADS1293_SPIWriteReg(0x22,0x02);//Configures the R3 decimation rate as 6 for channel 1.
    TI_ADS1293_SPIWriteReg(0x23,0x02);//Configures the R3 decimation rate as 6 for channel 2.
    TI_ADS1293_SPIWriteReg(0x24,0x02);//Configures the R3 decimation rate as 6 for channel 3.
    TI_ADS1293_SPIWriteReg(0x27,0x08);//Configures the DRDYB source to ECG channel 1 (or fastest channel).
    TI_ADS1293_SPIWriteReg(0x2F,0x30);// Enables channel 1 ECG and channel 2 ECG for loop read-back mode.
    TI_ADS1293_SPIWriteReg(0x00,0x01);//Starts data conversion.
    void ti_ads1293_stream_read(unsigned char *buff)
    for(int i=0;i<10;i++)
    buff = ti_ads1293_read_reg(0x50);
    for(int j=0;j<16;j++)
    board_spi_cs_set(0);
    delay_us(50);
    board_spi_cs_set(1);
    delay_us(50);
    for(int j=0;j<(8+8*10);j++)
    delay_us(50);
    delay_us(50);
    void ti_ads1293_read_ecg(unsigned int *ecg)
    unsigned char buff[10] = {0};
    if(ecg == NULL)
    return;
    for(int i=0;i<9;i++){
    buff = ti_ads1293_read_reg(0x37 + i);
    ecg[0] = buff[0]*65536 + buff[1]*256 + buff[2];
    ecg[1] = buff[3]*65536 + buff[4]*256 + buff[5];
    ecg[2] = buff[6]*65536 + buff[7]*256 + buff[8];
回帖(1)
小小
2024-12-12 09:21:14
您好!要将串口输出的原始数据转换为正常的心电数据,您需要进行以下步骤:
1. 读取原始数据:首先,您需要从串口读取原始数据。这通常是一个二进制格式的数据,表示心电信号的电压值。
2. 数据格式转换:将二进制数据转换为可读的数值。这通常涉及到位操作和位移。例如,如果您的数据是16位的,您可能需要将高8位和低8位分别提取出来,然后将它们组合成一个16位的整数。
3. 单位转换:将电压值转换为心电信号的单位(通常是毫伏)。这通常涉及到乘以一个比例因子。例如,如果ADS1293的增益设置为1,那么原始数据的单位就是毫伏。
4. 滤波:心电信号通常包含噪声,因此需要进行滤波处理。您可以使用低通滤波器、带通滤波器或高通滤波器来去除不需要的频率成分。
5. 基线漂移校正:心电信号可能会受到基线漂移的影响,因此需要进行校正。这通常涉及到找到一个合适的基线,并将其从信号中减去。
6. 显示或存储:最后,您可以将处理后的心电数据显示在屏幕上或存储在文件中。
以下是一个简化的示例代码,展示了如何将原始数据转换为心电数据:
```c
#include
// 假设原始数据是16位的,单位是毫伏
int read_raw_data() {
    // 从串口读取原始数据
    return raw_data;
int main() {
    int raw_data = read_raw_data();
    int ecg_data;
    // 数据格式转换
    ecg_data = (raw_data >> 8) | (raw_data << 8);
    // 单位转换(假设增益为1)
    ecg_data = ecg_data * 1.0; // 这里只是一个示例,实际比例因子可能不同
    // 滤波、基线漂移校正等处理
    // 显示或存储心电数据
    printf("ECG Data: %dn", ecg_data);
    return 0;
请注意,这只是一个简化的示例,实际的数据处理可能需要更复杂的算法和库。希望这对您有所帮助!
举报
更多回帖
