TI论坛
直播中
案发当时
5年用户 6经验值
擅长:可编程逻辑
私信 关注
[问答]
LMX2595EVM焊接后的成品相噪没有达到EVM板的水准怎么处理?
  • 你好,我们在按照LMX2595EVM板进行了一个信号源的设计时,原理图参考EVM板设计,但是在焊接时由于工作人员操作水平较低,导致焊接后的成品相噪没有达到EVM板的水准,请问,焊接工艺有何建议,后者在不规范的焊接工艺下有没有什么调整可以弱化焊接做相噪带来的恶化。(补焊人员已经崩溃类目)。
weibo.com/ttarticle/p/show?id=2309405100948438515855
weibo.com/ttarticle/p/show?id=2309405100948837236856
weibo.com/ttarticle/p/show?id=2309405100948556218448
weibo.com/ttarticle/p/show?id=2309405100948581384425
weibo.com/ttarticle/p/show?id=2309405100948795294104
weibo.com/ttarticle/p/show?id=2309405100948497235983
weibo.com/ttarticle/p/show?id=2309405100948283588836
weibo.com/ttarticle/p/show?id=2309405100948656619596
weibo.com/ttarticle/p/show?id=2309405100948753351129
weibo.com/ttarticle/p/show?id=2309405100948719796398
weibo.com/ttarticle/p/show?id=2309405100948736573949
weibo.com/ttarticle/p/show?id=2309405100948287783138
weibo.com/ttarticle/p/show?id=2309405100948606550382
weibo.com/ttarticle/p/show?id=2309405100948686241931
weibo.com/ttarticle/p/show?id=2309405100948640104658
weibo.com/ttarticle/p/show?id=2309405100948702756971
weibo.com/ttarticle/p/show?id=2309405100948707213755
weibo.com/ttarticle/p/show?id=2309405100948367474816
weibo.com/ttarticle/p/show?id=2309405100948602093576
weibo.com/ttarticle/p/show?id=2309405100948551762043
weibo.com/ttarticle/p/show?id=2309405100948539441182
weibo.com/ttarticle/p/show?id=2309405100948531052798
weibo.com/ttarticle/p/show?id=2309405100948501692711
weibo.com/ttarticle/p/show?id=2309405100948543635679
weibo.com/ttarticle/p/show?id=2309405100948488847507
weibo.com/ttarticle/p/show?id=2309405100948295909381
weibo.com/ttarticle/p/show?id=2309405100948505624697
weibo.com/ttarticle/p/show?id=2309405100948442972660
weibo.com/ttarticle/p/show?id=2309405100948468138392
weibo.com/ttarticle/p/show?id=2309405100947876479141
weibo.com/ttarticle/p/show?id=2309405100948220411972
weibo.com/ttarticle/p/show?id=2309405100948401029278
weibo.com/ttarticle/p/show?id=2309405100948346503204
weibo.com/ttarticle/p/show?id=2309405100948430389555
weibo.com/ttarticle/p/show?id=2309405100948392640814
weibo.com/ttarticle/p/show?id=2309405100948342309190
weibo.com/ttarticle/p/show?id=2309405100948354891938
weibo.com/ttarticle/p/show?id=2309405100948338114916
weibo.com/ttarticle/p/show?id=2309405100948082262281
weibo.com/ttarticle/p/show?id=2309405100947776078140
weibo.com/ttarticle/p/show?id=2309405100948258423079
weibo.com/ttarticle/p/show?id=2309405100948132593863
weibo.com/ttarticle/p/show?id=2309405100948229062862
weibo.com/ttarticle/p/show?id=2309405100948124205100
weibo.com/ttarticle/p/show?id=2309405100948241645693
weibo.com/ttarticle/p/show?id=2309405100948182925517
weibo.com/ttarticle/p/show?id=2309405100947725746307
weibo.com/ttarticle/p/show?id=2309405100948186857513
weibo.com/ttarticle/p/show?id=2309405100948203897013
weibo.com/ttarticle/p/show?id=2309405100948237189171
weibo.com/ttarticle/p/show?id=2309405100947998376300
weibo.com/ttarticle/p/show?id=2309405100948099039387
weibo.com/ttarticle/p/show?id=2309405100948086456463
weibo.com/ttarticle/p/show?id=2309405100948136788293
weibo.com/ttarticle/p/show?id=2309405100947725746462
weibo.com/ttarticle/p/show?id=2309405100948111360135
weibo.com/ttarticle/p/show?id=2309405100948065222683
weibo.com/ttarticle/p/show?id=2309405100947667026048
weibo.com/ttarticle/p/show?id=2309405100948061028431
weibo.com/ttarticle/p/show?id=2309405100943724380245
weibo.com/ttarticle/p/show?id=2309405100947906101642
weibo.com/ttarticle/p/show?id=2309405100948036124696
weibo.com/ttarticle/p/show?id=2309405100947939655777
weibo.com/ttarticle/p/show?id=2309405100948031930414
weibo.com/ttarticle/p/show?id=2309405100947981599141
weibo.com/ttarticle/p/show?id=2309405100948014891018
weibo.com/ttarticle/p/show?id=2309405100947788398753
weibo.com/ttarticle/p/show?id=2309405100947981598917
weibo.com/ttarticle/p/show?id=2309405100947948044504
weibo.com/ttarticle/p/show?id=2309405100947830604084
weibo.com/ttarticle/p/show?id=2309405100947931267399
weibo.com/ttarticle/p/show?id=2309405100947927073046
weibo.com/ttarticle/p/show?id=2309405100947931267311
weibo.com/ttarticle/p/show?id=2309405100947931267200
weibo.com/ttarticle/p/show?id=2309405100947797049492
weibo.com/ttarticle/p/show?id=2309405100947880673345
weibo.com/ttarticle/p/show?id=2309405100947880935522
weibo.com/ttarticle/p/show?id=2309405100947893256210
weibo.com/ttarticle/p/show?id=2309405100947880935462
weibo.com/ttarticle/p/show?id=2309405100947776078202
weibo.com/ttarticle/p/show?id=2309405100947838730303
weibo.com/ttarticle/p/show?id=2309405100947239207572
weibo.com/ttarticle/p/show?id=2309405100947830603903
weibo.com/ttarticle/p/show?id=2309405100947658637499
weibo.com/ttarticle/p/show?id=2309405100947826409657
weibo.com/ttarticle/p/show?id=2309405100947780009997
weibo.com/ttarticle/p/show?id=2309405100947725746343
weibo.com/ttarticle/p/show?id=2309405100947742523531
weibo.com/ttarticle/p/show?id=2309405100947775815821
weibo.com/ttarticle/p/show?id=2309405100947776078044
weibo.com/ttarticle/p/show?id=2309405100947302121691
weibo.com/ttarticle/p/show?id=2309405100947440533710
weibo.com/ttarticle/p/show?id=2309405100947692191850
weibo.com/ttarticle/p/show?id=2309405100947675414815
weibo.com/ttarticle/p/show?id=2309405100947654443476
weibo.com/ttarticle/p/show?id=2309405100947163709789
weibo.com/ttarticle/p/show?id=2309405100947482476796
weibo.com/ttarticle/p/show?id=2309405100946782027935
回帖(1)
tulin
2024-11-18 11:45:38
针对您的问题,我将提供一些建议来帮助您解决焊接工艺问题以及如何弱化焊接对相噪的影响。以下是一些建议:
1. 焊接工艺建议:
   a. 使用合适的焊接工具:确保使用合适的焊接工具,如恒温烙铁、焊锡丝和助焊剂。
   b. 保持烙铁温度适中:过高的烙铁温度可能导致焊点氧化,影响性能。建议将烙铁温度保持在300-350摄氏度。
   c. 焊接时间控制:焊接时间不宜过长,以免损坏元件。一般建议焊接时间为2-3秒。
   d. 焊接技巧:使用正确的焊接技巧,如拖焊法和点焊法,以减少焊接过程中的热应力。
   e. 检查焊接质量:焊接完成后,仔细检查焊点,确保焊点光滑、无氧化、无虚焊。
2. 弱化焊接对相噪的影响:
   a. 优化PCB布局:优化PCB布局,减少信号线之间的干扰,降低噪声。
   b. 增加地线:在PCB上增加地线,以减少地线阻抗,降低噪声。
   c. 使用屏蔽:在敏感信号线周围增加屏蔽层,以减少外部干扰。
   d. 优化电源设计:优化电源设计,确保电源稳定性,降低电源噪声对相噪的影响。
   e. 调整元件参数:根据实际情况调整元件参数,如电容、电阻等,以降低相噪。
希望以上建议能对您有所帮助。如果问题仍然存在,建议您寻求专业人士的帮助,或者联系LMX2595EVM板的制造商,以获取更专业的技术支持。
举报
更多回帖
