TI论坛
直播中
邹俩珍
8年用户 1113经验值
私信 关注
[问答]
aic23在debug的时候,点击暂停依然会播放声音,为什么?
[list]
[*]我测试了一下5509的codec程序,playmode选择为1,通过line in 输入,phone out输出声音,语音芯片为aic23,在debug的时候,点击暂停,依然会播放声音?还有如何将mcbsp的内容写到dma的rcv里面和将dma的xmt内容写到mcbsp上?如何让AIC23播放DMA的xmt里面的内容?
下面是程序代码
/* DESCRIPtiON:                   */
/* This is an example for EMIF of C5509            */
/* MODULE NAME... I2C and Mcbsp              */
/* FILENAME...... codec.c                 */
/* DATE CREATED.. Mon 02/4/2004                 */
/* COMPONENT.....                  */
/* PREREQUISITS..                  */
/* DESCRIPTION:                  */
/* this example is that the codec is controled by the I2C and Mcbsp     */
#include
#include
#include
#include
#include
#define CODEC_ADDR 0x1A
/*锁相环的设置*/
PLL_Config  myConfig      = {
  0,    //IAI: the PLL locks using the same process that was underway
                //before the idle mode was entered
  1,    //IOB: If the PLL indicates a break in the phase lock,
                //it switches to its bypass mode and restarts the PLL phase-locking
                //sequence
  12,    //PLL multiply value; multiply 24 times
  1             //Divide by 2 PLL divide value; it can be either PLL divide value
                //(when PLL is enabled), or Bypass-mode divide value
                //(PLL in bypass mode, if PLL multiply value is set to 1)
unsigned int play_mode;   // 0:play     1:record and play
MCBSP_Config Mcbsptest;
/*McBSP set,we use mcbsp1 to send and recieve the data between DSP and AIC23*/
MCBSP_Config Mcbsp1Config = {
  MCBSP_SPCR1_RMK(
    MCBSP_SPCR1_DLB_OFF,                   /* DLB    = 0,禁止自闭环方式 */
    MCBSP_SPCR1_RJUST_LZF,                 /* RJUST  = 2 */
    MCBSP_SPCR1_CLKSTP_DISABLE,            /* CLKSTP = 0 */
    MCBSP_SPCR1_DXENA_ON,                  /* DXENA  = 1 */
    0,                                     /* ABIS   = 0 */
    MCBSP_SPCR1_RINTM_RRDY,                /* RINTM  = 0 */
    0,                                     /* RSYNCER = 0 */
    MCBSP_SPCR1_RRST_DISABLE               /* RRST   = 0 */
    MCBSP_SPCR2_RMK(
    MCBSP_SPCR2_FREE_NO,                   /* FREE   = 0 */
    MCBSP_SPCR2_SOFT_NO,                   /* SOFT   = 0 */
    MCBSP_SPCR2_FRST_FSG,                  /* FRST   = 0 */
    MCBSP_SPCR2_GRST_CLKG,                 /* GRST   = 0 */
    MCBSP_SPCR2_XINTM_XRDY,                /* XINTM  = 0 */
    0,                                     /* XSYNCER = N/A */
    MCBSP_SPCR2_XRST_DISABLE               /* XRST   = 0 */
   /*单数据相,接受数据长度为16位,每相2个数据*/
  MCBSP_RCR1_RMK(
   MCBSP_RCR1_RFRLEN1_OF(1),              /* RFRLEN1 = 1 */
   MCBSP_RCR1_RWDLEN1_16BIT               /* RWDLEN1 = 2 */
  MCBSP_RCR2_RMK(
    MCBSP_RCR2_RPHASE_SINGLE,              /* RPHASE  = 0 */
    MCBSP_RCR2_RFRLEN2_OF(0),              /* RFRLEN2 = 0 */
    MCBSP_RCR2_RWDLEN2_8BIT,               /* RWDLEN2 = 0 */
    MCBSP_RCR2_RCOMPAND_MSB,               /* RCOMPAND = 0 */
    MCBSP_RCR2_RFIG_YES,                   /* RFIG    = 0 */
    MCBSP_RCR2_RDATDLY_1BIT                /* RDATDLY = 1 */
   MCBSP_XCR1_RMK(
    MCBSP_XCR1_XFRLEN1_OF(1),              /* XFRLEN1 = 1 */
    MCBSP_XCR1_XWDLEN1_16BIT               /* XWDLEN1 = 2 */
MCBSP_XCR2_RMK(
    MCBSP_XCR2_XPHASE_SINGLE,              /* XPHASE  = 0 */
    MCBSP_XCR2_XFRLEN2_OF(0),              /* XFRLEN2 = 0 */
    MCBSP_XCR2_XWDLEN2_8BIT,               /* XWDLEN2 = 0 */
    MCBSP_XCR2_XCOMPAND_MSB,               /* XCOMPAND = 0 */
    MCBSP_XCR2_XFIG_YES,                   /* XFIG    = 0 */
    MCBSP_XCR2_XDATDLY_1BIT                /* XDATDLY = 1 */
MCBSP_SRGR1_DEFAULT,
MCBSP_SRGR2_DEFAULT,
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
   MCBSP_PCR_IDLEEN_RESET,                 /* IDLEEN   = 0   */
   MCBSP_PCR_XIOEN_SP,                     /* XIOEN    = 0   */
   MCBSP_PCR_RIOEN_SP,                     /* RIOEN    = 0   */
   MCBSP_PCR_FSXM_EXTERNAL,                /* FSXM     = 0   */
   MCBSP_PCR_FSRM_EXTERNAL,                /* FSRM     = 0   */
   0,                                      /* DXSTAT = N/A   */
   MCBSP_PCR_CLKXM_INPUT,                  /* CLKXM    = 0   */
   MCBSP_PCR_CLKRM_INPUT,                  /* CLKRM    = 0   */
   MCBSP_PCR_SCLKME_NO,                    /* SCLKME   = 0   */
   MCBSP_PCR_FSXP_ACTIVEHIGH,              /* FSXP     = 0   */
   MCBSP_PCR_FSRP_ACTIVEHIGH,              /* FSRP     = 1   */
   MCBSP_PCR_CLKXP_FALLING,                /* CLKXP    = 1   */
   MCBSP_PCR_CLKRP_RISING                  /* CLKRP    = 1   */
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/* This next struct shows how to use the I2C API */
/* Create and initialize an I2C initialization structure */
I2C_Setup I2Cinit = {
        0,              /* 7 bit address mode */
        0,         /* own address - don't care if master */
        84,            /* clkout value (Mhz)  */
        50,            /* a number between 10 and 400*/
        0,              /* number of bits/byte to be received or transmitted (8)*/
        0,              /* DLB mode on*/
        1               /* FREE mode of operation on*/
I2C_Config testI2C;
/*数字音频接口格式设置
AIC23为主模式,数据为DSP模式,数据长度16位*/
Uint16 digital_audio_inteface_format[2]={0x0e,0x53};
/*AIC23的波特率设置,采样率为44.1K*/
Uint16 sample_rate_control[2] = {0x10,0x23};
/*AIC23寄存器复位*/
Uint16 reset[2] ={0x1e,0x00};
/*AIC23节电方式设置,所有部分均所与工作状态*/
Uint16 power_down_control[2] ={0x0c,0x03};
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为Line*/
Uint16 analog_aduio_path_control[2] ={0x08,0x10};
/*AIC23数字音频通路的控制*/
Uint16 digital_audio_path_control[2] ={0x0a,0x05};
/*AIC23数字接口的使能*/
Uint16 digital_interface_activation[2] ={0x12,0x01};
/*AIC23左通路音频调节*/
Uint16 left_line_input_volume_control[2] ={0x00,0x17};
/*AIC23右通路音频调节*/
Uint16 right_line_input_volume_control[2] ={0x02,0x17};
/*AIC23耳机左通路音频调节*/
Uint16 left_headphone_volume_control[2] ={0x05,0xFF};
/*AIC23耳机右通路音频调节*/
Uint16 right_headphone_volume_control[2] = {0x07,0xFF};
/*定义McBSP的句柄*/
MCBSP_Handle hMcbsp;
Uint16 i2c_status;
Uint16 i,temp;
void delay(Uint32 k)
   while(k--);
void main(void)
    Uint16 aic23data = 0;
i2c_status = 1;
play_mode=1;
    /* Initialize CSL library - This is REQUIRED !!! */
    /*初始化CSL库*/
    CSL_init();
/*设置系统的运行速度为140MHz*/
    PLL_config(&myConfig);
    /* Initialize I2C, using parameters in init structure */
    /*初始化I2C的格式*/
// I2C_config(&Config);
// I2C_start();
// I2C_getConfig(&Config1);
/*I2C is undet reset*/
I2C_RSET(I2CMDR,0);
/*设置预分频寄存器,I2C的mode clock is 10MHz*/
delay(100);
I2C_RSET(I2CSAR,0x001A);
I2C_RSET(I2CMDR,0x0620);
    I2C_setup(&I2Cinit);
   /*设置I2C的Mater clock*/
I2C_RSET(I2CCLKL,100);
I2C_RSET(I2CCLKH,100);
    I2C_getConfig(&testI2C);
/*初始化McBSP0*/
hMcbsp = MCBSP_open(MCBSP_PORT1,MCBSP_OPEN_RESET);
/*设置McBSP0*/
MCBSP_config(hMcbsp,&Mcbsp1Config);
/*启动McBSP0*/
MCBSP_start(hMcbsp,
                MCBSP_RCV_START | MCBSP_XMIT_START,
                0);
    MCBSP_getConfig(hMcbsp,&Mcbsptest);
    /*reset AIC23*/
    i2c_status = I2C_write( reset,          //pointer to data array
                      2,    //length of data to be transmitted
                      1,    //master or slaver
                      CODEC_ADDR,     //slave address to transmit to
                      1,    //transfer mode of operation
                      30000   //time out for bus busy
delay(1000);
    /*设置AIC23各部分均工作*/
    i2c_status = I2C_write( power_down_control,//pointer to data array
/*设置AIC23的数字接口*/
i2c_status = I2C_write( digital_audio_inteface_format,//pointer to data array
  /*设置AIC23模拟通路*/
/* i2c_status = I2C_write( analog_aduio_path_control,//pointer to data array
/*设置数字通路*/
i2c_status = I2C_write( digital_audio_path_control,//pointer to data array
/*设置AIC23的采样率*/
i2c_status = I2C_write( sample_rate_control,//pointer to data array
/*设置耳机音量*/
i2c_status = I2C_write( left_headphone_volume_control,//pointer to data array
i2c_status = I2C_write( right_headphone_volume_control,//pointer to data array
/*设置Line输入的音量*/
i2c_status = I2C_write( left_line_input_volume_control,//pointer to data array
i2c_status = I2C_write( right_line_input_volume_control,//pointer to data array
/*启动AIC23*/
i2c_status = I2C_write( digital_interface_activation,//pointer to data array
/*回放音频*/
while(TRUE)
if(play_mode==1)  //record and play
  while(!MCBSP_xrdy(hMcbsp)){};
  aic23data = MCBSP_read16(hMcbsp);
  for(temp=3000;temp>0;temp--);
  while(!MCBSP_rrdy(hMcbsp)){};
  MCBSP_write16(hMcbsp,aic23data);
else
  aic23data = 5000;
  for(temp=30000;temp>0;temp-=100)
         for(i=0;i<2;i++)
           aic23data = 5000;
           delay(temp);
           aic23data = 0;
           delay(temp);
  //MCBSP_write16(hMcbsp,aic23data);
void Delay(unsigned int nDelay)
unsigned int ii,jj,kk=0;
for ( ii=0;ii
回帖(2)
王希予
2024-11-1 11:06:31
暂停后依然会播放声音?  要不命令没有执行, 要么是数据缓冲的问题.因为播放芯片的缓冲里还留有一定的数据可以继续播放一会
举报
王霞
2024-11-1 18:12:02
根据您的描述,您在使用AIC23语音芯片进行调试时,即使点击暂停,声音仍然播放。这可能是因为您的程序没有正确处理暂停信号。以下是一些建议和解决方案:
1. 确保您的程序正确处理暂停信号。在您的代码中,您需要检查暂停信号的状态,并在检测到暂停信号时停止播放声音。例如,您可以使用一个全局变量来存储暂停状态,并在播放声音时检查该变量。
```c
volatile int pause_flag = 0;
void play_sound() {
    while (1) {
        if (pause_flag) {
            // 暂停播放声音
            break;
        // 播放声音的代码
2. 将MCBSP的内容写入DMA的RCV:
您需要配置MCBSP和DMA,以便将MCBSP的数据传输到DMA的接收缓冲区。以下是配置MCBSP和DMA的示例代码:
```c
// 配置MCBSP
mcbsp_config_t mcbsp_config = {
    .sample_rate = 44100,
    .word_length = 16,
    .serial_format = MCBSP_SERIAL_FORMAT_I2S,
    .clock_polarity = MCBSP_CLOCK_POLARITY_LOW,
    .clock_phase = MCBSP_CLOCK_PHASE_SINGLE,
    .frame_sync_width = 32,
    .frame_sync_polarity = MCBSP_FRAME_SYNC_POLARITY_LOW,
    .frame_sync_delay = 1,
    .clkx_div = 1,
    .clkr_div = 1
mcbsp_init(&mcbsp_config);
// 配置DMA
dma_config_t dma_config = {
    .channel = DMA_CHANNEL_0,
    .transfer_mode = DMA_TRANSFER_MODE_PERIPHERAL,
    .source_address = (uint32_t)&mcbsp->rx_buffer,
    .destination_address = (uint32_t)&dma_rcv_buffer,
    .transfer_size = 1024,
    .source_burst_length = 1,
    .destination_burst_length = 1,
    .source_data_width = DMA_DATA_WIDTH_16,
    .destination_data_width = DMA_DATA_WIDTH_16,
    .source_burst_step = 0,
    .destination_burst_step = 0,
    .source_transfer_step = 1,
    .destination_transfer_step = 1,
    .arbitration_rate = DMA_ARBITRATION_RATE_1,
    .source_peripheral = DMA_PERIPHERAL_MCBSP_RX,
    .destination_peripheral = DMA_PERIPHERAL_NONE
dma_init(&dma_config);
3. 将DMA的XMT内容写入MCBSP:
您需要配置MCBSP和DMA,以便将DMA的发送缓冲区的数据传输到MCBSP。以下是配置MCBSP和DMA的示例代码:
```c
// 配置MCBSP
    .word_length = 16,
    .clkx_div = 1,
    .clkr_div = 1
// 配置DMA
    .channel = DMA_CHANNEL_1,
    .source_address = (uint32_t)&dma_xmt_buffer,
    .destination_address = (uint32_t)&mcbsp->tx_buffer,
    .source_peripheral = DMA_PERIPHERAL_NONE,
    .destination_peripheral = DMA_PERIPHERAL_MCBSP_TX
4. 让AIC23播放DMA的XMT里面的内容:
您需要将DMA的发送缓冲区的数据传输到AIC23。以下是示例代码:
```c
// 将DMA的发送缓冲区的数据传输到AIC23
aic23_config_t aic23_config = {
    .word_length = 16,
    .serial_format = AIC23_SERIAL_FORMAT_I2S,
    .clock_polarity = AIC23_CLOCK_POLARITY_LOW,
    .clock_phase = AIC23_CLOCK_PHASE_SINGLE
举报
更多回帖
