TI论坛
直播中
张桂英
7年用户 1538经验值
私信 关注
[问答]
TLV320AIC3104安装snd-soc-tlv320aic3x-i2c.ko模块失败,无法aplay音频怎么解决?
  • 你好,我升级到linux5.15.71配置声卡的时候,选配了snd-soc-tlv320aic3x.ko 和 snd-soc-tlv320aic3x-i2c.ko 模块,安装完成后
    ls /dev/snd/ by-path controlC0 pcmC0D0c pcmC0D0p timer
    但是安装完模块后 i2c命令无法使用,不安装模块时都是可以使用的
    # i2cdump -y -f 0 0x18
    No size specified (using byte-data access)
    0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
    00: XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XXXXXXXXXXXXXXXX
    无论是播放还是录制音频都是显示这种信息
    c# aplay sine.wav
    Playing WAVE 'sine.wav' : Signed 32 bit Little Endian, Ra[ 1101.900499] fsl-sai 2028000.sai: failed to derive required Tx rate: 2822400
    te 44100 Hz, Stereo
    [ 1101.909754] fsl-sai 2028000.sai: ASoC: error at snd_soc_dai_hw_params on 2028000.sai: -22
    [ 1101.923524] 2028000.sai-tlv320aic3x-hifi: ASoC: soc_pcm_hw_params() failed (-22)
    aplay: set_params:1297: Unable to install hw params:
    ACCESS: RW_INTERLEAVED
    FORMAT: S32_LE
    SUBFORMAT: STD
    SAMPLE_BITS: 32
    FRAME_BITS: 64
    CHANNELS: 2
    RATE: 44100
    PERIOD_TIME: (125011 125012)
    PERIOD_SIZE: 5513
    PERIOD_BYTES: 44104
    PERIODS: 4
    BUFFER_TIME: (500045 500046)
    BUFFER_SIZE: 22052
    BUFFER_BYTES: 176416
    TICK_TIME: 0
    在我安装模块时,有这样一个错误
    # insmod snd-soc-tlv320aic3x-i2c.ko
    [ 327.413410] tlv320aic3x 0-0018: Unsuitable MicBias voltage found in DT
    下面是我的相关设备树配置
            sound {                compatible = "simple-audio-card";                simple-audio-card,name = "tlv320aic3104";                simple-audio-card,format = "i2s";                simple-audio-card,mclk-fs = <256>;                simple-audio-card,bitclock-master = <&dailink0_master>;                simple-audio-card,frame-master = <&dailink0_master>;                simple-audio-card,widgets =                        "Microphone", "Microphone Jack",                        "Headphone", "Headphone Jack",                        "Speaker", "External Speaker",                        "Line", "Line Out",                        "Line", "Line In";                ,routing =                        "MIC_IN", "Microphone Jack",                        "Headphone Jack", "HP_OUT",                        "LINE1L", "Line In",                        "LINE1R", "Line In",                        "Headphone Jack", "RLOUT",                        "Headphone Jack", "LLOUT";                dailink0_master:simple-audio-card,cpu {                        sound-dai = <&sai1 0>;                };                simple-audio-card,codec {                        sound-dai = <&codec 0>;                        // clocks = <&clks IMX6UL_CLK_SAI1>;                };        };        &sai1 {        #sound-dai-cells = <0>;        pinctrl-names = "default";        pinctrl-0 = <&pinctrl_sai1>;        assigned-clocks = <&clks IMX6UL_CLK_SAI1_SEL>,                          <&clks IMX6UL_CLK_SAI1>;        assigned-clock-parents = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;        assigned-clock-rates = <2>, <24576000>;        status = "okay";};&i2c1 {        clock-frequency = <100000>;        pinctrl-names = "default";        pinctrl-0 = <&pinctrl_i2c1>;        status = "okay";                codec: tlv320aic3104@18 {                #sound-dai-cells = <0>;                compatible = "ti,tlv320aic3104";                reg = <0x18>;                gpio-reset = <&gpio1 26 GPIO_ACTIVE_LOW>;                ai3x-micbias-vg = <0>;                /* Regulators */                DRVDD-supply = <®_3p3v>;                AVDD-supply = <®_3p3v>;                IOVDD-supply = <®_3p3v>;                DVDD-supply = <®_1p8v>;                status = "okay";        };请问我是哪里没配置,还有有什么配置错误呢?menuconfig里面选配那些
更多回帖
