TI论坛
直播中
李宛蔓
7年用户 981经验值
私信 关注
[问答]
PGA113程序驱动, 电压一直放不大是怎么回事?
  • 驱动程序如下   电压一直放不大  找不到程序哪有问题
    #include "PGA.h"
    void PGA_GPIOInit(void)
    SPI_InitTypeDef SPI_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    /* 使能SPI时钟 */
    PGA_SPI_APBxClock_FUN ( PGA_SPI_CLK, ENABLE );
    /* 使能SPI引脚相关的时钟 */
    PGA_SPI_CS_APBxClock_FUN ( PGA_SPI_CS_CLK|PGA_SPI_SCK_CLK|
    PGA_SPI_MOSI_PIN, ENABLE );
    /* 配置SPI的 CS引脚,普通IO即可 */
    GPIO_InitStructure.GPIO_Pin = PGA_SPI_CS_PIN;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(PGA_SPI_CS_PORT, &GPIO_InitStructure);
    /* 配置SPI的 SCK引脚*/
    GPIO_InitStructure.GPIO_Pin = PGA_SPI_SCK_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(PGA_SPI_SCK_PORT, &GPIO_InitStructure);
    /* 配置SPI的 MOSI引脚*/
    GPIO_InitStructure.GPIO_Pin = PGA_SPI_MOSI_PIN;
    GPIO_Init(PGA_SPI_MOSI_PORT, &GPIO_InitStructure);
    /* 停止信号 PGA: CS引脚高电平*/
    SPI_PGA_CS_HIGH();
    /* SPI 模式配置 */
    SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(PGA_SPIx , &SPI_InitStructure);
    /* 使能 SPI */
    SPI_Cmd(PGA_SPIx , ENABLE);
    void SPI_PAG_SendData (uint8_t data)
    time_out = 10000;
    while(SPI_I2S_GetFlagStatus( SPI2,SPI_I2S_FLAG_TXE) == SET)
    SPI_I2S_SendData(SPI2,data);
    static void Delay(__IO uint32_t nCount)
    for(; nCount != 0; nCount--);
    void WriteByte(u8 command)
    unsigned char i;
    SPI_PGA_CS_LOW();
    Delay(0xffffee);
    for(i = 0; i < 16;i++)
    SPI_PGA_SCK_LOW();
    if(command&0x80)
    SPI_PGA_MOSI_HIGH();
    else
    SPI_PGA_MOSI_LOW();
    SPI_PGA_SCK_HIGH();
    command <<= 1;
    SPI_PGA_SCK_LOW();
    Delay(0xffffee);
    SPI_PGA_CS_HIGH();
    void configPGA(u8 ch,u8 gain)
    unsigned char i;
    switch(gain)
    case 1: gain=pgaGain1;
    break;
    case 2: gain=pgaGain2;
    break;
    case 4: gain=pgaGain4;
    break;
    case 8: gain=pgaGain8;
    break;
    case 16: gain=pgaGain16;
    break;
    case 32: gain=pgaGain32;
    break;
    case 64: gain=pgaGain64;
    break;
    case 128: gain=pgaGain128;
    break;
    default: gain=pgaGain2;
    break;
    i=ch+gain;
    SPI_PGA_CS_LOW();
    WriteByte(0x01);
    WriteByte(i);
    SPI_PGA_CS_HIGH();
更多回帖
