乐鑫技术交流
直播中
张览秀
9年用户 1239经验值
擅长:可编程逻辑 电源/新能源
私信 关注
[问答]
请问iOS集成后报No route to host和isSuc: NO,isCancelled: NO,bssid: (null)怎么解决呢?
下面是具体的log,手机系统是ios11,帮忙看下,谢谢了
2018-01-04 10:49:54.667335+0800 newDemo[1298:368864] [Accessibility] ****************** Loading GAX Client Bundle ****************
2018-01-04 10:49:54.750645+0800 newDemo[1298:368864] udpBroadcast
2018-01-04 10:49:54.757363+0800 newDemo[1298:368864] udpSocket
2018-01-04 10:49:54.757400+0800 newDemo[1298:368864] udpSocket didReceiveData -- hlkAT at+mac=?
2018-01-04 10:49:54.757451+0800 newDemo[1298:368864] udpSocket
2018-01-04 10:49:54.757463+0800 newDemo[1298:368864] udpSocket didReceiveData -- hlkAT at+mac=?
2018-01-04 10:49:54.772867+0800 newDemo[1298:368930] ssid:1110,pw:Vlifeaper,bssid:be:5f:f6:14:a3:fa
2018-01-04 10:49:54.773289+0800 newDemo[1298:368930] ESPTouchTask init
2018-01-04 10:49:54.773617+0800 newDemo[1298:368930] ##########################client init() _sck_fd=5
2018-01-04 10:49:54.773759+0800 newDemo[1298:368930] ##########################server init(): _sck_fd=6
2018-01-04 10:49:54.774451+0800 newDemo[1298:368930] ESP_NetUtil:: 10.1.10.76
2018-01-04 10:49:54.774488+0800 newDemo[1298:368930] ESPTouchTask executeForResult() localInetAddr: 10.1.10.76
2018-01-04 10:49:54.775382+0800 newDemo[1298:368930] ESPTouchTask __execute() send gc code
2018-01-04 10:49:54.775663+0800 newDemo[1298:368929] ESPTouchTask __listenAsyn() start an asyn listen task, current thread is: {number = 5, name = (null)}
2018-01-04 10:49:54.775690+0800 newDemo[1298:368929] ESPTouchTask __listenAsyn() expectOneByte: 22
client: sendto fail, but just ignore it
: No route to host
: No route to host
: No route to host
: No route to host
2018-01-04 10:50:39.781791+0800 newDemo[1298:368930] ESPTouchTask __sleep() start
2018-01-04 10:50:44.751230+0800 newDemo[1298:368864] udpBroadcast
2018-01-04 10:50:49.751192+0800 newDemo[1298:368864] udpBroadcast
2018-01-04 10:50:54.751446+0800 newDemo[1298:368864] udpBroadcast
server: receiveOneByte fail
: Resource temporarily unavailable
2018-01-04 10:50:54.776160+0800 newDemo[1298:368929] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2018-01-04 10:50:54.786842+0800 newDemo[1298:368930] ESPTouchTask __sleep() end, receive signal is NO
2018-01-04 10:50:54.787019+0800 newDemo[1298:368930] ###################server close() fd=6
: Bad file descriptor
2018-01-04 10:50:54.787199+0800 newDemo[1298:368929] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2018-01-04 10:50:54.787661+0800 newDemo[1298:368930] ESPTouchTask __notify()
2018-01-04 10:50:54.788673+0800 newDemo[1298:368930] ESPViewController executeForResult() result is: [isSuc: NO,isCancelled: NO,bssid: (null),inetAddress: 1.0.0.0]
2018-01-04 10:50:54.788792+0800 newDemo[1298:368930] ESPViewController do cancel action...
2018-01-04 10:50:54.788888+0800 newDemo[1298:368930] ESPTouchTask interrupt()
2018-01-04 10:50:54.789042+0800 newDemo[1298:368929] ESPTouchTask __notify()
2018-01-04 10:50:54.789136+0800 newDemo[1298:368929] ESPTouchTask __listenAsyn() finish
2018-01-04 10:50:54.789322+0800 newDemo[1298:368930] ESPTouchTask __notify()
(lldb)
回帖(1)
贾熹
2024-7-15 17:10:39
以下是一些建议来解决这个问题:
1. 检查网络连接:确保您的设备连接到互联网。尝试断开连接并重新连接,或者尝试连接到另一个网络。
2. 检查设备的IP地址:确保您的设备有一个有效的IP地址。您可以在设备的“设置”>“Wi-Fi”>“已连接的网络”中查看IP地址。
3. 检查DNS设置:确保您的设备使用的DNS服务器是正确的。您可以在设备的“设置”>“Wi-Fi”>“已连接的网络”>“配置DNS”中查看和修改DNS设置。
4. 检查防火墙设置:确保您的设备或网络防火墙没有阻止应用程序访问网络。您可能需要检查设备的防火墙设置或与网络管理员联系。
5. 重启设备:有时候,重启设备可以解决一些网络问题。尝试重启您的设备,然后再次尝试连接。
6. 更新应用程序和系统:确保您的应用程序和操作系统都是最新版本。有时候,更新可以解决一些已知的问题。
7. 检查应用程序的设置:检查应用程序的设置,确保所有必要的设置都已正确配置。
举报
更多回帖
