我需要从我的 esp8266 向 Shelly 插头发出 http 请求才能打开它。如何使用 RTOS SDK 2.1.0 从我的 esp8266 发送 http 请求?
请求网址:http://{shellyplug-ip}/relay/0?turn=on
2024-7-9 16:01:54
要使用ESP8266的RTOS SDK 2.1.0发送HTTP请求,您可以按照以下步骤操作:
1. 确保您已安装ESP8266 RTOS SDK 2.1.0。
2. 创建一个新的项目并设置您的开发环境。
3. 将以下代码添加到您的主应用程序文件中(例如:main.c):
```c
#include "espressif/esp_common.h"
#include "esp/uart.h"
#include "FreeRTOS.h"
#include "task.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include "lwip/api.h"
#include
static const char *shelly_plug_ip = "YOUR_SHELLY_PLUG_IP";
static const char *relay_command = "/relay/0?turn=on";
void http_request_task(void *pvParameters)
char *get_request = (char *)malloc(256);
sprintf(get_request, "GET %s HTTP/1.1rnHost: %srnConnection: closernrn", relay_command, shelly_plug_ip);
struct sockaddr_in server_addr;
int sock = socket(AF_INET, SOCK_STREAM, 0);
if (sock != -1)
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons(80);
server_addr.sin_addr.s_addr = inet_addr(shelly_plug_ip);
if (connect(sock, (struct sockaddr *)&server_addr, sizeof(server_addr)) == 0)
write(sock, get_request, strlen(get_request));
free(get_request);
char receive_buffer[1024];
int bytes_received = recv(sock, receive_buffer, sizeof(receive_buffer) - 1, 0);
if (bytes_received > 0)
receive_buffer[bytes_received] = '
