乐鑫技术交流
直播中
石飞鹏
7年用户 995经验值
私信 关注
[问答]
用ESP_FACTORY_TEST_TOOL_V4.9.5测试时,总出现TX_POWER_BACKOFF部件故障错误的原因?
我用ESP_FACTORY_TEST_TOOL_V4.9.5测试时,总是出现TX_POWER_BACKOFF中的部件故障错误信息,配置文件和log信息如下:
配置文件:
法典:全选
#define   CHIP_TYPE_1            ESP8266   #ESP8089 or ESP8266
#define   LOG_PATH_1            ./logs      #log saving path, user could modify their own folder
#define  FACTORY_INFO_1     ESP     #fill factory id or factory name
#define   COMPORT_1       9
#define   BAUDRATE_1      115200   #26m晶振需要减小波特率(230600)
#define   IMGPATH_1       ./image/eagle.app.flash_MODULE_TEST_26m_tout_151229.bin
#define   FREQ_1          26             #晶振频率
#define   AUTOSTART_1     0              #1:自动开始下一次测试 0:手动开始
#define   INSTRUMENT_EN_1   0          #使能仪器测试模式
#define   IPADDR_IQV_1        192.168.100.254    #iqview 仪器IP地址
#define   IPADDR_PC_1        192.168.100.186     #PC IP地址
#define   TESTER_1        LITEPOINT     #不要更改
#define   RFPORT_1        1    #1:left  2:right
#define   INPUT_ATTEN_EN_1   1  #use input path loss to test tx
#define   PATH_ATTEN_1   21    #practical attenuation in the path
#define   PATH_ATTEN_DIFF_ALARM_1   5  #固定 设置线路衰减与计算值的最大偏差 超过会报错提示
#define   PATH_ATTEN_TX_CRT_1      0    #CORRECT VAL FOR TX GAIN
#define   PATH_ATTEN_CAL_CHANNEL_1   1,6,11,14   #CALCULATE PATH ATTEN IN THIS CHANNEL
#define   PRINT_MAC_EN_1   1   #set 1 to print MAC after
#define   PRINT_MAC_AUTO_1   0   #set 1 to print MAC automatically
#define   PRINT_MAC_COMMAND_1   ./mac_printer/8266_MAC2DPrint.exe
#define   UPLOAD_CMD_PATH_1      ./result_upload/ADS_8266.exe
#define   UPLOAD_SN_RES_EN_1    1    #enable upload test result and SN
#define   UPLOAD_SN_LENGTH_1      12   #length of SN string
#define   UPLOAD_SN_AUTO_START_1   1   #输入满UPLOAD_SN_LENGTH长度的SN号后,自动开始测试,重启或者点击开始后下次生效
#define   ANALOGTEST_1    1
#define   TXTEST_1        1
#define   RXTEST_1        1
#define   SKIP_DOWNLOAD_1  0
#define   SET_MAC_EN_1    0          #support burn customer Mac
#define   MAC_INPUT_EN_1    0
#define   MAC_CRC_EN_1    0
#define   MAC_OFFSET_1    0x7c000            # mac burn addr
#define   MAC_START_1     A00000000000   #mac start addr
#define   MAC_END_1        A00000000008    #mac end addr
#define   MAC_CURRENT_1  A00000000000
#define   DEBUG_EN_1        1
#define   ANTENNA_1         1           #1:天线测试 0:cable测试
#define   INITFROMXLS_1       0         #这项不要更改
#define   START_DELAY_1       200         #四个模块时间相互错开,单位ms
#define   GPIO_TEST_EN_1     0
#define   GPIO_TEST_PIN_1    0x3030
#define   GPIO_TEST_VAL_1    0x1010
#define   GPIO_TEST_READ_EN_1     0
#define   GPIO_TEST_VAL_TARGET_1  0x3030
#define   ADC_TEST_EN_1     0
#define   EFUSE_MODE_1      1    # 0: NOT USED ; 1:NORMAL
#define  USER_FW_DOWNLOAD_EN_1    0   #0: disable ; 1: enable
#define  USER_FW_DOWNLOAD_PORT_1   SPI   #SPI OR HSPI
#define  USER_FW_FORCE_DOWNLOAD_1    0  #0:download if RF test pass ; 1:download after test
#define  USER_FW_VER_TEST_EN_1    0   #0: disable ; 1: uart 2: gpio
#define  USER_FW_VER_STR_1        v1.0.02
#define  USER_FW_FILE_NUM_1       1
#define  USER_FW_PATH0_1        ./bin/test.bin
#define  USER_FW_ADDR0_1        0x0
#define  USER_FW_PATH1_1        ./bin/test.bin
#define  USER_FW_ADDR1_1        0x0
#user fw version, when system restart print : esp_user_fw_version:xxxx
#define  USER_TEST_CMD_EN_1       0  #Send user test command
#define  USER_TEST_CMD_NUM_1      2  #TEST COMMAND NUMBER
#define  USER_TEST_CMD0_1      AT+CWLAPrn
#define  USER_TEST_RESP0_1     OK
#define  USER_TEST_TIMEOUT0_1    5   #S
#define  USER_TEST_CMD1_1      AT+CWLAPrn
#define  USER_TEST_RESP1_1     OK
#define  USER_TEST_TIMEOUT1_1    5   #S
#define  USER_TEST_CMD2_1      AT+CWJAPrn
#define  USER_TEST_RESP2_1     OK
#define  USER_TEST_TIMEOUT2_1    5   #S
log信息:
法典:全选
TOOL_VERSION:4.9.5
工厂: esp
MODULE_TEST开始!!
phy_version: 20130913_b1 2015-12-29 11:51:10
CHIP_VERSION:0x0
CHIP_ID:0x5ccf7f64
rc_cal_dout=29, rx_filt_dcap=14, tx_filt_dcap=23
VDD33=3379,temp_code=0,偏移量=0
cal_rf_ana_gain、rf_gain=0x1f、ana_gain=0x10、bb_atten=6
rxiq_tot_pwr1=33dB,k=0
RX_NOISEFLOOR, -388
RX_NOISEFLOOR,-386
RX_NOISEFLOOR, -392
RX_NOISEFLOOR, -392
TXCAP_TMX2G_CCT_LOAD、13、15、15、
TXCAP_PA2G_CCT_STG1、3、3、1、
TXCAP_PA2G_CCT_STG2、2、1、1、
TX_POWER_BACKOFF、9、10、11、10、
TX_PWRCTRL_ATTEN, -24, -4, 7, 13, 17, 26, -23, -3, 8, 15, 19, 27, -22, 4, 9, 15, 20, 28, -23, -4, 7, 14, 18, 27,
TXIQ, 4, 12
TXDC,79,77;78, 69;78, 67;78, 66;
RXIQ,0,-1;0, -2;1, -2;1, -2;1, -2;
RXDC、257、251、256、256;257, 252, 256, 256;258, 252, 256, 256;258, 252, 256, 256;257, 252, 256, 256;258, 252, 256, 256;259, 253, 256, 256;259, 253, 256, 256;259, 254, 256, 253;258, 254, 258, 253;259, 253, 256, 256;259, 254, 256, 256;260, 254, 256, 256;260, 254, 256, 256;260, 254, 256, 256;260, 254, 253, 256;259, 254, 256, 256;259, 254, 256, 256;259, 254, 256, 255;259, 254, 256, 256;260, 254, 251, 257;259, 254, 256, 256;259, 254, 256, 256;259, 254, 256, 256;259, 254, 256, 255;259, 254, 256, 256;260, 254, 251, 257;259, 254, 256, 256;259, 254, 256, 256;259, 254, 256, 256;
svn_log=772
tx_vdd33=3379
吹捧=13
TEST_NUM=1,TEST_TIME=436172us
MODULE_ANA测试结束!!
TX数据包测试..
txp_pwctrl_atten: 3
rombist_rslt: 0
fb_rxrssi: 55, 55, 54, 53, 52, 53,
dut_rxrssi: 61, 61, 61, 61, 61, 61, 61,
fb_rx_num: 14, 14, 16, 15, 16, 16,
dut_rx_num: 14, 14, 16, 15, 16, 16,
FREQ_OFFSET, -13, -12, -13, -13,
txp_state:0xffffffffdffffffff77fb7ff、0xffffffffdffffffff77fb7ff;
txp_result: 91, 91, 0
0: req_suc:1 req_times:1 data_suc:1 txdata_use_timer:0x636f 96 txreq_start_time:0x72694b txdata_start_time:0x761307
init_time=402935us
MODULE_TEST结束!!
排泄日志:
注册号0:6A5A0000
reg1:02008218
编号2:6400B000
reg3:005ccf7f
EFUSE 正常模式
EFUSE检查通过...-------------------------
TOOL_VERSION:4.9.5
工厂: esp
日志在这里:
TX_POWER_BACKOFF中的部件故障  #0,#0 : 0.000000 !< 9.000000 !< 8.000000
TX_POWER_BACKOFF中的部件故障  #0,#1 : 0.000000 !< 10.000000 !< 8.000000
TX_POWER_BACKOFF中的部件故障  #0,#2 : 0.000000 !< 11.000000 !< 8.000000
TX_POWER_BACKOFF中的部件故障  #0,#3 : 0.000000 !< 10.000000 !< 8.000000
回帖(1)
淡淡的爱
2024-7-8 11:33:10
根据您提供的信息,我将尝试分析可能导致TX_POWER_BACKOFF部件故障错误的原因。以下是一些可能的原因及相应的解决方案:
1. **固件版本不兼容**:请确保您使用的ESP_FACTORY_TEST_TOOL_V4.9.5与您的ESP8266模块兼容。如果不兼容,请尝试更新固件或使用其他版本的测试工具。
2. **配置文件错误**:检查配置文件中的参数设置是否正确。根据您的配置文件,您已经选择了ESP8266作为芯片类型。请确保其他参数(如日志路径等)也正确设置。
3. **硬件问题**:TX_POWER_BACKOFF错误可能与硬件有关。检查您的ESP8266模块是否有任何损坏或故障。如果有,您可能需要更换模块。
4. **软件问题**:软件中的某些设置可能导致TX_POWER_BACKOFF错误。请检查您的代码,确保没有错误或不兼容的设置。
5. **环境因素**:TX_POWER_BACKOFF错误可能与测试环境有关。请确保您的测试环境没有干扰信号或其他可能影响测试结果的因素。
6. **测试工具问题**:如果以上原因都排除了,可能是测试工具本身的问题。您可以尝试重新下载或安装测试工具,或者寻求技术支持。
为了更准确地找到问题所在,您可以提供更多关于测试过程中的详细信息,例如错误代码、日志文件等。这将有助于我为您提供更具体的解决方案。
举报
更多回帖
