乐鑫技术交流
直播中
莫联雪
9年用户 1200经验值
私信 关注
[问答]
基于ESP32C3运行Homekit example报错如何解决?
  IDF版本v4.3-rc
直接烧入Homekit Lightbulb例程之后报错:
E (410) esp_image: Image length 1665504 doesn't fit in partition length 1638400
为了解决这个问题,我将partitions_hap.csv的内容修改为:
[Codebox]
# Name,   Type, SubType, Offset,  Size, Flags
# Note: Firmware partition offset needs to be 64K aligned, initial 36K (9 sectors) are reserved for bootloader and partition table
sec_cert,  0x3F, ,0xd000,    0x3000, ,  # Never mark this as an encrypted partition
nvs,      data, nvs,     0x10000,   0x6000,
otadata,  data, ota,     ,          0x2000
phy_init, data, phy,     ,          0x1000,
ota_0,    app,  ota_0,   0x20000,   1792K,
ota_1,    app,  ota_1,   ,          1792K,
factory_nvs, data,   nvs,     0x3a0000,  0x6000
nvs_keys, data, nvs_keys,0x3a6000,  0x1000
[/Codebox]
再次编译下载后,依然报错无法正常运行
[Codebox]
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40383e58
0x40383e58: esp_restart_noos at /Users/mephisto/esp/esp-idf/components/esp32c3/system_api_esp32c3.c:137 (discriminator 1)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1778
load:0x403ce000,len:0x8d4
load:0x403d0000,len:0x293c
entry 0x403ce000
I (35) boot: ESP-IDF v4.3-rc 2nd stage bootloader
I (35) boot: compile time 15:00:03
I (35) boot: chip revision: 3
I (37) boot.esp32c3: SPI Speed      : 80MHz
I (42) boot.esp32c3: SPI Mode       : DIO
I (46) boot.esp32c3: SPI Flash Size : 4MB
I (51) boot: Enabling RNG early entropy source...
I (57) boot: Partition Table:
I (60) boot: ## Label            Usage          Type ST Offset   Length
I (67) boot:  0 sec_cert         unknown          3f 00 0000d000 00003000
I (75) boot:  1 nvs              WiFi data        01 02 00010000 00006000
I (82) boot:  2 otadata          OTA data         01 00 00016000 00002000
I (90) boot:  3 phy_init         RF data          01 01 00018000 00001000
I (97) boot:  4 ota_0            OTA app          00 10 00020000 001c0000
I (105) boot:  5 ota_1            OTA app          00 11 001e0000 001c0�ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
entry 0x403ce000
I (30) boot: ESP-IDF v4.3-rc 2nd stage bootloader
I (30) boot: compile time 15:00:03
I (30) boot: chip revision: 3
I (32) boot.esp32c3: SPI Speed      : 80MHz
I (37) boot.esp32c3: SPI Mode       : DIO
I (41) boot.esp32c3: SPI Flash Size : 4MB
I (46) boot: Enabling RNG early entropy source...
I (52) boot: Partition Table:
I (55) boot: ## Label            Usage          Type ST Offset   Length
I (62) boot:  0 sec_cert         unknown          3f 00 0000d000 00003000
I (70) boot:  1 nvs              WiFi data        01 02 00010000 00006000
I (77) boot:  2 otadata          OTA data         01 00 00016000 00002000
I (85) boot:  3 phy_init         RF data          01 01 00018000 00001000
I (92) boot:  4 ota_0            OTA app          00 10 00020000 001c0000
I (100) boot:  5 ota_1            OTA app          00 11 001e0000 001c0000
I (107) boot:  6 factory_nvs      WiFi data        01 02 003a0000 00006000
I (115) boot:  7 nvs_keys         NVS keys         01 04 003a6000 00001000
I (122) boot: End of partition table
I (127) esp_image: segment 0: paddr=00020020 vaddr=3c140020 size=46a04h (289284) map
I (180) esp_image: segment 1: paddr=00066a2c vaddr=3fc8da00 size=045f0h ( 17904) load
I (184) esp_image: segment 2: paddr=0006b024 vaddr=40380000 size=04ff4h ( 20468) load
I (190) esp_image: segment 3: paddr=00070020 vaddr=42000020 size=13e0dch (1302748) map
I (398) esp_image: segment 4: paddr=001ae104 vaddr=40384ff4 size=0889ch ( 34972) load
I (405) esp_image: segment 5: paddr=001b69a8 vaddr=50000000 size=00010h (    16) load
I (409) boot: Loaded app from partition at offset 0x20000
I (410) boot: Disabling RNG early entropy source...
I (427) cpu_start: Pro cpu up.
I (439) cpu_start: Pro cpu start user code
I (440) cpu_start: cpu freq: 160000000
I (440) cpu_start: Application information:
I (442) cpu_start: Project name:     lightbulb
I (447) cpu_start: App version:      esp_homekit_release_3.0.r3-38-g
I (454) cpu_start: Compile time:     Jun 10 2021 14:59:55
I (461) cpu_start: ELF file SHA256:  1a89a731318cf04a...
I (466) cpu_start: ESP-IDF:          v4.3-rc
I (472) heap_init: Initializing. RAM available for dynamic allocation:
I (479) heap_init: At 3FC9AE00 len 00025200 (148 KiB): DRAM
I (485) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
I (492) heap_init: At 50000010 len 00001FF0 (7 KiB): RTCRAM
I (498) spi_flash: detected chip: generic
I (503) spi_flash: flash io: dio
I (507) sleep: Configure to isolate all GPIO pins in sleep state
I (513) sleep: Enable automatic switching of GPIO sleep configuration
I (521) cpu_start: Starting scheduler.
Keystore initialised
Accessory is not Paired with any controller
Database initialised. Accessory Device ID: E3:BC:81:CB:BE:91
HAP Initialization succeeded. Version : 4.0-c654909
E (566) ledc: freq_hz=5000 duty_resolution=0
I (566) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (576) app_hap_setup_payload: -----QR Code for HomeKit-----
I (586) app_hap_setup_payload: Scan this QR code from the Home app on iOS
I (656) app_hap_setup_payload: If QR code is not visible, copy paste the below URL in a browser.
https://api.qrserver.com/v1/create-qr-c ... 27813XES32
MFi auth not supported. Falling back to HAP_MFI_AUTH_NONE
I (686) coexist: coexist rom version 9387209
I (686) pp: pp rom version: 9387209
I (686) net80211: net80211 rom version: 9387209
I (706) wifi:wifi driver task: 3fca65c4, prio:23, stack:6656, core=0
I (706) system_api: Base MAC address is not set
I (706) system_api: read default base MAC address from EFUSE
I (716) wifi:wifi firmware version: c7d0450
I (716) wifi:wifi certification version: v7.0
I (716) wifi:config NVS flash: enabled
I (726) wifi:config nano formating: disabled
I (726) wifi:Init data frame dynamic rx buffer num: 32
I (736) wifi:Init management frame dynamic rx buffer num: 32
I (736) wifi:Init management short buffer num: 32
I (746) wifi:Init dynamic tx buffer num: 32
I (746) wifi:Init static tx FG buffer num: 2
I (756) wifi:Init static rx buffer size: 1600
I (756) wifi:Init static rx buffer num: 10
I (756) wifi:Init dynamic rx buffer num: 32
I (766) wifi_init: rx ba win: 6
I (766) wifi_init: tcpip mbox: 32
I (766) wifi_init: udp mbox: 10
I (776) wifi_init: tcp mbox: 6
I (776) wifi_init: tcp tx win: 5744
I (786) wifi_init: tcp rx win: 5744
I (786) wifi_init: tcp mss: 1440
I (786) wifi_init: WiFi IRAM OP enabled
I (796) wifi_init: WiFi RX IRAM OP enabled
Setup ID: ES32
HAP Main Loop Started
mDNS initialised
Registering HomeKit web handlers
Announcing _hap._tcp mDNS service
W (816) BTDM_INIT: esp_bt_mem_release not implemented, return OK
I (826) wifi_prov_scheme_ble: BT memory released
I (826) app_wifi: Starting provisioning
I (836) phy_init: phy_version 500,985899c,Apr 19 2021,16:05:08
I (946) wifi:set rx active PTI: 0, rx ack PTI: 12, and default PTI: 1
I (956) wifi:mode : sta (7c:df:a1:87:b1:fc)
I (956) wifi:enable tsf
I (956) BTDM_INIT: BT controller compile version [501d88d]
I (956) coexist: coexist rom version 9387209
I (966) BTDM_INIT: Bluetooth MAC: 7c:df:a1:87:b1:fe
E (966) simple_ble: Configuration mismatch. Select BLE Only or BTDM mode from menuconfig
E (976) protocomm_ble: simple_ble_start failed w/ error code 0xffffffff
E (986) wifi_prov_scheme_ble: Failed to start protocomm BLE service
E (996) wifi_prov_mgr: Failed to start service
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x4038565d
0x4038565d: _esp_error_check_failed at /Users/mephisto/esp/esp-idf/components/esp_common/src/esp_err.c:41
file: "/Users/mephisto/esp/esp-homekit-sdk/examples/common/app_wifi/app_wifi.c" line 421
func: app_wifi_start
expression: wifi_prov_mgr_start_provisioning(security, pop, service_name, service_key)
abort() was called at PC 0x40385661 on core 0
0x40385661: _esp_error_check_failed at /Users/mephisto/esp/esp-idf/components/esp_common/src/esp_err.c:42
Stack dump detected
Core  0 register dump:
MEPC    : 0x40386524  RA      : 0x40386c84  SP      : 0x3fca00b0  GP      : 0x3fc8e288
0x40386524: panic_abort at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367
0x40386c84: rtos_int_enter at /Users/mephisto/esp/esp-idf/components/freertos/port/riscv/portasm.S:35
TP      : 0x3fc598fc  T0      : 0x37363534  T1      : 0x7271706f  T2      : 0x33323130
S0/FP   : 0x00000004  S1      : 0x3fca0114  A0      : 0x3fca00dc  A1      : 0x3fca0112
A2      : 0x00000000  A3      : 0x3fca0109  A4      : 0x00000001  A5      : 0x3fc9b000
A6      : 0x7a797877  A7      : 0x76757473  S2      : 0x00000000  S3      : 0x00000000
S4      : 0x00000000  S5      : 0x00000000  S6      : 0x00000000  S7      : 0x00000000
S8      : 0x00000000  S9      : 0x00000000  S10     : 0x00000000  S11     : 0x00000000
T3      : 0x6e6d6c6b  T4      : 0x6a696867  T5      : 0x66656463  T6      : 0x62613938
MSTATUS : 0x00001881  MTVEC   : 0x40380001  MCAUSE  : 0x00000007  MTVAL   : 0x00000000
0x40380001: _vector_table at ??:?
MHARTID : 0x00000000
Backtrace:
panic_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367
367         *((int *) 0) = 0; // NOLINT(clang-analyzer-core.NullDereference) should be an invalid operation on targets
#0  panic_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/panic.c:367
#1  0x40386c84 in esp_system_abort (details=details@entry=0x3fca00dc "abort() was called at PC 0x40385661 on core 0") at /Users/mephisto/esp/esp-idf/components/esp_system/system_api.c:112
#2  0x4038c456 in abort () at /Users/mephisto/esp/esp-idf/components/newlib/abort.c:46
#3  0x40385664 in _esp_error_check_failed (rc=, file=file@entry=0x3c144e20 "", line=line@entry=421, function=function@entry=0x3c144764 <__func__.8973> "", expression=expression@entry=0x3c144acc "") at /Users/mephisto/esp/esp-idf/components/esp_common/src/esp_err.c:42
#4  0x42009240 in app_wifi_start (ticks_to_wait=ticks_to_wait@entry=4294967295) at /Users/mephisto/esp/esp-homekit-sdk/examples/common/app_wifi/app_wifi.c:421
#5  0x420079ba in lightbulb_thread_entry (arg=) at ../main/app_main.c:267
#6  0x40389480 in vPortEnterCritical () at /Users/mephisto/esp/esp-idf/components/freertos/port/riscv/port.c:130
#7  0x00000000 in ?? ()
Backtrace stopped: frame did not save the PC
[/Codebox]
请问这个问题如何解决?
我这边同样的例程把环境修改为ESP32就可以正常运行。这个问题只在ESP32C3上出现。
回帖(1)
维生素B2
2024-6-28 16:34:30
根据您提供的信息,您在使用ESP-IDF版本v4.3-rc时,遇到了Homekit Lightbulb例程烧录失败的问题。错误提示表明烧录的固件长度超出了分区表中分配的分区长度。为了解决这个问题,您需要调整分区表以适应固件的大小。
首先,您已经尝试修改了partitions_hap.csv文件,但是看起来您没有提供完整的文件内容。我将为您提供一个示例分区表,您可以根据自己的需求进行调整:
# Note: Firmware partition offset needs to be 64K aligned, initial 36K (9 sectors) are reserved for bootloader and partition tables
nvs,       data, nvs,      0x9000,  0x6000,
phy_init,  data, phy,      0xf000,  0x1000,
factory,   app,   factory,  0x10000, 1M,
sec_cert,  data,  ,         0xd000,  0x2000,
这个示例分区表包括了NVS、PHY初始化数据、工厂固件、安全证书等分区。请根据您的实际需求调整分区类型、大小和偏移。
接下来,按照以下步骤操作:
1. 确保您的ESP-IDF环境已经设置好,并且已经安装了所需的组件。
2. 将上述分区表保存为`partitions_hap.csv`文件。
3. 在您的项目目录中,创建一个名为`partitions`的子目录,并将`partitions_hap.csv`文件放入该目录。
4. 打开`CMakeLists.txt`文件,确保以下行存在:
   set(PARTITION_TABLE_OFFSET 0x8000)
   include(${IDF_PATH}/tools/cmake/partition_table.cmake)
5. 重新构建和烧录您的项目。这将使用新的分区表进行烧录。
如果按照上述步骤操作后仍然遇到问题,请检查您的固件大小是否确实适合新的分区表。如果问题仍然存在,请提供更多的信息,以便我们能够更好地帮助您解决问题。
举报
更多回帖
