问题描述:
环境:
windows环境+esp-idf
烧录环境为windows命令行eclipseclion环境
idf版本为4.2.1
执行idf.py -p COMX flash指令进行烧录时,出现Invalid head of packet (0x47)问题无法烧录。
尝试内容:
同样环境换用esp32-devkitC wroom-32D能够正常烧录。
更换波特率不能解决。
详细报错信息:
[1/4] Performing build step for 'bootloader'
ninja: no work to do.
[1/2] cmd.exe /C "cd /D D:workandlearnMISSUMISSU_socketesp-envcomponentsesptool_py && D:workandlearnMISSUMISSU_socketesp-IDF.espressiftoolscmake3.16.4bincmake.exe -D IDF_PATH="D:/workandlearn/MISSU/MISSU_socket/esp-env" -D ESPTOOLPY="python D:/workandlearn/MISSU/MISSU_socket/esp-env/components/esptool_py/esptool/esptool.py --chip esp32" -D ESPTOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="C:/Users/51680/eclipse-workspace/flash_test1/build" -P D:/workandlearn/MISSU/MISSU_socket/esp-env/components/esptool_py/run_esptool.cmake"
esptool.py --chip esp32 -p COM5 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x8000 par
tition_table/partition-table.bin 0x1000 bootloader/bootloader.bin 0x10000 hello-world.bin
esptool.py v3.0
Serial port COM5
Connecting....
WARNING: This chip doesn't appear to be a ESP32 (chip magic value 0x1b31506f). Probably it is unsupported by this version of esptool.
Chip is ESP32-D0WDQ6 (revision 0)
Features: WiFi, BT, Dual Core, Coding Scheme None
WARNING: Detected crystal freq 0.00MHz is quite different to normalized freq 26MHz. Unsupported crystal in use?
Crystal is 26MHz
MAC: 00:00:00:00:00:00
Uploading stub...
Running stub...
A fatal error occurred: Invalid head of packet (0x47)
CMake Error at run_cmd.cmake:14 (message):
esptool.py failed
Call Stack (most recent call first):
run_esptool.cmake:21 (include)
FAILED: CMakeFiles/flash
ninja: build stopped: subcommand failed.
Executing action: flash
Running ninja in directory c:users51680eclipse-workspaceflash_test1build
Executing "ninja flash"...
ninja failed with exit code 1
求助该问题怎么解决
