乐鑫技术交流
直播中
王利祥
7年用户 1424经验值
私信 关注
[问答]
esp-idf-tools-setup-offline-2.11.exe编译提示Could NOT find Perl,这个Perl如何安装?
官网下载了esp-idf-tools-setup-offline-2.11.exe,安装在D盘以后,对examples目录下面的项目进行编译,提示找不到Perl应用程序,不知这个Perl如何安装?
           以下为编译的过程
d:esp32esp-idfesp32-s2-hmi-devkit-1examplessmart-panel>idf.py build
Executing action: all (aliases: build)
Running cmake in directory d:esp32esp-idfesp32-s2-hmi-devkit-1examplessmart-panelbuild
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32s2 -DCCACHE_ENABLE=1 d:esp32esp-idfesp32-s2-hmi-devkit-1examplessmart-panel"...
-- Found Git: D:/esp32/.espressif/tools/idf-git/2.30.1/cmd/git.exe (found version "2.30.1.windows.1")
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 8.4.0
-- The CXX compiler identification is GNU 8.4.0
-- The ASM compiler identification is GNU
-- Found assembler: D:/esp32/.espressif/tools/xtensa-esp32s2-elf/esp-2021r1-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe
-- Check for working C compiler: D:/esp32/.espressif/tools/xtensa-esp32s2-elf/esp-2021r1-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe
-- Check for working C compiler: D:/esp32/.espressif/tools/xtensa-esp32s2-elf/esp-2021r1-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-gcc.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: D:/esp32/.espressif/tools/xtensa-esp32s2-elf/esp-2021r1-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++.exe
-- Check for working CXX compiler: D:/esp32/.espressif/tools/xtensa-esp32s2-elf/esp-2021r1-8.4.0/xtensa-esp32s2-elf/bin/xtensa-esp32s2-elf-g++.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Building ESP-IDF components for target esp32s2
-- Project sdkconfig file D:/esp32/esp-idf/esp32-s2-hmi-devkit-1/examples/smart-panel/sdkconfig
Loading defaults file D:/esp32/esp-idf/esp32-s2-hmi-devkit-1/examples/smart-panel/sdkconfig.defaults...
-- Found PythonInterp: D:/esp32/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe (found version "3.8.7")
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- App "smart-panel" version: v4.3.1
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.ld
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.api.ld
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.libgcc.ld
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-funcs.ld
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.newlib-data.ld
-- Adding linker script D:/esp32/esp-idf/components/esp_rom/esp32s2/ld/esp32s2.rom.spiflash.ld
-- Adding linker script D:/esp32/esp-idf/esp32-s2-hmi-devkit-1/examples/smart-panel/build/esp-idf/esp32s2/esp32s2_out.ld
-- Adding linker script D:/esp32/esp-idf/components/esp32s2/ld/esp32s2.project.ld.in
-- Adding linker script D:/esp32/esp-idf/components/esp32s2/ld/esp32s2.peripherals.ld
CMake Error at ../../../tools/cmake/component.cmake:274 (message):
  SRC_DIRS entry 'lvgl/src/lv_core' does not exist.
Call Stack (most recent call first):
  ../../../tools/cmake/component.cmake:434 (__component_add_sources)
  ../../components/lvgl/CMakeLists.txt:1 (idf_component_register)
-- Configuring incomplete, errors occurred!
See also "D:/esp32/esp-idf/esp32-s2-hmi-devkit-1/examples/smart-panel/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
回帖(2)
陈桂平
2024-6-20 16:29:02
是缺少lvgl目录下面文件,需要github重新下载对应的目录就可以了。
举报
李秀珍
2024-6-20 17:30:59
Perl 是一种编程语言,用于编写脚本和自动化任务。在您的情况下,ESP-IDF 编译过程需要 Perl。要解决这个问题,请按照以下步骤安装 Perl:
1. 访问 Perl 官方网站:https://www.perl.org/get.html
2. 根据您的操作系统选择相应的安装包。例如,如果您使用的是 Windows 系统,请点击 "Windows"。
3. 下载适用于您系统的 Perl 安装程序。例如,对于 Windows,您可能需要下载 "Strawberry Perl" 或 "ActivePerl"。这里我们以 Strawberry Perl 为例。
4. 下载完成后,运行安装程序并按照提示进行安装。在安装过程中,请确保勾选 "Add Perl to PATH"(将 Perl 添加到 PATH)。这一步非常重要,因为它会让您在命令行中直接运行 Perl。
5. 安装完成后,打开命令提示符(Windows)或终端(Linux/Mac),并输入 `perl -v`。如果安装成功,您将看到 Perl 的版本信息。
现在,您已经成功安装了 Perl。接下来,您需要重新编译 ESP-IDF 项目:
1. 打开命令提示符(Windows)或终端(Linux/Mac),并导航到您的 ESP-IDF 项目目录。例如:
   cd D:esp32esp-idfesp32-s2-hmi-devkit-1examplessmart-panel
2. 运行以下命令以清除之前的构建文件:
   idf.py clean
3. 再次运行以下命令以编译项目:
   idf.py build
现在,您的项目应该可以正常编译,而不会出现找不到 Perl 的错误。如果在编译过程中遇到其他问题,请随时提问。
举报
更多回帖
