开发板:ESP32-S2-DevKitM-1 v1.0
开发环境:win10+espressif-ide(c语言)
我直接打开ulp_adc例程能编译成功,但无法烧录,烧录失败并出现下述信息。(其他例程可以正常烧录)
[1/388] Performing build step for 'ulp_main'
FAILED: esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build esp-idf/main/ulp_main/ulp_main.bin esp-idf/main/ulp_main/ulp_main.ld esp-idf/main/ulp_main/ulp_main.h esp-idf/main/ulp_main/ulp_main.map esp-idf/main/ulp_main/ulp_main.sym esp-idf/main/ulp_main/esp32.ulp.ld esp-idf/main/ulp_main/ulp_main F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main-prefix/src/ulp_main-stamp/ulp_main-build F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.bin F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.ld F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.h F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.map F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.sym F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/esp32.ulp.ld F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main
cmd.exe /C "cd /D F:ESP_Workspaceulp_adcbuildesp-idfmainulp_main && F:ESP-IDFEspressiftoolscmake3.23.1bincmake.exe --build F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main --target build"
[1/4] Linking ASM executable ulp_main
FAILED: ulp_main
cmd.exe /C "cd . && F:ESP-IDFEspressiftoolsesp32s2ulp-elf2.28.51-esp-20191205esp32s2ulp-elf-binu
tilsbinesp32s2ulp-elf-ld.exe -A elf32-esp32s2ulp -nostdlib CMakeFiles/ulp_main.dir/adc.ulp.S.obj -o ulp_main -T"F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_fsm.ld" -Map="F:/ESP_Workspace/ulp_adc/build/esp-idf/main/ulp_main/ulp_main.map" && cd ."
F:ESP-IDFEspressiftoolsesp32s2ulp-elf2.28.51-esp-20191205esp32s2ulp-elf-binutilsbinesp32s2ulp-elf-ld.exe: invalid length for memory region ram
ninja: build stopped: subcommand failed.
[2/388] Performing build step for 'bootloader'
[1/1] cmd.exe /C "cd /D F:ESP_Workspaceulp_adcbuildbootloaderesp-idfesptool_py && python F:/ESP-IDF/Espressif/frameworks/esp-idf-v4.4.2/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 F:/ESP_Workspace/ulp_adc/build/bootloader/bootloader.bin"
Bootloader binary size 0x4950 bytes. 0x26b0 bytes (35%) free.
[3/386] Generating x509_crt_bundle
Executing action: flash
Running ninja in directory f:esp_workspaceulp_adcbuild
Executing "ninja flash"...
ninja failed with exit code 1
例程未更改,但无法下载
能麻烦工作人员帮忙看看吗?
