电路设计论坛
直播中
陈霞
7年用户 942经验值
私信 关注
[问答]
使用AD7705进行双通道采样时,双通道采样数据混乱的原因?
我在使用AD7705进行双通道采样时,交替向通信寄存器写入通道1和通道2的数据读取命令,但每次写命令后,返回的数据是随机的,并没有与通道对应好,请各位帮看下代码有无问题
Uint16 test_cnt1 = 0 ,test_cnt2 = 0;
Uint16 ch_samp_flag = 1; /* ch_samp_flag = 1,通道1采样;ch_samp_flag = 0,通道2采样 */
Uint16 out_vol_samp_dig = 0, out_cur_samp_dig = 0;
float out_vol_samp = 0, out_cur_samp = 0;
float out_vol_samp_real = 0, out_cur_samp_real = 0;
void AD7705_WriteByte(uint8_t addr)
CS_ADC_LOW(1);
// delay_us(1);
spi2_read_write_byte(addr);
// delay_us(1);
CS_ADC_HIGH(1);
void Init_AD7705(uint8_t channel)
uint8_t i;
for(i=0;i<150;i++)/* 多于连续32个 DIN=1 使串口复位 */
AD7705_WriteByte(0xff);//持续DIN高电平写操作,恢复AD7705接口
delay_ms(1);
switch (channel)
case 1:
AD7705_WriteByte(0x20);/* 写时钟寄存器选中ch1*/
AD7705_WriteByte(0x07);/* 4.9152MHz时钟,200Hz数据更新速率 */
AD7705_WriteByte(0x10);/* 选择设置寄存器,使用chnanel 1*/
AD7705_WriteByte(0x44);/* 写设置寄存器 ,设置成单极性、有缓冲、增益为1、滤波器工作、自校准 */
break;
case 2:
AD7705_WriteByte(0x21);/* 写时钟寄存器选中ch2 */
AD7705_WriteByte(0x11);/* 选择设置寄存器,使用chnane 2*/
AD7705_WriteByte(0x44);/* 写设置寄存器,设置成单极性、有缓冲、增益为2、滤波器工作、自校准*/
break;
default:
break;
uint16_t ReadDataAD7705_CH1(void)
// uint16_t result1 = 0;
uint16_t DataH = 0, DataL = 0;
static uint16_t result1_z1=0,result1 = 0;
static uint16_t ad7705ch1_write_rdy = 0 ;
result1 = result1_z1;
if(ad7705ch1_write_rdy == 0)
AD7705_WriteByte(READ_DATA_FROM_CH1);
ad7705ch1_write_rdy = 1;
else
if(SPI2_READ_DRDY == 0)
CS_ADC_LOW(1); /* 使能ADC */
DataH = spi2_read_write_byte(0xff); /* 取数据高字节 */
DataL = spi2_read_write_byte(0xff); /* 取数据低字节 */
CS_ADC_HIGH(1); /* 使能ADC */
DataH = DataH << 8;
result1 = DataH | DataL;
result1_z1 = result1;
ad7705ch1_write_rdy = 0;
test_cnt2++;
ch_samp_flag = 0;
return result1;
uint16_t ReadDataAD7705_CH2(void)
static uint16_t result2_z1 = 0, result2 = 0;
static uint16_t ad7705ch2_write_rdy = 0;
result2 = result2_z1;
if(ad7705ch2_write_rdy == 0)
AD7705_WriteByte(READ_DATA_FROM_CH2);
ad7705ch2_write_rdy = 1;
else
DataH = DataH << 8;
result2 = DataH | DataL;
result2_z1 = result2;
ch_samp_flag = 1;
return result2;
void AD7705MulChSamp(void)
if(ch_samp_flag == 1)
out_vol_samp_dig = ReadDataAD7705_CH1();
out_vol_samp = (float)(out_vol_samp_dig * 1.225/65536);
else
out_cur_samp_dig = ReadDataAD7705_CH2();
out_cur_samp = (float)(out_cur_samp_dig * 1.225/65536);
out_vol_samp_real = (float)out_vol_samp * OutVolSampGain;
out_cur_samp_real = (float)out_cur_samp * OutCurSampGain;
回帖(1)
王浩
2024-6-3 14:14:12
根据您提供的代码片段,我将分析可能导致双通道采样数据混乱的原因,并提供一些建议。
1. 首先,确保您已经正确初始化了AD7705。在开始采样之前,您需要设置正确的控制寄存器值,以确保AD7705按照预期工作。请检查您的初始化代码,确保所有必要的寄存器都已正确设置。
2. 其次,检查您的通信协议。确保您在写入通道1和通道2的数据读取命令时,通信协议是正确的。这包括正确的起始位、数据位、校验位和停止位。如果通信协议不正确,可能会导致数据混乱。
3. 检查您的CS_ADC_LOW()函数。在您的代码中,您使用了CS_ADC_LOW(1); 这可能不是正确的方法来设置片选信号。通常,片选信号应该设置为低电平以选中器件,然后设置为高电平以取消选中。请检查您的硬件连接和CS_ADC_LOW()函数的实现,确保片选信号正确地控制AD7705。
4. 确保您的时序正确。在SPI通信中,时序非常重要。请检查您的代码,确保在发送命令和读取数据时,时序是正确的。这包括适当的延时和数据采样时间。
5. 检查您的数据读取逻辑。在您的代码中,您交替向通信寄存器写入通道1和通道2的数据读取命令。请确保在读取数据时,您正确地识别了通道1和通道2的数据。这可能需要在读取数据之前发送一个特定的命令,或者在读取数据之后进行一些额外的处理。
6. 最后,检查您的硬件连接。确保AD7705与微控制器之间的连接是正确的,包括SPI数据线、时钟线、片选线等。如果硬件连接有问题,可能会导致数据混乱。
综上所述,要解决双通道采样数据混乱的问题,您需要检查初始化、通信协议、时序、数据读取逻辑和硬件连接。希望这些建议能帮助您找到问题所在并解决问题。
举报
更多回帖
