1、
MCU 正在运行,我使用 miniprog3 和 Auto Flash U
tility 擦除闪存,但无法连接目标。
2、日志如下:
PS C:Program Files (x86)infineonAuto Flash Utility 1.3bin>.openocd.exe -s ./scripts -f interface/kitprog3.cfg -c"transport select swd" -f target/traveo2_8m_b0.cfg -c"targets; shutdown"
Open On-Chip Debugger 0.11.0+dev-1.3.0.1958 (2022-02-14-10:58)
Licensed under GNU GPL v2
错误报告请阅读
http://openocd.org/doc/doxygen/bugs.html
适配器速度:2000 kHz
适配卡 srst 延迟:25
适配卡 srst 脉宽:25
** 启用自动获取功能,使用"设置 ENABLE_ACQUIRE 0" 禁用
cortex_m reset_config sysresetreq
TargetName Type Endian TapName State
0* traveo2_8m。cpu.cm0 cortex_m little traveo2_8m.cpu unknown
1 traveo2_8m.cpu.cm70 cortex_m little traveo2_8m.cpu unknown
2 traveo2_8m.cpu.cm71 cortex_m little traveo2_8m.cpu.cm71 cortex_m little traveo2_8m.cpu unknown
调用关机命令
PS C:Program Files (x86)infineonAuto Flash Utility 1.3bin>.openocd.exe -s ./scripts -f interface/kitprog3.cfg -c"transport select swd" -f target/traveo2_8m_b0.cfg -c"init; reset init; flash erase_sector 0 0 last; shutdown"
错误报告请阅读
adapter speed: 2000 kHz
adapter srst delay: 25
adapter srst pulse_width: 25
** Auto-acquire enabled, use"set ENABLE_ACQUIRE 0" to disable
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf151, serial=1B1D0B1D03201400
Info : CMSIS-DAP:支持 SWD
信息:CMSIS-DAP:支持 JTAG
Info : CMSIS-DAP:支持原子命令
信息:CMSIS-DAP:FW 版本 = 2.0.0
信息:CMSIS-DAP:Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP:接口就绪
Info : KitProg3: FW version: 2.40.1241
Info : KitProg3: Pipelined transfers enabled
Info : KitProg3: Asynchronous USB transfers enabled
Info : VTarget = 3.284 V
Info : kitprog3: acquiring the device (mode: reset)...
Error: kitprog3: failed to acquire the device
Info : clock speed 2000 kHz
Error:Error: Error connecting DP: cannot read IDR
Error:DAP "traveo2_8m.cpu 初始化失败(检查连接、
电源、传输、DAP 是否启用等)
Info : traveo2_8m.dap: 关闭调试域电源......
错误:连接 DP 出错:无法读取 IDR
Error:连接 DP 出错:无法读取 IDR
警告 :调试域关机失败
3、您能帮我们提出一些建议吗? 非常感谢
